Question about HP Computers & Internet
Operating system A computer took a hard hit, and the power cord broke in the process. When booting it back up, it goes into codes and finally to one where it says no operating system can be found. Would that be because of the power cord or the computer got jostled....?
  • james yu
    james yu May 11, 2010
    Hi Pepsi250;
    What Operating system are you using? when you say power cord broke, do you mean i got cut into two?
    Try pressing F8 while booting up and select Last known good configuration and reply to this post about the result.
    thanks
  • 89 Answers
Most probable cause is that the pc is unable to detect the Hard Drive, could be caused by some loose connections/wirings. Open the CPU case and try to re-attach the cables from the motherboard to the hard disk drive, and try your pc again.
Posted on Jun 04, 2008
I can not upgrade windows, javaor my restore point/ what can I do ?
Windows XP comes in two editions: Home and Professional. The Home edition is intended for a casual computer user while Professional is intended for an office context. If you are experiencing slow performance in Windows XP Home Edition, you may want to reboot the operating system, which is defined as simply reloading the operating system by restarting the computer.
Turn off all peripheral devices connected to your computer, including speakers, printers, scanners and external hard drives. Click the "Start" button located in the bottom left corner of the desktop and select "Turn off Computer." From the "Turn off Computer" menu, select "Turn Off." Allow the computer to completely shut down. Give the computer sufficient time to rest and make sure that there is absolutely no noise coming out of the computer. Unplug the power cord from the power source and wait at least five seconds. Plug the power cord back into the power source. Turn the computer back on by pressing the "Power" button on the computer and wait for Windows XP to reload. or factory settings Restart the computer. Press the "F8" key after the computer reboots but before the "Windows" logo appears on the screen. You should now see the "Advanced Boot" menu. Scroll down through the menu options using the down arrow key. Stop when "Repair Your Computer" is highlighted and hit the "Enter" key. Select the language you wish to use and press the "Enter" key. Type in the computer's administrator ID and password. Press the "Enter" key. Scroll through the options using the down arrow key. Choose "Restore (name of computer manufacturer) Settings." Press the "Enter" key. Choose "Yes" when asked if you want to reformat the hard drive. Press the "Enter" key to begin the reformatting process. The process takes a few minutes, so be patient. Do not turn off the computer or attempt to stop the process after it has begun, or this may result in major damage to the hard drive. Choose "Finish" and press the "Enter" key to restart the computer. The computer will restart with the original factory settings.
Hope this helps.
Jan 18, 2013 | Microsoft Windows XP Home Edition
When i start my computer it come on but i have hit the f1key to start my computer
You have to format a hard drive with a third party disk unless its a usb data drive
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system.
Note: After you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded
If you are putting windows XP on your computer your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd.
hope this helps
Nov 18, 2012 | Dell Dimension 9200 PC Desktop
Pxe e53 no boot filename received
Sounds like it is trying to boot from a lan or someplace other than your hard drive. Make sure you don't have a music cd or movie dvd in the cd/dvd drive. Turn the computer off then turn it back on and the screen for which key it says to hit to Change The Boot Sequence or Boot Order, then hit that key. You have to hit the key when you see the message or it will not work and you will have to reboot and start over. Select the Hard Drive as the boot device and let it boot up. If you are successful then each time you boot you will need to do this process unless you make it a permanent change.
To make a permanent change to the boot process turn the computer off, then turn it back on and watch the screen for which key it says to hit to get into the Bios or System Setup, then hit that key. You have to hit the key when you see the message or it will not work and you will have to restart and boot again. Once you are in the Bios or System Setup look for any reference to Boot, Boot Sequence or Boot Order. It might be a tab you you select at the top of the window. Change the boot order to CD\DvD as 1st and the Hard Drive as 2nd. This is the normal boot order so that if anything goes wrong with the hard drive, you can boot from the cd/dvd by putting in a repair disk or operating system disk. Just make sure you don't have a music cd, movie dvd or anything in the cd/dvd drive when you boot. Save the settings and exit the Bios or System Setup and Reboot.
Jun 05, 2012 | Intel D946GZIS Motherboard
My HP Pavilion dv9740us Notebook PC dosent start the screen is black
Doesn't start as in nothing happens when you hit the power button? Or are you saying the Desktop is black, but it seems like windows started and went through the boot process?
If nothing happens when you hit the power button:
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 20, 2012 | Computers & Internet
Dell OptiPlex GX620 no boot sometimes it appears black screen with a cursor blinking
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 02, 2012 | Dell OptiPlex GX620 PC Desktop
MODEL LT2016U WONT BOOT UP
Is it trying to boot up or is it doing absolutely nothing when you plug in the power cord and hit the power button?
Mar 30, 2012 | Computers & Internet
Comp.will not boot starts screen no signal goes off
Mar 29, 2012 | Computers & Internet
I have a worm in my computer. How can I format the disk?
if you format your hard drive you will need to load another operating syatem on on it
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Hope this helps
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
if you still want to load another operating system
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
Jun 20, 2011 | Fujitsu Siemens (MAN3184MCB) Hard Drive
For Atheros AR8121/AR8113/AR8114 PCIE Ethernet Controller v1.0.0.9 2008/04/25) Check Cable connection! PXE-MOF: Exiting Intel PXE ROM. No bootable device -- insert bot disk and press any key
hfc_32 - Hi, your system is telling you that it can't find a boot device (Your hard drive) and is trying to boot from a network instead (PXE) which doesn't exist.
Either something is wrong with your hard disk or somehow the boot device got changed in your system's BIOS.
You didn't say anything about your computer (laptop, desktop. Mac or PC?). There are a few things you should try (if you're comfortable doing it).
The easiest thing to try is to get the CD/DVD of your operating system and place it in the optical drive (with the error you described on the screen) power it down and then in turn it back on. It should boot from the OS disc and let you know if it finds your hard disk. You didn't specify your OS so we can't go any further there. Hopefully it will find your hard drive. Then you'll know that it didn't die.
If the disc doesn't see the hard drive and your PC is a desktop system (don't do any of this with a laptop) open the case and make sure the power and data cables are securely connected. Try booting again. The hard drive will be in a cage type holder usually at the front of the system.
Lastly, if the system still doesn't boot look in your system manual and find out how to get into the system BIOS. Follow the instructions and go to the Boot section and see if you hard disk is listed and if so make sure it is listed as the FIRST boot device.
To try to get into the BIOS if you don't have the manual try hitting (on separate boot attempts) at the beginning of the boot process (when you first see the white text on black boot screen just after you've applied power) first the key, then if that doesn't work, next try the key, then the key and finally try hitting the key.
Good Luck and Thank You for using 'Fix Ya'
Mikeywaf
Mar 16, 2011 | Computers & Internet
Error - The Hard Disk Was Not Found
Boot into the BIOS, I think you hit the Delete key on Dell's to get into the BIOS, but I'm not sure. You should see some type of message at boot that says "To enter setup press XXX" Where XXX is the Delete key or some other key.
Once you're in the BIOS setup see if your HDD is listed. You may also find the option to reset the BIOS to default. Generally speaking this will not hurt anything and may be worth a try.
Dec 19, 2007 | Dell Precision M60 Notebook
Computers & Internet Logo
26 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
