Question about Onkyo HTR500 Receiver
Power will not stay on
Have unplugged and re-plugged in - turns on, immediately shuts off.
is there a reset button on the HTR500 ?
  • 3 more comments
  • mefootin Oct 13, 2008
    I had this problem for a while, then I couldn't get it to turn on unless I unplugged the unit. Now, that doesn't even work. I cannot get it out of standby mode.
  • twhite311 Oct 27, 2008
    have unplugged and re-plugged in - turns on, immediately shuts off.
  • Anonymous Nov 19, 2008
    power will not stay on and goes stat to stad by mode
  • jackg2 Nov 20, 2008
    need solution
  • mtfalls Apr 04, 2009
    I can turn it on, and it immediately shuts off. The standby button continues to flash. My troubleshooting page mentioned the Amplifier protection circuitry has been activated. How do you deactivate it?
  • 135 Answers
Www.eserviceinfo.com/downloadsm/28790/Onkyo_HT-R500.html
Posted on Oct 02, 2008
Turns on and then it turns off ,iv'e tried to get help no one can help me so please help!
Posted on Nov 20, 2008
    can't find solution
WINDOW XP WOM'T SHUT DOWN
Hold the power button in for a few seconds it will shut down. Then unplug system and push the power button down with it unplugged then replug it in and power up again. Then do a proper shut down again to see if the problem fixed. I hope this assisted you. John
Feb 07, 2011 | Microsoft Windows XP Professional
When i push power button clicks on immediately
I had this problem also and discovered an easy way to trick it into powering on: Click the power button, then within 1 second of the receiver powering off, click the power button again. The receiver should stay on this time. This works with both the button on the receiver and the remote control.
I would like to know what causes this problem and whether or not I should be concerned about damage being done. I assume this is a power protection. I haven't tried plugging this receiver into a different power socket to test, but I don't think the power plug is the problem. Note: I have the subwoofer plugged into the power plug on the back of the receiver.
Feb 23, 2010 | Onkyo HTR500 Receiver
I push the Power button--but usually have to go thru many tries before machine turns on. It was suggested to remove the PWR plug from the ASUS motherboard and replace it with the RST plug. First time thru:...
hi , by your description i would say the relay in your power supply is deffective , its not a cost effective repair , so change the power supply
hope this helps
Jan 10, 2010 | Antec CASE |P180B BLACK RT
My rxv 1800 wasnt used for probably a year but was left plugged to a wall outlet during that time it wasnt used. when i came home last week, i switched it on but immediately shuts off after a second. when...
r this one: Switc off your receiver using the main power button on the front face. Hold the the Effect button and the Direct button, and turn the main power ON.f it ain't working, try this one: Turn your receiver ON and, while holding down the [VCR1] button, press the [STANDBY/ON] button. "Clear" might appears on the display and your receiver might enter Standby mode.
Hope it does.. With your receiver in the Standby mode, hold on STRAIGHT (EFFECT) on the front panel and press STANDBY/ON.
* The ADVANCED sETUP menu appears in the front panel display.ress STRAIGHT (EFFECT) to select the desired setting.
RESET = To reset your receiver to its factory presets.
CANCEL = To cancel without making any changes Press STANDBY/ON to confirm your selection.
* If you selected "RESET", your receiver is reset to its factory presets and switches to Standby mode good luck
shaun
Aug 24, 2009 | Yamaha RX-V1800
After turning in my receiver, it immediately turns back off.
Sounds like it's going in to safe mode. This can be caused by a number of things but the first thing to look at is a failed output amp.
May 03, 2009 | Onkyo HTR500 Receiver
It hangs on the first screen!
when i plug it in to charge it just stays on the philips welcome screen and just stayz like that wen i reset it does the same thing
Sep 10, 2008 | Philips GoGear Flash MP3 Player
Set won't stay on
hi im joe i have the same problem, but before this happened it turned the channel by its self and hade a mind of its own. to get it on unplug it. then as you plug it in repeatedly press the power button on the REMOTE. this will get it to turn on. if you get it on and some how get to control it then go into menu and put the fpd lock on. now you can only use the remote but at least it works. :)
Apr 06, 2008 | RCA 27V520T 27" TV
Reciever shutting off
Has anyone found a solution for this problem? My unit starting clicking off to standby once in a while and now does it all the time.
Feb 02, 2008 | Onkyo HTR500 Receiver
HT-R510 home theater system
If bought new return immediately for replacement. The amp section is no good and cannot be reset - needs repair. but you are under WARRANTY - use it.
Sep 06, 2017 | Onkyo HT-S490 System
Onkyo HTR500 Receiver Logo
449 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
