Question about Brother HL-2040 Laser Printer
ALL lights are on and wont turn off
I changed the drum it didnt work.. toner is also brand new..the paper is in... what else is the probelm...! please help!
THANKS
  • eapen Jun 22, 2008
    how i can replace lacer
  • 3 Answers
Just fixed the same problem following the info here: http://www.fixya.com/support/t612015-print
Posted on Jun 10, 2008
    Problem Solver:
  • 13 Answers
Turn printer on, when all the ied's are flashing press the GO
key down untill just one of the leds stay on.
if the toner light stays on.........replace fuser or mpcb
if the drum light stays on.........replace laser.
if all the lights stay on.............mpcb.
Any of the above solutions that fix the printer would cost
more than the machine was worth.
mongrelken.
Posted on Jun 08, 2008
Tip
Getting Full Yield in Brother Printers - Preventing Early Supply Failures
Brother laser printers, fax machines and multifunctions all use a toner reclaim system. That means the used or left over toner (along with paper dust and debri) is recycled into the new toner cartridge supply. There is no waste section for the leftover toner and debri. This design is efficient however their are some short falls that you need to address. The toner cartridge supply is slowly contaminated with debri and dust that will send the cartridge down prematurely if your not using a good quality paper.
In addition, Brother Drum Units (ie DR-400, DR-500, DR-510, etc...) are expensive and suffer from the same premature failure problems. There is a charging brush and transfer roller inside the front top inside of the drum that drags on the drum surface to charge and discharge it properly for toner transfer. If you use poor quality the built up paper dust and debri interferes with this system and ultimately prevents it from working prperly. Here's a photo of a newer drum that failed due to the use of poor paper. Note the paper dust embedded in the transfer roller (top), caught up in the charge brush (center) and actually laying on the drum (bottom).
Here's a closeup of the charge brush so you can see the problem better below.
Below is the damage that bad paper caused. This DR-520 drum pictured is rated for 25,000 pages but due to low quality paper lasted just over 7,000. This was caused by a "Store Brand" paper.
Here below is a photo of the inside of a brother toner cartridge contaminated with paper dust and debri due to la ow quality super store brand paper. Note all the white paper dust in the toner.
To get the full yield from your Brother supplies, simply use GOOD QUALITY PAPER. STAY AWAY FROM STORE BRAND PAPERS as they go out on low price bid rather than to meet a tight quality standard. I would recommend a HP Brand paper as it's an "ALWAYS KNOWN GOOD" paper. The cheapest on the HP branded papers is HP Office and it works well.
Hope this has helped you understand the importance of using good quality paper in your brother machines. If you found this helpful, please rate it with a FIXYA as significant time and effort was used to help you.
Thanks and Happy Printing
on Mar 31, 2009 | Brother HL 5250DN Laser Printer
Tip
Get the most from Brother Drums and Toner - Stop Early Failures
on Aug 30, 2008 | Brother FAX-8360P Plain Paper Laser
Yellow light on Toner light on) Cannot print a thing
take out the toner.. at the left side of the toner, there is a level, unscrew the 3 screws and turn the level to the other side, this will reset your toner.
make sure the printer is on when you put back the toner.
Jan 18, 2010 | Xerox DocuPrint 203A Laser Printer
Black roller marks on right side of paper
Sounds like you have a bad fuser assembly if the drum unit didn't solve the probelm.
Mar 16, 2009 | Brother HL-5240 Laser Printer
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Toner error
hmmm..not good. when you took out the paper jam, did it come out easy?
http://tinyurl.com/6qcpgy
Aug 18, 2008 | Samsung ML 2010 Laser Printer
Toner light doesnt go away in our printer and the printer doesnt print. We changed the cartridge please help us
The HL-2070N gets jammed in a toner end-of-life error condition. Perform the following to clear (I have 120 in the field so I know it works!):
  1. Open front door
  2. Turn off printer
  3. While holding down the GO button, turn printer back on
  4. When all four LEDs light up release GO button. All LEDs will turn off
  5. Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
  6. Press the GO button 5 times
  7. Paper light will be blinking
  8. At this point the toner end-of-life condition has been reset. Close front door.
Mar 11, 2008 | Brother HL-2070N Laser Printer
HL-2040 CHANGE TONER
Reset the drum counter by opening the front panel, then hold down the power button for about 5seconds until ALL the leds are on. Then realease the button and close the front panel. Your coutner will be resetted.
Dec 22, 2007 | Brother HL-2040 Laser Printer
Brother 5240 laser printer changed toner still wont work.
This works on several different Brother Printers to get rid of toner/drum empty errors:
1. Open the front cover and leave open while completing the following steps.
2. Turn the printer off.
3. Hold the 'go' button while turning the printer on. All panel lights should be on.
4. Release the 'go' button.
5. Press the 'go' button 2 times.
6. Pause.
7. Press the 'go' button 5 times.
8. The toner light should be off.
9. The paper light should be on or flashing [doesn't happen on all].
10. Close cover. The ready light should be the only light on.
Oct 20, 2007 | Brother HL-5240 Laser Printer
Brother HL-2040 Laser Printer Logo
112 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
