Panasonic Reverse cycle Airconditioner
I have an airconditioner installed on my balcony. I need to remove it to allow the balcony floor to be maintained. It needs to be disconnected from power supply and internal unit. How can I do this myself?
  • 828 Answers
This operation should NOT be done by the home owner. If the unit has valves on the high and low sides to enable a pump down operation of the system (gage manifold required) to return all refrigerant to the high side of the system (condensing unit). If the system does not have valves it must have the refrigerant charge recovered from the system before it is disconnected. Call someone qualified!
Posted on Jun 04, 2008
Why isn't it heating?
Because its an air conditioner, not a heater?
May 03, 2015 | Heating & Cooling
Panasonic power light flashing air not cold blowing
hi there you need to see where you bhave a gas leak thats all the flashing light indicates that your gas pressure is to low to activate your compressor
Dec 09, 2013 | Panasonic Heating & Cooling
Airconditioner hitachi reverse cycle
Hi, this is a heat-pump. What is it you need to know about it??
Shastalaker7
Sep 19, 2011 | Hitachi Heating & Cooling
I bougth an Uberhaus Airconditioner R410A. It is draining out onto the carpet, while I use the airconditioner, We hadn't attached the drainage tube! Is this supposed to be constantly drainned or does...
If this is the 3-in-1 air conditioner, then you have two options:
1- do you see two drain outlets on the back? one is at the very bottom and has a removable plug and the second should be about half way down also with a removable plug. This air conditioner has a small non-removable tank that will fill up and a red light on the panel will light up and the machine will switch to FAN mode when full. Then you have to roll the machine to a drain and unplug the bottom plug to let it drain out. Not resonable.Probably good for a basement with a drain in the floor, but not on the main floor or 2nd storey floor.
2nd method is to unplug the top drain (Keep the bottom drain plugged) , attach the plastic hose that the machine came with to this drain, find a bucket that is at the same height or below the top drain and let the water drain into the bucket. Then when it gets about 3/4 of the way full, empty the bucket.This way the airconditioner mode and the humidifier mode will work continously.
This is the way this type of air conditioner is made.
Hope that helps
Jul 20, 2011 | Heating & Cooling
Hot water heater leakes on top
what sort of heater is it the pipes that are leaking or coming out of heater its self and is it reverse cycle being a airconditioner as well need more info to help
Jul 06, 2011 | Heating & Cooling
Our reverse cycle airconditioner is not cooling in two of our bedrooms, but the rest of the house seems to be cooling alright, but I am sorry the airconditioner is approximately 6-7 years old and we have...
Hi, I assume it is ducted, it could be either a flapper door is closed to shut off an area from receiving air, or there is a blockage in the duct (less likely). Also if there is more than one duct attached to the air conditioner then you'll have to check if air is entering all ducts (you may have a problem with the unit).
Nov 16, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Manual for Akai reverse cycle airconditioner remote control
I have a Akai AC-GP10HRCI model portable air conditioner. We have lost the manual. It shows F8 on the display panel board and is not working at all. Please help. Thank you!!
Jun 08, 2008 | Heating & Cooling
Mitisubishi Ducted Reverse Cycle AirConditioner
1.check blower fan motor.if blower fan motor donot work then compressure trip after 5 to 10 minitue.
2.make switch of airconditioner n reset again.
Feb 11, 2008 | Mitsubishi MS12TN Air Conditioner
Panasonic air conditioner problem
This is an easy problem to slove. First remove the filter and clean the evap coil with a bleach type product. Also you will need to wipe the blower wheel and housing down as well. Thx RepairUSA
Aug 25, 2007 | Panasonic CW-C60RU Air Conditioner
Heating & Cooling Logo
101 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
