Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Singer futura ce-200 problem, pattern mis-alignment
HI! I am having a problem with my singer futura ce-200 embroidery machine. I havent had this problem before until now. When stitching out a design, it will stitch out and mis-align different parts of the design. Such as outlining of the design. I have noticed if i turn the machine off and then back on between each color, it will stay on task, but if i just let it run, the design is not stitching out right at all. Any suggestions as to what is causing this? Thank you, brandi
    Problem Solver:
I have had similar problems in the past.
Do you hear a noise from the embroidery unit when the misalignment occurs ? If so, I suspect that your issue may be that you have some resistance under the hoop. Is there extra material that may be rubbing on the machine or catching somewhere. I have found that if I use some masking tape to keep all of the extra material from hitting any other parts of the machine or dragging under the edge of the hoop this error does not occur. FYI: I also stopped using the "optimize stitch speed" option at the same time. I believe that material dragging was causing the problem, but I still wonder about the stitch speed optimization feature.
Posted on Jul 20, 2008
  • MZES Jul 21, 2008
    When I posted my recommendation I was assuming that you have already installed the service update listed below. If you have not installed this service update, I would recommend that you do this immediately.
    FUTURA™ Service Update version 1.0.0.2
    Go to the Singer Support Web site. Click service updates. Follow the instuctions carefully for your specific operating system. Good Luck
    This update resolved many problems that I had initially with blocks of stitching being misplaced on the material. I still had intermittent issue that were resolved by carefully arranging my material so it does not drag and cause unnecessary resistance on the embriordery carriage.
I have use as the model number of Singer CE200 (Quantum futura ) computer swing meceching. But i have get two hoops when it medium and small one. how we get enbroidary medium caphoop, Super Giant Long Hoop ,Super Double-wide Hoop ,Double Wide Square Hoop. can i use Those above aspective hoops in my swing meching ? wher i get those spesific hoops and in wich country that can availabe.
Posted on Jun 06, 2008
Why cant i install futura ce 150 softwRE with windows 10?
Singer Futura CE-150, I NEED HELP!!! - FreeEmbroideryStuff ...
freeembroiderystuff.embroiderydesigns.com/forums/threadView.aspx?id...
Jul 11, 2014 - 15 posts - ‎10 authors
I just got the Singer Futura CE-150 and every time I start a design it ... Posts: 2/10/2014 11:18:44 PM, RE: Singer Futura CE-150, I NEED ... Futura CE-100but didn't realize it didn't have its original install cd with ... I can't afford Singers price. ... -Software-Download-and-Installation_A287.aspx?id=287&siteid= ...
Singer futura ce-350 software download - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesJavaScript isn't enabled in your browser, so this file can't be opened. Enable and reload. ... Singer futura ce 150 embroidery machine 3900 designs dvd. Top 3 singer ... Singerfutura software for windows 10 memphis soft portal. Using my singer ... Singer futura software installation for windows 2000 xp youtube. Service ...
Singer Futura CE-250 Sewing and Embroidery Machine w
SINGER® FUTURA™ Software Installation for Windows ...? 7:20https://www.youtube.com/watch?v=RDkHyrh0ejkNov 30, 2009 - Uploaded by SingerSewingCompanySINGER® FUTURA™ Software Installation for Windows 2000 & XP ... yes i already have a singer ...Singer Futura will not work with Windows 7 - Microsoft Communityanswers.microsoft.com/.../singer-futura.../da1ea4db-8594-4a12-91d1-d8...I bought a Singer Futura sewing machine and a Win 7 laptop for Christmas. ... can find the right person at Singer to talk to they might let you have a pre-release version of thesoftware. ... What if you download the patch and it still doesn't work? ... if you are using ce-150 go to http://futura-support.com/downloads/ce150.html.
Dec 30, 2015 | Sewing Machines
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
My embroidery (Singer Quantum XL6000) requires the Windows XP and lower on a computer to acquire additional patterns, will it work with Windows 7?
Mine works with Vista. :)
Just install the XP patch (futura-support.com/downloads/patch.htm) and tell Windows 7 to run the software in XP mode.
Oct 07, 2011 | Singer CE-200 Quantum Futura Computerized...
Which format should I use for my Singer futura CE-200 when I download embroidery deisgns
The Futura should run any format program but its dedicated program type is XXX so if you have that option I would use that one.
Jan 18, 2011 | Singer CE-200 Quantum Futura Computerized...
What embroidery download formats can be used on singer ce200
It depends on your software version. The list of supported formats could be found in the manual, on Futura support site or checked right through the sofware menu (File->Open, File->Save as)
Apr 28, 2010 | Singer CE-200 Quantum Futura Computerized...
Singer futura ce-100 wont start
Do you still have the embroidery arm attached? If you do, the sewing function of the machine won't work.
Mar 24, 2010 | Singer CE-100 Futura Computerized Sewing...
CE150 Editing Software
http://www.futura-support.com
Go there and check out the support site.It is a singer website.
Mar 25, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer futura CE-200 Can not wind the bobbin thread
In embroidery mode, you have to send a design to the machine before the bobbin winder will work.
Jan 30, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
606 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
