Question about Canon PIXMA MP160 All-In-One InkJet Printer
Hello hey my name is shelbi boomgarden i am needing help with my canon scanner i have it set up with the usb cord and all but i dont know where to go to get it setup
    Guru:
  • 377 Answers
    Problem Solver:
  • 12 Answers
You need to Unplug it, install the CD that came with it, and when the software tells you to plug it in... then plug it in and follow the prompts to finish the software/driver install.
It's fairly easy but many people plug it in first, when you need to install the CD that came with it first and ONLY plug it in when the software tells you too.
Hope this helps!
Posted on Jun 09, 2008
Very slow operation of Canoscan Lide90
Canon scanners are slow to begin with. A good usb cord plugged directly into a port, not a hub can help. Discontinue as many background programs and operations as possible. The shorter the cord, the better. You can't speed up the scanner, only the data transfer between the scanner and your PC. They are good scanners, just slow. Some printers are like that as well.
May 20, 2014 | Canon CanoScan LiDE 90 Flatbed Scanner
How old is matty b
hi matty b rap it shelby Butler
Jan 11, 2014 | IDKJava Android Apps
When I plug my camera into the computer using the USB cord that was given, the computer says that the camera or scanner cannot be detected. I have used the same cord with the same computer many times...
Its not always a solution but you can try using a *DIFFERENT* usb port on the computer. Windows sees each USB port as a separate thing and treats them differently. It sometimes works.
You could swap the cable if its standard. Cables do break now and then so it is a possibility. Its usually easy to find a second cable for a test.
You can check control_panel -> system -> Hardware -> Device_manager -> Imaging
[Camera name]
See if its happy. if its not, right click-uninstall it, see if it reinstalls ok next time you plug
the USB in.
Its all 15% success solutions which adds up to 45% so its probably not the answer, sadistically speaking.
Jun 25, 2011 | Nikon D60 Digital Camera
Canon MP 640 not recognized by MP Navigator EX 3.0
Your anti virus software is blocking the Canon software. Restore AV default settings.
Jan 31, 2010 | Canon Office Equipment & Supplies
My canon scanner show up on my mac
you have to install the scanner... call up cannon suppport and they will walk you through the process...
Dec 23, 2009 | Canon CanoScan LiDE 90 Flatbed Scanner
Unable to connect printer.
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokl-25
Aug 12, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Smartbase MP360 Scanner Not Identified by MS Vista
One thing to check and be sure of is that your printer cable (USB) is definately a USB 2.0 cable. Canon have an issue with their printers with scanners in that the data flow sometimes isn't sufficient when an older USB cable is used. The slightest drop of data on startup or during scanning will cause a stop.
Worth trying and has sometimes solved the problem for my customers.
Aug 23, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Canon CanoScan5000/5000F - light bulb out
TheComp, I tried what you suggested, but no luck. The scanner is dead. The computer does not even read the scanner through the usb. I called Canon tech support. They tell me that this unit is not serviceable and offered a 20% discount to buy another Canon scanner. No thanks. I don't need another piece of electronic junk. I'll wait for a sale to buy another make. Thanks for your help.
Apr 10, 2008 | Canon CanoScan 5000F Flatbed Scanner
Canon LIDE 60
hi styrimenn,
I see that the LiDE 60 is powered by USB. Thus it draws all its power from USB and requires no power adapter to function. As you certainly know there's currently two versions of USB, namely
USB 1.1 and USB 2.0 Hi-Speed (with a third, USB 3.0 in development).
The difference between the USB versions is such that
USB 2.0 is faster and provides greater electrical power
to attached devices than USB 1.1.
I see from
http://www.canon-europe.com/For_Home/Product_Finder/Scanners/Flatbed/canonscan_lide60/index.asp that the LiDE 60 requires the power output of a USB 2.0 Hi-Speed bus. This means that if you plug the scanner into a USB 1.1 bus, the scanner will not get the required amount of power to function.
If your PC doesn't have on board USB 2.0 ports, a PCI USB 2.0 adapter may be installed in a open PCI expansion slot on your motherboard to provide your PC with USB 2.0 functionality.
You need to download the drivers for the LiDE 60 at
http://software.canon-europe.com/products/0010220.asp
(select your operating system and language). You can download the
CanonScan Toolbox
Deldrv, and
ScanGear SC
to ensure software communication between your PC and scanner
Hope you find this information helpful in solving your scanner's problem and thanks for using the FixYa service
Kind regards
Feb 18, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
27 people viewed this question
old marine
old marine
