Question about Crosley 0187SST Turntable
CROSLEY CR249 KEEPSAKE USB TURNTABLE STOPPED SPINNING
I'VE HAD IT FOR A COUPLE MONTHS, WORKED FINE UP UNTIL YESTERDAY... IT TURNS ON BUT DOESN'T SPIN, THE MOTOR DOESN'T TURN, THERE IS NO SOUND WHEN I RUB THE NEEDLE, THE BELT IS INTACT, ARM IS FINE, WHAT COULD BE THE PROBLEM? HOW CAN I FIX IT?
  • 1 more comment
  • dianatown9 Nov 26, 2008
    usb turntable same one stopped spinning after couple months.
  • Anonymous Mar 14, 2009
    Doesn't spin.
  • Anonymous Mar 21, 2009
    stopped spinning
Midwest-tech
  • 243 Answers
SOURCE: crosley cr249
are you using a standard microphone jack? like a 1/8" if so this is most likely the problem. also what program are you using. i recommend audacity.
Posted on Jun 19, 2008
freetek
  • 5568 Answers
SOURCE: new crosley CR249-GR "wow and flutter"
I see your message isn't new anymore but Crosley does have a website with warranty and support info:
Crosley Radio
Posted on Aug 15, 2009
  • 8404 Answers
SOURCE: Just got our Crosley cr249 turntable for Christmas
Increase the pressure on the needle.
Posted on Dec 26, 2009
STYLUSCITY
  • 271 Answers
SOURCE: Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Posted on Nov 11, 2011
djtatty
  • 417 Answers
SOURCE: CROSLEY CR249 KEEPSAKE AUX TURNTABLE STOPPED SPINNING
if it's belt driven, then your belt has fell off.
Posted on Jul 10, 2012
Brand new crosley keepsake that spins too fast even at its slowest speed setting (33 1.2). Can I fix or should I send it back for repair?
If it is belt driven it could be that the belt is not moving to the smaller diameter pulley for the slower speed. But the unit is new so I would just return it for an exchange at the store it was purchased from. It is new - the heck with a repair - just get another one!
Dec 25, 2015 | Crosley Audio Players & Recorders
Why my computer not reconize the crosley usb turntable
The turn table is ANALOG and your PC is DIGITAL.
Jul 08, 2014 | Crosley Keepsake USB Turntable
Why is my brand new crosley turntable keepsake hunter skipping tracks?
The turntable may not be level. Also, the stylus could be damaged or defective. The stylus pressure may not have been set correctly in production or may have been affected by shipping.
May 05, 2014 | Crosley Keepsake USB Turntable
Crosley CR249 warped table
Sounds like you need a new platter. Has the platter worked OK before or has it always been like this?
I suspect you might have to contact Crosley to see who supplies parts.
Jan 10, 2013 | Crosley CR249TA Turntable
Jul 07, 2012 | Crosley 0187SST Turntable
My cr249 model record player is turning on, but not spinning. it's been working fine until today, what do i do?
The chances are that the drive belt has either broken or come off the pulleys on the underside of the turntable platter and the motor.
You will need to access the underneath of the turntable to do this.
How you do so varies from one model to another - some you can just lift the top plate off the wooden base, others you will have to turn the whole thing upside down and unscrew the bottom.
With some turntables you lift off the rubber mat from the platter to expose a couple of little holes through which you can access the drive system.
If the belt has not actually broken you should be able to put it back onto the pulleys. However, the fact that it has come off indicates that the belt has stretched and you should replace it. There are plenty of suppliers on the internet (Amazon is usually worth a try) where replacements can be found
Feb 01, 2011 | Crosley 0187SST Turntable
Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Jan 12, 2010 | Crosley Audio Players & Recorders
New crosley CR249-GR "wow and flutter"
Crosley Radio
Jul 14, 2009 | Crosley CR248 Turntable
Suitcase Turntable stopped turning
Check the drive band- it may have come off the pulley. But if it is a new purchase then perhaps it should go back to the vendor
Jul 07, 2007 | Crosley 0187SST Turntable
Crosley 0187SST Turntable Logo
222 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
