we cant hear it.
any own with 22 year old car and drove it for 22 year
will hear noises for sure not serviced/.
we can guess what is knocking 3000 parts to a car.
engine or trans, brakes or suspension, wheel bearings or what/
why not ask the living this, in person called a shop.
we are blind and deaf here, so all we can to is guess wrong.
here is my wild useless guess
EGR fails and engine knocks.
It's a 32 year old moped designed for about 12-20k of use and to only last a few years. When was the last time it ran? Is the fuel tank, carburetor, and ignition system in good condition? How old is the fuel? Do you have the oil/fuel ratio mixed correctly? How about compression? does the engine have the correct compression. That is a very simple machine, if you have spark, combustion and fuel it will run. If is missing any of those it will not.
gerneric should be able to be used as i had to work on a customers old prima and used some generic parts. ill try and find the link for you for the parts
Hi and welcome to fixya,
it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube...
thank u.........
go to the section "Moving the carriage" turn on printer and then unplug power. If you still cant move the carrage then remove both toner cartridge and all the trays. Then completely disconnect printer and stand it upright (so paper feed and cartridge tray is on top) Look thru the paper feed area to the left side of toner carrage and you will see a little plastic tab around the bottom back of the carrage. That tab is suppose to be inside a track on the bottom of the carrage. I think that when we put in or took out toner we must have pushed it to hard and that piece jumped out of the track and has "locked" the carrage. I just pushed the carrage up carefully and used a letter opener to move the plastic tab back into place (tab is spring loaded) print working fine now. Hope this solves your problem
adjust first the screen. it is a knob at the back of plyback.(lower knob),if the has vertical line ,then the section had a problem.try to resolder the vertical IC or else change the IC.
issue with carrage , try cleaning ink carrage .
first
*unplug the power cable and press and hold power button for 1 min
*press and hold # and 6 , while holding # and 6 plug the power cable back in
*release the button after 10 sec
*wait for some time
*open carrage access door
*cleane printer carrage see for any dust in carrage
*pull the carrage to left
*turn off printer and turn it on
then try pressing OK and cancel at the same time
check for test page
