P1402 - dm-tl air pump motor is shorted or disconnected.
2000 model year accent is equipped with a new enhanced evaporative emission system. this new system is capable of measuring leaks as small as 0.020" diameter. the new system pressurizesthe evaporative emission system with a diagnostic module for tank leakage (dm-tl), while the previous model's system appliedengine vacuum through the purge valve to detect system leaks.
service information
vehicles that have the check engine light illuminated and have dtc p1401, p1402 and p1403 stored in the ecm should have their electrical systems diagnosed related to the appropriate dtc. these codes are not related in any way to an evaporative emission system leak. the conditions that set the diagnostic codes areas follows:
p1401 - dm-tl air pump motor current draw is higher or lower than expected (normal = 17-36 ma).
p1402 - dm-tl air pump motor is shorted or disconnected.
p1403 - dm-tl changeover valve is shorted or disconnected
perform the suggested repair
1. inspect for water in the dmtl by removing the 90° air inlet elbow and looking into the air chamber. if water or corrosion is present, replace the dm-tl p/n 31440-25500; air filterp/n 31453-25500; and pipe assembly p/n 31454-25500if corrosion is in the pipe. see detailed instructions on page3 for air filter replacement.
2. inspect for underbody coating sprayed into connector m52 at dm-tl. if underbody coating is present on the male or female connector, spray with electrical contact cleaner to remove the undercoating.
air filter (dm-tl) replacement instructions
