Question about Samsung Televison & Video
I have the LNT5271FX/XAA television. Is there a way to have a different picture in picture input other than the television tuner?
The right lower quarter of my Samsung LNT 5271 has lines and blurry when you first turn it on for about 5 minutes before it clears up. Is one of the boards going out?
Posted on Mar 26, 2010
Have hln617wix/xaa all inputs hdmi rca ok vidio good cable or antena picture all scambled
The DLP does not have a flyback but if rear inputs work hook cable b o x there via audio/video cables or use a VCR (does not have to play tapes) via its av jacks to one set on back of tv.
If Video rear inputs are good but antenna,coax are not B Y P A S S the problem.
Mar 17, 2012 | Samsung Televison & Video
Hello my samsung hcn529wx/xaa is has a green picture,I switch my cable boxes and no help, when i disconnect cable box, i get a green blank screen instead of white,i went into the menu page and adjusted all...
If you have a DVD player you can do a test to see if you have a bad tuner in the TV. Using Red, White, and Yellow cables hook up your DVD player to the corresponding jacks on the back of the DVD player and INPUT on the back of the TV with corresponding jacks as well. Turn on the DVD and TV and go to the TV menu and find the input that you have the red, white, and yellow jacks hooked to and see if you get a picture from your DVD player. If you do get a picture you probably have a bad tuner in your TV (if you are sure your cable signal is good). This setup bypasses the tuner. Let me know how it goes. And if you haven't done so be sure you have the right input for your cable signal correct in the menu as well.
Dec 22, 2011 | Samsung HCN4226W 42" Rear Projection...
50" plasma sound but no
Are you running an input device to the tv? Or is this an internal tuner?
If you're running an input device like a cable box or satellite receiver, check your cables. 90% of the time it's a bad input cable. Try a different cable and a different input.
Be sure you inputs are correctly inserted to the corresponding jack, as well.
If it's an internal tuner, switch through all the channels to confirm that you are getting sound only and no video. You may want to contact your cable service provider unless you can confirm it works on seperate tv's in the home. If this is the case, your tuner is malfunctioning.
May 15, 2011 | Samsung Televison & Video
Samsung LNT5271FX/XAA can not be turned on, keep cliking. I tried to replug in and change power outlet, never worked
I had the same problem. It is the capacitors. You can fix this yourself if you have a saudering gun. It is very easy and costs about $10 or less. You can even buy a cheap saudering gun. You just have to replace the bad ones and it will work fine after.
Nov 13, 2010 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
How do I set up a split screen to view two different channels at once?
There are two parts to this, first you need to have picture in picture. No got, then you cannot view the two at once. Then, you need two input sources, like tuner and dvd. or two tuners.
Oct 15, 2010 | Philips 50PFP5332D 50 in. Plasma...
Only use to play games,,, now we have sound but no picture blue screen any suggestions?
Try a different input and see if you get a picture back...try tuner input. A blue screen shows up if it doesn't see an input signal. Try the game on another set. Problem may be with the game.
Mar 10, 2010 | Toshiba CF35F50 TV
Can not get my picture and picture to work. the tv tells me i can't use the same device for side by side pictures.
You probably need to connect a different input. i.e tuner+video or aleast two different signal if you don`t have a split tuner.
Oct 31, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Televison & Video Logo
517 people viewed this question
Henry  Thomas
Henry Thomas
