Question about Kicker 06ZX750.1 Car Audio Amplifier
Kicker 750.1 Amp wont play music
The amp was working perfectly fine yesterday wen it jus stop playing. the green light is on but the sub wont play. i tested 2 c if it was the sub but it plays fine. all the wiring is hooked up right either its the rca input on the amp or something
  • Shoaib1989 Sep 05, 2008
    I just got my Kicker 12L7 replaced because the face cracked on it, everything was working fine until the shove stopped. The amp status light is green and I just replaced my battery, checked all the wires and fuses and everything seems correct. Any suggestions?
  • HAROLDFLLR Oct 24, 2008
    I HAVE THE SAME PROBLEM WHEN I HOOK UP MEMPHIS SUB 500WATTS
    Problem Solver:
  • 10 Answers
This is a really powerful amp. You may have blown your sub if it's not a very powerful sub. Check all the wiring. Could be a bad ground. Or bad power connection.
Posted on Aug 15, 2014
  • 3 Answers
The wire you are needing to check is the Blue antenna wire that runs from the back of your deck to the amp. More than likely if you are getting a green light on the amp than that means this wire blew a fuse somewhere or blew the amp itself. I would say re-check all the fuses. (there should be one in front of battery wire and some on the amp) If these are still good and you are still getting green light but no sub than check the wiring for the box. I just had to re-wire my box because one of the cables came loose in the box. I have a Kicker 750.1 and a kicker 12" L7 so i understand what you mean... it just takes time and understanding. If everything fails and still it wont work.. than hook the amp up to a friends car and see the results.
Posted on Sep 09, 2010
  • 11,896 Answers
It is probably the rca inputs on the amp may have fried. was your cd decked turned up loudly before the power went out? did any wires accidently touch each other? If had worked fine and then suddenly stopped, than either a wire came loose or the inputs fried. try using different cables and I also suggest disconnecting power for 24 hours and then reconnect. If the green light is on then it is getting power and the problem is in the rca cables or the inputs
Posted on Mar 31, 2009
I have 2 15 inch L5 solo baric subs and need a amp?
the 15" l5 is rated at 750 watts rms so i suggest you get an amp with atleast that much power because if you get a amp weaker than that you run the risk of clipping your subs and blowing them
Jul 15, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Amp has no sound?
Yeah, u are probably right. If u are good enough with electronics it is a pretty easy fix
Feb 07, 2010 | Power Acoustik OVN1-4000D Car Amp
I have a Kicker ZX350.2...Was working for great for over a year. Now it doesn't power the subs. Green & Red LED lights flash. Any idea where to start looking for problem ?
Check the speaker wire first, get another speaker to see if it works (may have blown yours) or get another signal to plug to the speakers tosee if the play. Also check the RCA's and make sure your signal is getting to the amp
Nov 01, 2009 | Kicker ZX350.2 Car Amp
I think ma kicker kx1200.1 amp is blown or ma kicker L7 are gone
that would be the amp. sorry to say. when a wire crosses over, it sends a shock through the amp, there are a few things to try just to see if you fried the amp. the first thing to try is to move your ground to a different location. second thing to look at would be the fuses. alot of times the fuses will blow at the slightest shock. the amp will still turn on if you have an amp with 2 fuses, it just wont be getting all the power it needs, which could be causing your problem. also, it is worth the hour and a half to mount everything down in your vehicle. you might check the kicker website, because i have herd rumors that kicker offers a lifetime warranty on almost all of their products. best of luck, and i hope you didnt fry your amp.
Apr 09, 2009 | Kicker KX1200.1 Car Audio Amplifier
Amp playing speakers very quietly
it sounds like you have the polarity of the speakers hooked up wrong on one of them, try unhooking the new speakers you added and hook them back up one by one, when the music gets fuzzy then reverse the wires for that speaker, this should cure your problem.
Mar 07, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
Kicker 750.1 mono amplifier
Since you didn't mention the red light, I'll assume it's not coming on. If that's the case, you'll need to check the B+ and remote voltage at the amp.
With a multimeter set to DC volts and the black lead on the amplifier's ground terminal, the meter should read 11+ volts when the red lead is touched to either the remote terminal or the B+ terminal.The head unit will need to be on so the remote lead will be 'hot' (have 12v on it).
Nov 17, 2007 | Kicker 06ZX750.1 Car Audio Amplifier
Car audio
hi, your amp seems to be getting power but the cables might be wrong so it's not getting enough power. the light on the amp should be green if everything is going well. are you sure the cables are suitable for your amp?
Sep 11, 2007 | MTX RT202 Car Audio Amplifier
Hifonics 1605d stopped working
the red light blinking because your amplifaier its dead look for the alimentation cabel end replace the calibration protector
Apr 16, 2007 | Hifonics BX1500D Car Audio Amplifier
What amp to use
recommended maximum for the sub boxes is 1600/800 here is the link to the manual if you need it; http://www.kicker.com/06/tech-support/manuals/manuals/2007/2007%20CompVR%20Box%20d01%20Web.pdf If you really wanted to get the maximum from your subs then a zx750, or possibly a zx1000 would be the ideal choice. Either amp you suggested will work, but you will have more fun with a 750 which should do fine. Hope this helps :)
Mar 17, 2007 | Kicker ZX400.1 Car Audio Amplifier
Kicker 06ZX750.1 Car Audio Amplifier Logo
1,208 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
