Question about HP PSC 1410v All-in-One Printer
Printer wont print
Ahh i'm so stressed! I have finals this week and I need to print a bunch of pictures and I just bought a new printer cartridge (both colored and black ink) and I thought I replaced the ink correctly, but it keeps flashing "check print cartridge" I dont know what to do! PLEASEE HELP!
    Master:
  • 638 Answers
TRY CLEANING THE SURFACES WITH MOIST CLOTH THAT CONNECTS WITH UR COLOUR AND BLACK CARTRIDGE CIRCUIT.WISH U SUCCESS.
Posted on Jun 04, 2008
Printer wont produce red on pictures
You need to take out red cart and pull off the tape. It's normally yellow but could be any color. Pull the plastic tape off, and put the cartridge back in, run a few head cleaning cycles and your ready to go.
Sep 22, 2012 | Canon Office Equipment & Supplies
New ink cartridge only last less than two weeks after printing less than 30 pages
I had that model and the same experience. I kept buying ink until I realized I could have nearly bought the printer for nearly the same cost as ink refills, black and color. I also had an HP. Same thing. I finally bought the Kodak 3250. The ads about ink costs was so correct. Many more pages are printed before the "need ink" message is displayed. Buying ink online saves even more.
Mar 27, 2012 | Canon PIXMA MP150 All-In-One InkJet...
HP 8250 Cannot Print - Printer Senses New Ink Cartridge as EMPTY
you need to have authentic hp cartridges,if you bought cheaper,it will not work.
Apr 23, 2017 | HP Photosmart 8250 InkJet Printer
Wont print, says ink is low.. ...but will print
problem could be not compatible with the windows program
most windows vista will not except any printer made before windows vista.
Apr 08, 2010 | Dell 966 All-In-One InkJet Printer
I just unpacked my Brother 4070CDW after moving it from Portland, Oregon to Roseburg, Oregon last week. I had packed it in its original carton, complete with styrofoam, etc. I purchased the printer 9...
Ahh Im from Vancouver, You went backwards moving down there.. lol
As to your printer, I would check very carefully that no styrofoam got stuck in the printer anywhere.
Make sure the print head can move.
Make sure none of the print cartridges have come loose.
make sure none of the print cartridges are empty.
Just some things to try and check.
best of luck.
Mar 09, 2010 | Brother HL-4070CDW Printer
Epson CX 4300 printing problem
This can happen to cartridges with attached print heads. All cartridges are weighed and tested before leaving the factory so lack of ink isn't the problem. It usually has to do with the print head of the cartridge not having any ink to feed it. This happens because cartridges are kept flat or upside down for weeks or months before being used and the ink settles away from the print head. The easiest remedy is to open the box and stand the cartridge upright for a few minutes before using. Then get a damp paper towel, fold it into quarters and sit the cartridge print head down onto it. Hold the cartridge down to the damp paper towel for three minutes. This will help pull the ink out of the print heads, priming them and getting them ready to print. Finally, install the cartridge into your printer and print a few test pages.
Feb 19, 2010 | Epson Stylus CX4200 All-In-One InkJet...
Won't work after installing new ink cartridges
This can happen to cartridges with attached print heads such as HP, Lexmark or Dell. All cartridges are weighed and tested before leaving the factory so lack of ink isn't the problem. It usually has to do with the print head of the cartridge not having any ink to feed it. This happens because cartridges are kept flat or upside down for weeks or months before being used and the ink settles away from the print head. The easiest remedy is to open the box and stand the cartridge upright for a few minutes before using. Then get a damp paper towel, fold it into quarters and sit the cartridge print head down onto it. Hold the cartridge down to the damp paper towel for three minutes. This will help pull the ink out of the print heads, priming them and getting them ready to print. Finally, install the cartridge into your printer and print a few test pages.
Feb 19, 2010 | HP DeskJet F380 All-In-One Printer
My printer was printing pictures great... until we had to change one of the cartridges. Now we're having trouble gettting the pictures to look as good as they did originally. Anything we can do to fix...
you must use the original toner cartridges, if you want to have a best results. Not original toner must be removed from printer. Call to professional.
Dec 17, 2009 | Samsung CLP 315 Laser Printer
My yellow ink ran out and I finally replaced all inks this evening. Now, with all new inks, I keep getting a message that the yellow needs to be replaced. Any suggestions? I've turned off the printer,...
I had the same problem with mine but I bought a refill cartridge instead of a new one and went through three refilled cartridges when I found that it was that I needed a brand new one. For some reason, the HP printers and some other printers need to know that you are using the same brand of ink as the printer. if it is another brand it wont except it and it wont let you print anything! So make sure it is a brand new hp brand ;)
Nov 12, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Easyshare printer dock
ahh..yes..it does indeed...that means that your printer will choke on that..what sort of file is it? what are you printing from(application)
Mar 18, 2008 | Kodak EASYSHARE Printer Dock Thermal Photo
HP PSC 1410v All-in-One Printer Logo
56 people viewed this question
Seeker5211
Seeker5211
