Question about AudioBahn AW121T Car Subwoofer
Audiobahn sub settup
Hi ive just bought a audiobahn aw121t sub for my car,im just wondering how i should set it up.i have 3000watt silver sonic 4 channel amp (3000 is the peak power), i have mi kenwood 300 watt max 6x9's wired to channel 1&2 and im going to wire my sub to channels 3&4amp.im not sure how much gain i should give my sub exactly becuse i know you can damage them by under or over powering them.as i know from experiance that ive blew a sub up before.im just wondering can one ef them electrical tester things test how much watts are going to a speaker? can any1 advise me on this please thanks jay
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
Audiobahn.com has a tech support with diagrams on thier website check it out
Posted on May 11, 2010
I have two audiobahn aw1206t 12in. subs in a box hooked to a 100.1 american bass amp its 1000 watt mono block. i also ran a capacitor due to my lights dimming. but for some reason my amp keeps kicking over...
This could be caused due to the impedance load being to low. Your amp is stable to 2 ohm load however its very possible that you have your subs wired to a 1 ohm load that would cause the amp to go into protect mode. The subs you have are dual 4 ohm voice coils and would need to be wired in series/parallel. I've included a link that will show you how the subs should be wired.
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2-DVC-4-ohm-mono-low-imp.jpg
May 16, 2011 | AudioBahn AW1206T Car Subwoofer
Hello..im trying to find a diagram on how to wire my subs down to 1 ohm..i have 2 12 in. Audiobahn alum12n..they are currently runnimg at 3 ohms on a hifonics 2500 watt 1 channel amp that only supports 1 2...
Hi, if you wire all voice coils in parallel, you will get down to 1.5 ohms. That is the lowest you can go with these 2 subs. Just hook the amps' positive to all 4 positive speaker terminals and the amp negative to all 4 speaker negative terminals. Please let me know if you have more questions, and thanks for using FixYa.
Mar 22, 2011 | AudioBahn Car Audio & Video
I just bought an Uudiobahn AW121T and I am trying to figure out the best and loudest box for the sub
ported pro boxes are all ways the best way to go make sure they are ported get the blk plastic ones they are the best in the pro line
Nov 17, 2009 | AudioBahn AW121T Car Subwoofer
I have a audiobahn a400t and im running 2-12''jh45 mtx jackhammers the speakers are wired in parallel stabel @ 2or1 ohm. the speakers are in a ported box. how do i run my wires to my hook these up right to...
Hello rattle822,
A pair of JH4512-04's can be wired to 2 ohms if the subs themselves are paralleled. There's only one voice coil and it's 4 ohm. If wired in series, the final impedance to the amp would be 8 ohms. They cannot be wired to 1 ohm.
In bridged mode, your 4-channel amp is only stable down to 4 ohms. You can bridge 2 of the channels to provide a relatively low 200 watts RMS X 2. The best power solution for your subs would be to bridge channels 1 and 2 and wire one sub to it. Likewise, bridge channels 3 and 4 and connect the other sub. If you connect both subs in parallel, the impedance will be too low causing the amp to overheat and possible fail.
As for the settings: Low pass filter on, crossover somewhere between 80-100, input levels to match your receiver, and bass boost to your personal preference.
Hope this helps.
Aug 13, 2009 | AudioBahn Car Audio & Video
I have 2 AW1206T's how do you know when their blown?
when a sub is blown it usually makes a scratcy or grinding noise if you push the sub in but if its blow it realy wont make much of a sound so it sounds like your voice coil is going out you will want to get this looked at quick or it can get expensive...i had one were it was cheaper to buy a new sub rather than fix it. it can also just be it disorting from too much power. i would never go over the power limit when dealing with 3000 watts, that can get realy expensive quick
Apr 12, 2009 | AudioBahn AW1206T Car Subwoofer
Just wondering ..
square port (slot loaded) vented box tuned at 33 - 38 hz is the loudest deepest bass you can get
Nov 18, 2008 | AudioBahn A2801Q Car Audio Amplifier
Best way to set up my car sound system???
This is a multi-tiered question. First of all, you're going to want to run the subs at a 2ohm load (if the amp is capable) to get the maximum power from it. Use the 5.0.1 for the subs only, that's what it's designed for. Run the cap in conjunction with only the sub amp as it has the largest power requirement. You can not link the two amps to increase output as they are first of all different amps and second of all not designed to run that way. Some amps are but they must be identical.
Set the crossover on the sub amp probably no higher than 80Hz (I like it lower than that but that's a personal preference) and turn the sub-sonic filter off.
Now, one of the most important things about a subwoofer is it's encosure. If it's a properly built box designed for your subs specifically then you should be ok. You dont' specify if it's ported or sealed etc. That would be helpful to know as well as it's approximate size (air volume).
The head unit can also have some bearing on how things sound, as I recall the Sony X-Plod units are fairly decent for the price and if set up properly should sound ok.
If you need further assistance please provide a little more info about the sub enclosure etc.
good luck!
Oct 08, 2008 | Car Audio & Video
I got same problem as you
the player dosent realy give power to the subwolfer its more for the speakers. it should be the amplifer that is connected to the subs, also mite want to chek the settings on the amp
Jun 06, 2008 | AudioBahn AW1206T Car Subwoofer
Wiring subs
audiobahn.com can help you with the free diagrams under tect support
May 03, 2008 | AudioBahn A4075HCQ Car Audio Amplifier
AudioBahn AW121T Car Subwoofer Logo
295 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
