Question about Whirlpool Refrigerators
Whirlpool designer stlye side by side, model #ed25dq
Moved refrig to garage , worked great for 2 weeks, now freezer and refrig will not cool down, also need to find replacement ice maker
guly
  • 67 Answers
SOURCE: Build-up of a mountain of ice in freezer
replace the heater tube inside the freezer under the cooling fan good luck
Posted on Sep 24, 2007
fridgetech
  • 473 Answers
SOURCE: GE GSS20IE Ice Maker
Even though the fridge was given to you it still has a 1 yr warranty from manufacture date.  Look on the sticker inside the fridge and see if it gives the manufacture date or get the receipt from you gave it to you.  Call 1-800-905-9505 for service.  They are nationwide (US).  If you find out it is older than 1 yr then use the model # on that sticker and go to www3.sears.com to get the correct part # for the icemaker.  Unfortunately these come as a whole unit and can't replace parts.  Once you have the correct part # I bet will find a good price on ebay for a new ice maker.  If you need help finding the part # or any other questions let me know.  If you feel I didn't help solve your problem please let me know before you rate this solution.
Posted on Oct 13, 2007
Sea Breeze
  • 4654 Answers
SOURCE: Whirlpool ED25DQ - not colling
Need you to look inside the fresh food compartment and turn the defrost timer clockwise slowly.
d01b0a9.png part number 6 is defrost timer. When you turn it and compressor stops leave it there for 20 minutes and see if the refrigerator comes back on. If not the timer will need to be replaced, Let me know, Sea Breeze
Posted on Mar 22, 2009
projdoc
  • 2237 Answers
SOURCE: Whirlpool Side By SIde Refrigerator Freezer stopped cooling
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 28, 2009
  • 3 Answers
SOURCE: ED2KVEXVL Whirlpool refridgerator - not cooling in refridgerator
Tip: Most self-defrosting household refrigerators that loose part or all of their cooling in the freezer or fridge are having problems with the self-defrost system. Three components to check: defrost timer; defrost heater elements (esp. on side x side units); and evaporator fan. All cold air is normally produced in the freezer, then circulated via evaporator fan to the refrigerator section. About every 12 hrs. a defrost timer turns off the compressor, and turns on the defrost elements to melt the frost from the evaporator coils. This normally takes about 20 minutes to complete, then the timer turns off the heaters, and restores normal cooling operations. If the cycle does not complete properly, the coils will "ice up", restricting proper air circulation through the freezer and refrigerator sections. Worse yet is if timer sticks in defrost mode (rare), it will turn the freezer into an oven. If the defrost system seems to be working normally, then you should check the condensing coils for excess dirt, and vacuum &/or bush the dirt and lint out to restore proper head disipation. It's recommended that you vacuum out a condensor that's located on the bottom of the unit once a year. You should also check the condensor fan (if present) for proper operation. If the condensor fan fails, heat can not be properly released from the condensor, and will cause the refrigerator to 'run all the time' yet not cool efficiently. There are many things to check on modern frost-free refrigerators, before turning to the actual sealed refrigeration system and compressor unit.
Posted on Jan 11, 2010
How do I determine and fix what is wrong with 2008 model whirlpool frig that the freezer I noticed first all food unfrozen then a couple days later refrigerator not cooling can hear running but contin
I ned more information to answer your question. What model do you have? This is very important to give you the correct information you seek. Thanks
Sep 16, 2014 | Whirlpool Refrigerators
I have a Whirlpool Refrig. model GX5FHDXVY04. The freezer is working properly but the refrigerator is not cooling. I noticed frost on the inside back panel of the freezer. I turned the temp down in the...
Many of frost-free fridges use fans to move a controlled amount of air into the upper or side cooling chamber, check for non-working fan or a stuck or malfunctioning damper control. Keith L.
Mar 02, 2012 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
After defrosting the freezer, both the freezer and the refrigerator side work great for about 2 weeks. Then the refrigerator side will not cool below 50 degrees. If we shut it off and let it defrost...
Old fashion ice box's had to be defrosted by hand like yall are doing now. Apparently the defrost timer, the defrost heater, or the defrost termination thermostat has took a dump. It takes about 2 weeks for every thang to clog up in a evaporator.
I wrote a tip about it and included links to service manuals HERE
Apr 13, 2011 | Kitchen Ranges
Refrig. stopped cooling then the freezer side. then started back
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
ED25DQ refrigerator: will not stop running; find
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Oct 28, 2009 | Whirlpool ED2FHEXN Side by Side...
Aug 24, 2009 | Whirlpool GS6NBEXRQ Side by Side...
Moved refrig this morning and now it is not cooling... freezer works great
Hih, Check and see if something has stopped the condenser fan motor down by the compressor from turning. Sometimes this happens in a move.
Also make sure the controls didn't get turned to wrong settings. Make sure evaporator fan motor is working in freezer and that there is no frost building up on the rear panel.
Just some ideas to help you.
lease let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Admiral 26 cu. ft. Side-By-Side...
Mar 22, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Sep 22, 2007 | Whirlpool GAFZ21 Bottom Freezer...
Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
101 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
