Question about Goldstar R1003 Air Conditioner
Lost manual hooking up window ac for the first time this year. Do i add water? and if i do need to add water, where do I add it? Thanks
    New Friend:
Hello, I have a goldstar ac and it doesn't cool my place up. What can I do to fix that?? do I need to add water Or I need to change something and it makes noise when It Extracts in the cool air to my place??
Posted on Jun 30, 2013
  • 143 Answers
No, you don't put water into air conditioners. They make their own water and it is an inconvenient by-product that needs to be disposed of in some way. The A/C will use the outside fan blade to fling the water on the hot coil, let it drain out, or both.
Posted on Jul 24, 2008
Why my hitachi ac do not drain water
unless it is really humid many times they will not need to drain any water off
Oct 25, 2015 | Hitachi Heating & Cooling
If I have lost acid from my battery should I have it replaced
If it was lost by evaporation it was just water that left, so add distilled water only. If it was lost by spillage then add a mix of 37-38% sulphuric acid with distilled water, to the correct level indicator.
You can get this mix from an autoparts store like Autozone. It can't be sent by post. If you make the mix yourself, then only ever add acid to water a bit at a time, NEVER add water to acid, it will spit. Wear good eye protection and rubber gloves as well.
Aug 21, 2015 | Cars & Trucks
Do I have to put in water in order to make it colder?? and if so where...and does it collects water, at what point do i dump?? thanks in advance
You DO NOT have to add water. The unit collects humidity out of the air, if you're operating the dehumidifier, in addition to the AC part of the unit. It is not necessary to operate the dehumidifier and the AC side at the same time. Once the water collection tank is full, the unit should shut off and the bucket full warning indicator will glow. This is when you drain the water from the tank, as described in the Owner's Manual. So, just in case you have misplaced the Owner's Manual, I have included a link to it that you can download and print for future reference.
I hope this helps you.
Jul 20, 2011 | Danby DPAC8399 Air Conditioner
Where do i put the water in? i have a ge stand up ac
If its a AC unit, you add no water. If its a humidifier you add water, but you do not want humidity this time of year.
Jul 03, 2011 | GE APH10AA Air Conditioner
The air coming out of my Haier CPRB09XC7 Portable Air Conditioner has gotten warmer and dryer. I'm sure that i need to add water but i do not know how as the manual was lost a while ago. Do I just need to...
Actually, sportsfan, you don't need to add any water. In fact, there is no way to do it. Your unit works much the same way a dehumidifier does with auto evaporation function. In other words, it collects the humidity out of the room air a evaporates it, so there is no water removal on your part involved. While this water is being evaporated, it's also being cooled, so that cools your room. The hot air of the unit running is exhausted out through the window vent kit.
To replace your Owners Manual call Haier Customer Support 877-337-3639
Hope this helped answer your question. Please let me know. Thanks.
May 04, 2011 | Haier CPRB09XC7 Portable Air Conditioner
Kenmore AC 58067081. Have water draining out front. Think it's clogged, but where are the drain holes. Nothing in manual... I've taken off the front grill, and shop vac'd up the water sitting in the bottom...
If you can slide the unit out, there is a drain tube or drain hole from the front tray under the coil that directs the water into the rear of the unit to drain out the hole. That tube needs to be blown out or flushed. It's most likley plugged. You only need to add the drain pipe if you want to direct the drain water away from where it drips now.
Aug 23, 2009 | Heating & Cooling
Ice maker not working Kenmore model 106.55226400
Look for an ice cube lodged in the fingers IM. Get a hair dryer and melt that dude. No ice cube? Add some water to the IM mold. If it kicks out some ice but makes no more then you is gonna need a water valve. If it don't kick out no ice then you is gonna need a ice mold thermostat. Either one is very easy and cheap to fix. let me know Kimosabe.
Mar 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Dometic air conditioner
1The air coditioner does run on Electric. 110V 2. No you do not have to unhook the battery 3. Yes you need to put water in the hot water heater so you do not burn the unit up.
Feb 01, 2009 | Dometic Rooftop RV Air Conditioner
Have a ge ac in window unit asto5 model leaks inside just recently . connot find any plug to pull for draining outside excess water inside ac cabnit . does it have one? been running this ac all summer and...
No drain plug but this model should have a SLINGER RING AROUND the end of the fan blades which picks up the water & sling it on the back coil which it is so hot & evaporates to help get rid of excess water .. So as for the water running inside, the drain channel are plugging up, from the front coil to the back, & only need to add clorox bleach to the front coil area for now , to kill the slime or mold slowly blocking the channels..But first, TURN_OFF UNIT! (certain times of the year, mold & slime grows rapidily and thats what the bleach for..!
Sep 05, 2008 | GE Heating & Cooling
Trying to hook up my jabra bt125 BT to my sanyo katana dlx
Before the search you need to hold down the power button on the headset.Keep it held down until it stops flashing,the PS3 should be able to read it.My problem is that I lost my instruction manual and don't know the pass key.Can anyone help me there?
May 12, 2008 | Jabra BT125 Headset
Goldstar R1003 Air Conditioner Logo
312 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
