Question about Husqvarna Viking 1
Reverse sewing button stuck HELP!!
Model 6430 Viking has the reverse button located in the center of the stitch length dial. It is firmly jammed in the reverse position causing the machine to sew ONLY in reverse.
When I pull firmly on the button it will sew forward but goes back to reverse when I let go...It seems to be attached to a spring, inside. Possibly the top knob has not been installed correctly????
  • clutterbug Jun 15, 2008
    I think this got me on the right track...seems to be a technical problem rather than just frozen. the machine is clean and perfect, physically but the instruction book leaves a lot of unanswered questions.
    I appreciate your help so much.
    Sherry
  • Anonymous Mar 30, 2014
    Brother ps 55 is stuck in reverse can't get it to sew forward
  • 323 Answers
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
Posted on Jun 05, 2008
  • Linda Stone Aug 28, 2013
    I tried this but it did not work. When I set the knob to 0 it was in as far as it would go.
Viking/Husqvarna 5710 sewing machine is stuck in reverse. Reverse button isn't stuck, but doesn't pop out by itself anymore. Stitch dial isn't in between stitches. Put wd40 in the insides, didn't help
Uh-oh. Don't use WD-40 on your machine... WD-40 becomes sticky with time and will seize the mechanics...
Wondering if there is a spring under the R button that perhaps is broken or collapsed.
Apr 27, 2017 | Sewing Machines
Viking 2000 6430? sewing machine, only sews in reverse.
Your stitch length dial is stuck. Your machine is in need of oil. If you open the back of your machine and see the bit that moves when you turn you stitch length dial. oil that bit and warm it with your hair dryer. It should become loose. It take a bit of warming and working the oil into the machine. You have to repeat this process a few times.
I do have the service manual at sewingnz@gmail.com
Jan 25, 2010 | Husqvarna Sewing Machines
How do I reverse stitch on a singer 362 fashion mate model
The large knob in the center of the stitch length dial is a button, push it in to reverse stitch. Hold in as long as you need to reverse stitch, then release to resume regular stitching.
Jan 09, 2010 | Singer Sewing Machines
My model 210 is stuck in reverse. Can you help?
The only thing you can do to possible free the mechanism is to turn the lower dial back and forth a bit, from the position where it is in permanent reverse to the numbered area on the dial. Make sure the selector is not on the buttonhole position. That machine doesn't really have a history of that issue but anything is possible, especially if it has sat for awhile and not been used. If moisture was present where it was stored, it's possible the feed linkage is slightly rusted and simply stuck.
Oct 07, 2009 | Husqvarna Viking 1
Husqvarna Model 6360 reverse button stuck
This problem comes about due to lack of useage usually. If the machine has been sitting for some time the grease inside hardens. The stitch length regulator, the pattern selector and the buttonhole mechanism could all be contributing to your problem. To fix it properly all three dials should be remove from the machine, disassembled cleaned, assembled and oiled lightly with a teflon lubricant. Since so much is removed from the machine doing this job, every setting in the machine is checked and or reset. It's a major overhaul and costs about $350 and only a handful of Viking Techs in the country can do it.
Sep 19, 2009 | Husqvarna Sewing Machines
Viking sewing machine model 6430 will only sew backwards
Th cam stack gears have gummed up on you you can try getting the back cover off along with the side and soaking the machine down with wd-40 and running it while forcing the reverse button in and out if it breaks free try and soak up as much of the wd-40 as you can and then oil anything that moves. I know this may be discouraging but viking no longer supports this machine and you might be better off taking it to an older viking dealer for help.
Jul 14, 2009 | Husqvarna Viking 1
Reverse stitching on a singer 514, HELP!
In the center of the stitch length knob (at the right side of the machine) is a button. You would push that button in to get the machine to reverse.
May 08, 2009 | Singer 7442 Mechanical Sewing Machine
The mechanism requires lubrication from the back, would be best to have machine serviced.
Jun 30, 2008 | Husqvarna Viking 1
Sewing Machines Logo
1,071 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
