Question about HP Office Equipment & Supplies
My HP 990cse deskjet printer prints in very faint ink, even though I have just put in 2 new ink cartridges. What happened?
Make sure you have a tri-color and a black cartridge installed. Make sure the print quality is not set to draft mode. Only use HP inkjet cartridges and not refilled cartridges. Make sure you are using the correct driver for your operating system.
Posted on Jun 04, 2008
I have refilled ink in my cartridge but when i try to print nothing comes out i.e it gives faint copies
Ink is full but nib is faulty will pen writes? similarly cartridge refilled with ink but nozzles are clogged/blocked then print wont happen properly..before refilling the cartridge check nozzle status, clean nozzles properly then refill it. Remedy1:Take little warm water pour in small container dip nozzles in water wait some 2-3 minutes clean nozzle area with dry smooth cloth...try it till print quality improves..Remedy2: You can do clan/align process through printer drivers properties..
Nov 15, 2011 | HP LaserJet M1522nf Multifunction Printer...
My HP PRINTER,DESKJET F4180 is printing faintly even though there is a lot of ink
I presume that you have tried with different cartridges to rule out the possibility of cartridge fault and you are not printing in draft mode.
Clean the electrical contacts on the cartirdges and carriage.
The steel rod, on which the carriage moves, is set too far away from the paper. Open the printer's top cover and loosen the lock screw of the brackets holding the rod by its ends. Rotate these brackets a few degrees to lower the print carriage towards the paper to obtain desired printing. The screws to tightened.
Feb 17, 2011 | HP Deskjet F4180 All-in-One InkJet Printer
Sketchy printing
Clean the print heads. If that fails replace the cartridge.
Sep 10, 2009 | HP DeskJet 990cse InkJet Printer
Deskjet 990Cse
Are you sure the plastic tape has been removed from the cartridges?
Jun 06, 2009 | Apple HP DeskJet 990cse InkJet Printer
Hp deskjet 990 cse won't stop printing, help!
you'll need to re install the printer drivers, clear out the print queue, and begin anew
www.hp.com has those drivers by model number and operating system
http://tinyurl.com/6qcpgy
Aug 19, 2008 | Apple HP DeskJet 990cse InkJet Printer
Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
Jul 06, 2008 | HP DeskJet 5150 InkJet Printer
My hp officejet d135 won't print with ink. I just installed two new ink cartridges. It printed out one sheet very very faintly and then wouldn't put out any more ink. The printer hasn't been used in...
look un der the print cartridge, you should see the actual print heads or jets. they can be removed and cleaned with mild soap and water. They tend to plug up if not used regularly.
Apr 28, 2008 | HP DeskJet F380 All-In-One Printer
Cleaning the print head on my HP5440 printer?
Try cleaning the head of the cartrige with alcohol and a Q-tip, if this doesn't help you may have to buy a new one. Cartriges can dry up if they haven't been used for a while. Even though you refilled it, there could be some dry ink stuck in the head. Hold the Qtip with alcohol on the head for a bit and let it dry, reinstall it and then try printing again.
Nov 08, 2007 | HP Deskjet 5440 InkJet Photo Printer
Deteriorating Print Quality
This is Maltesecross. Turns out that the faintness of my printed pages was in fact due to a low ink cartridge, even though some pages printed out fine and others half-good. Eventually, all pages turned faint, and upon re-installing the driver, I got a low-ink warning (the first one ever). Putting in a new ink cartridge solved the problem for me.
Oct 21, 2007 | HP Photosmart C3180 All-In-One InkJet...
168 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
