Question about Brother HL-2070N Laser Printer
Brother HL-2070N won't feed paper from tray
I noted that you replied to someone else on this problem and you said the gears were out of alignment. How do I go about fixing that particular problem? The manual feed is fine. Just the paper tray won't feed.
Thanks.
  • 3 more comments
  • Anonymous Jun 17, 2008
    The HL-2070N wont feed paper. The paper stucks.
  • Anonymous Jul 16, 2008
    Same problem.
  • macla1 Aug 24, 2008
    Same problem ... how do you remove the 'gear'???
  • mzazo Oct 13, 2008
    The printer gears move for a few seconds, then stop and the red printer light blinds. It will not load paper from tray or manual feed.
  • goodkid21 Oct 20, 2008
    Same problem.
I had the same problem with 2 of the 2070N printers. Solution was that the paper tray was setting to tight against the paper pushing it tight up to the front of the tray. Back the rear support up so there is maybe 1/16 inch clearance between the paper and the end of the tray. No more feed problems.
Posted on Nov 25, 2008
  • jercro Nov 25, 2008
    May be the same problem. If the paper is tight in the paper tray, it doesn't feed right. Make sure there is about a 1/16 inch gap between the paper and the front of the tray. Slid the rear clamp back to adjust the distance.
    Problem Solver:
  • 5 Answers
Try cleaning the feed. you may have to remove the black gear with a spring on it temporarily to get the feed spun around... do not remove any pins from the gears these are timing, and as I fix copiers for a living, I have experience with timming.. it isn't for the novice, unless they understand the copier(printer)
cleaning feed is 90 percent of our jamming issues in the industry. You may also get ahold of brother solutions and get new feed and install them.. but brother didn't make this an easy chore. :P
gl
Posted on Jul 17, 2008
If you're running this printer over ethernet, try setting the ip address to static, then configure the driver to the same address, as well as ensuring that you're printing RAW to port 9100. Took me an hour to figure it out, but happily printing from multiple machines now.
Posted on Nov 03, 2008
How to replace paper feeding kit hl 2070n
Unless something is actually broken, I have usually found that the rubber rollers and belts need cleaning. The manual details which ones to clean with rubbing alcohol, but they are mostly at the front of the machine and can be found by removing the paper tray.
Aug 13, 2014 | Brother HL-2070N Laser Printer
My Brother HL-2070N printer won't print Web page
In January 2011 Brother update its drivers for your printer due to a compatibility problem. You haven't advised what operating system you're using but you apparently need to update your drivers.
If you are running Windows 7, you will have to update the drivers either from Microsoft Update or Brother. Click on this link for Brother.
If you are running Windows XP, CLICK HERE
Apr 23, 2012 | Brother HL-2070N Laser Printer
Envelopes will not feed from the paper tray
I usually just set them up as a regular sheet of paper. Print one and adjust your tray to accomodate where they print.
Nov 12, 2009 | Brother HL-2070N Laser Printer
A small white wheel inside the printer that feeds
Hello Sargentjonat,
I have found the service manual of the Brother HL-2070N. Here is a link to the manual:
http://www.megaupload.com/?d=TLIPIA9N
If you can find your gear in the manual then you could find the replacement part number. It's a long document so just Ctrl+F and search for gear.
After that you could try locating a brother service center and calling them. If you go to brother.com and select support there is a service center locator. I have not dealt with brother for replacements before so I don't know their process.
I hope this information can help,
Adam.
Jul 13, 2009 | Brother HL-2070N Laser Printer
Extra paper being fed after print job
Try a test page from the control panel, if this works properly you probably have an issue with the software of the printer. Reload the printer as if it was a brand new machine.
Jun 03, 2009 | Brother HL-2070N Laser Printer
How do I remove paper from paper jam?
To remove paper pull the paper with both hands being careful not to tear the paper . If you're unable to pull it you may need to manually rotate the gears that feed the paper through the printer
Now reset the printer by pressing the power button in on state to turn it off and restart
again thats all just take care that you remove the tray carefully
Thanks and Regards
May 12, 2009 | Brother HL-2070N Printer
Brother HL 2070N red paper light blinks but won't print.
Just fixed my printer issue, had the same problem, Would load 1 sheet, then jam, sometimes it won't pull the paper out of the tray, sometimes it would pull the paper to the toner area, but never into the toner, opening and slamming the paper tray while it attempted to load would usually work, but who wants to slam the tray 50 times? I was using Walgreens generic paper, 20lb, took some higher-quality 24lb HP paper and VOILA! It works every time! EVERYONE WHO IS HAVING THIS PROBLEM, CHECK THAT YOU ARE USING 24LB PAPER!!! Brother says 20-24 is acceptible, but sneaking one sheet of 20lb paper about 15 sheets down in a 20 sheet print job and it will stop at it every time, You can feel the difference, less like toilet paper and more like real paper.
24 LB PAPER! USE IT NOW AND THANK ME LATER!
Jun 27, 2008 | Brother HL-2070N Laser Printer
Will not feed paper
Sounds like the gears are out of alignment for the paper pick up tray.
May 28, 2008 | Brother HL-2070N Laser Printer
Brother HL-2070N Laser Printer Logo
4,498 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
