Question about Frigidaire Refrigerators
My freezer is too cold, now frig part is way too warm, we unplug it, defrost the freezer, then it's ok for a week, then it freezes up again, so on......... help....... thank you! =)
  • 1,122 Answers
Posted on Jun 04, 2008
Unplugged frig overnite once I plugged back in made a gurgeling sound whenever I opened the door what would that be?
Usually that is caused by a bad defrost heater thermostat or defrost timer. Failure to automatically defrost is the cause of freezing up.
If you don't feel up to doing the work yourself you should have an appliance repair shop look at it.
The gurgling is caused by water in the catch pan under the fridge. When you defrosted it some of the water made it into the drip pan (and maybe overflowed onto the floor). The fan inside the compressor area under and behind the freezer may be splashing in the excess water in the drip pan. This by itself is not a real problem since it is designed to automatically evaporate the water drained during automatic defrosting, but the excess water and potential overflow onto the floor can become a problem.
Mar 10, 2017 | Danby DFF8802 Top Freezer Refrigerator
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
I have a side by side that frosts up in the middle back ofthe freezer and the frig part gets warm. I have $200 in it and still no resolution. Bought new in June '04. I defrost for 24 hours, turn it on and...
If you can locate the defrost timer and advance it to the defrost cycle you should be able to see the defrost elements glow behind the rear panel in the freezer. Do this before the freezer gets too frosted up. If you can't see the glow then there is a problem with the defrost heaters or the defrost thermostat. Unplug the frig and remove all the racks in the freezer. Remove the screws holding the rear panel on. Locate the two heaters and check the resistance. IF open, replace heaters. IF ok check resistance of the defrost thermostat. IF open when cold, replace defrost thermostat.
If replacing heaters always replace defrost thermostat at the same time. It will save you doing so at a later date
Dec 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge works freezer isnt getting cold enough to freeze
check to see if you have frost on the back panel of the freezer if so then defrost the unit and if your able to find the failure of the defrst heater or defrst thermostat,or the defrost thmer more than likely its the mother board since its a general electric frig but if you manually defrost until a repair tect can come then it will run normal until it frost up again but before you call the tech out make sure you have the frost on the back panel otherwise he'll make several trip trying to solve the problem with the frig unless its the defrst heater
Sep 08, 2009 | Amana Refrigerators
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Fridge side warm but the freezer side cold
it sound like your defrost heater or defrost sensor in the freezer is not working,do you know if it is going into defrost every 8 hours?if you have an ohms meter you can check there parts no problem ,let me know if you want to tackle this and i will help-mike
Nov 02, 2008 | Maytag MZD2752G Side by Side Refrigerator
Refrigerator not getting cold
hello, my refrigerator got the following problem; it works fine at the freezer but there is no cold in the frig, when i unplug it from the wall connection and after few time connect it again, it start working, after few hours, the refrigerator stop, the freezer is fine and very cool,but the frig is not cool and the refrigerator do not start working again, even after the freezer gets warm.Please i hope you can help me with this problem.
Sep 03, 2008 | Refrigerators
Warm frigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Jun 14, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Have Maytag side by side refrig. mod. MSD2556AE and after running several weeks the food compartment starts warming up but freezer stays cold. Can turn frig. off overnite and will work ok for several more...
the notorious Adaptive defrost did it again (lol) verify the condition of the heater putting a voltmeter on the "beeping" feature if it beeps its good.
Replace the Adaptive Defrost board and defrost thermostat and should work like a charm
Apr 26, 2008 | Refrigerators
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
48 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
