Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
Memory Card Hello, I'm not sure why my camera powers on when the memory card is not in but when I insert the memory card and try to turn it on, it doesnt power up and then when it does, the little green light blinks and then it reads memory card error. Please Help!1
  • Anonymous Jul 20, 2008
    I have related trouble but mine says the card is locked. I am able to use the card on my laptop but not in my camera. The card i am using is a PNY SD.
Look to see if your memory card (your SD card) is "locked".
for some reason, when a "locked" card is in my canon SD1000, it won't turn on at all.
but when i unlock the card and put it back it, it works fine.
Posted on Jul 04, 2008
  • 46 Answers
Memory Card - b32f20a.jpgPowerShot SD630
Camera will not power on with a memory card installed.
1. Try another memory card and contact the memory card manufacturer 2. The PowerShot SD630 requires repair service.
This information sourced from Canon Support Forum page here
Posted on Jun 08, 2008
  • SmarT-Arse
    SmarT-Arse Jun 11, 2008
    To put it simply , canon technicians recommend that you try a different SD removable memory card. .
    Faulty cards will cause the camera to give error indications & power off the camera. Which otherwise works fine when no card installed.
    It's not un-common, particularly amongst cheap generic SD cards , to completely fail to work.
    If the problem occurs with numerous brands/sized SD cards
    then the camera may need to be serviced by a technician.
    Hope this helps anybody in the same situation
How to remove memory card from camera
Confirm the power-on lamp and the monitor are off and open the battery-chamber/ memory card slot cover. Be sure to turn off the camera before opening the battery-chamber/memory card slot cover.
Removing Memory Cards 1 Before removing memory cards, turn the camera off and confirm that the power-on lamp and monitor are off. 2 Open the battery-chamber/memory card slot cover and press the card in to partially eject the card. 3 The card can then be removed by hand. Do not attempt to remove the card at an angle.
Insert the memory card.
4 Slide the memory card in correctly until it clicks into place. 5 Close the battery-chamber/memory card slot cover.
Oct 08, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Hi - I am getting an error message when i switch on my Sony Cybershot dsc t9 saying access and then it flashes format error C13.01 - can you advise how to resolve?
It might be due to a bad contact of the placed memorycard.
1. Pull the memorycard out and in the camera several times and retry.
2. If not OK, format the card in the camera. If that does not work, format it in the computer.
3. Try another memorycard and recheck.
Sep 04, 2011 | Sony Cyber-shot DSC-T9 Digital Camera
Panasonic DMC-TZ3: one day it's working fine, next it won't power on. Tried the "Power Saver" reset technique posted ... didn't work. Battery is fully-charged.
Try removing the battery and the memory card for 1 minute then return them back. Make sure the battery is inserted properly. If that didn't work, try turning it on without the memory card.
Did you get any error message when you try to turn on your camera?
Sep 02, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Camera says out of memory won't let me take pictures. i cleared all the pictures out and still cant take pictures. What do you think the problem is?
I'm assuming you are trying to use an SD card in your camera and not the internal memory. I suggest you format the memory card if you are sure there is nothing on the card. Formatting the memory card deletes everything on the card and sets it up with a file system that your camera recognizes. Follow these steps to format your memory card using your camera. 1. Turn camera off 2. Insert memory card 3. Turn camera on 4. When the memory card is inserted in the camera, the [Format card] option appears in the setup menu 5. Choose Format to format the entire card. Don't choose Quick Format 6. Wait until your card is formatted
After formatting your memory card, try turning your camera off and on and you should now be able to take pictures to your memory card.
P.S. If you remove your memory card you can choose Format Memory from the setup menu to format the camera's built-in internal memory
Sep 01, 2011 | Nikon COOLPIX L5 Digital Camera
The camera beeps when we put the card in.
The images you take with your PDC 640 camera are stored on a removable 3.3V SSFDC or SmartMedia 2 MB memory card (also available in 4 MB and 8 MB). Note: You must insert the memory card before you can turn on the camera.
If camera beeps is enabled, the camera beeps if the card is not installed and displays the [ ] message on the Status panel.
To insert the memory card:
1. Make sure the lens cover is closed (the power is off).
2. Open the memory compartment on the side of the camera.
3. Insert the memory card into the slot (gold side of the card facing the front of the camera).
Make sure the card is pushed firmly into the slot. Note: The camera prompts you to format the memory card if it is not formatted. The camera displays the format menu on the LCD viewfinder. Press the button next to Format.
4. Close the memory compartment cover.
If you can, try using a different memory card. Else, your memory card contact terminals inside the camera may have become worn, causing the camera to not recognize the card once it is inserted.
Mar 13, 2011 | Polaroid PhotoMax PDC 640 Digital Camera
How do I enter my sandisk into my kodak easyshare camera?
  1. Open the camera memory card door on the side of the camera.
  2. Insert the camera memory card into the slot with the connecting end of the card facing the camera, and the lip on the card facing toward the front of the camera. CAUTION: The camera memory card can only be inserted one way into the camera. Forcing the card in the wrong way may damage your camera.
  3. Push the camera memory card all of the way into the card slot and then close the door. Make sure that no dirt is present when you close the door.
Hope this can help you.
Kind regards
Nov 17, 2009 | SanDisk 2GB microSD Memory Card
16G Memory Gets "Memory card Error Please Check Memory Card"
You may try to format the memory card and then try again. If needed, you can use a camera photo recovery tool to recover photos from memory card.
Card Recovery Software Free Download
Apr 10, 2009 | Panasonic DMC-TZ5 Digital Camera
Memory card
Hello Sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from or
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Oct 25, 2008 | Olympus FE-220 Digital Camera
    Canon ixus 400
    try another memory card may be the card has a short circuits that why the camera is power up when you inserted that card...
    Aug 22, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
    Insert memory card, LCD turns lank
    Hello Rach326, try with a new SD card. If it does not help contact the nearest authorized dealer/service. Best regards, Arpad
    Jan 12, 2007 | SeaLife Reefmaster DC310 Digital Camera
    Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
    320 people viewed this question
    Top Canon Cameras Experts
    old marine
    old marine
    Are you a Canon Camera Expert? Answer questions, earn points and help others
