Question about Dell Latitude D800 Notebook
Dell D800 Startup problem
Notebook trys to turn on and then shut off with plug in. Is this a battery problem.
  • 458 Answers
No, it is a DC Power Jack issue,,,it sounds like the +positive Post on the jack has wiggled loose from the mainboard..you can tell by pluggin in the AC Power cord and wiggling the plug if you see the power light coming on and off.. it's a Loose DC Jack,
If it doesnt do as i just described, and it won't power up at all, it is the motherboard.. and will need to be replaced.. Another Possibility is that it is Stuck in Sleep Mode.. Hope this helps you ..
Posted on Jun 03, 2008
I Have a Dell Latitude D800 and it's plugged into power. when i hit the start button it lights up a couple of lights on the keyboard, they go out after a couple of seconds and then nothing happens?
Is the battery charging? and is the power adaptor properly plugged in? If yes then it's probably a faulty PSU and you will need to phone DELL for a replacement/repair.
Sep 06, 2010 | Dell Latitude D800 Notebook
The D800 says it is docked or running on battery, push F1 to shut down. This happens at power on and with AC power adapter being used. Have tried other power adapter(90 watt) and no docking station being...
There's a "slide-away" coverv on the bottom of the laptop, where the docking-station's adapter would connect. Manually slide the cover, and inspect to ensure that there's nothing stuck there that is "tricking" the laptop into claiming that it is docked.
Apr 16, 2010 | Dell Latitude D800 Notebook
My Dell Latitude will not turn on. When I press the power button it will come on for 5 seconds then go off. Can anyone help ?
Plug in the AC power cord, remove the battery, and try powering up. Anything? Any lights?
Remove power cord, hold in the power button for 30 seconds, then try plugging it in again and powering up without the battery. Any change?
Mar 13, 2010 | Dell Latitude D800 Notebook
Dell Latitude D800 Wont Power Up
Check the status of the battery directly from the battery. Turn the laptop over and on the batter is an battery indicator button and lights to tell you if it's charged. If it is charged then you have an problem internally. Wiggle the tip of the power cord at the laptop connection to see if it is loose, if it is then you have an loose connection on the motherboard which can be fixed by an experienced tech that can solder or the motherboard will need to be replaced.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | Dell Latitude D800 Notebook
I have a dell D800 it won't power on at all the battery show full
Try removing the battery and plugging it into the wall. then turn it on, if it turns on your battery is bad or connected improperly.
Dec 11, 2008 | Dell Latitude D800 Notebook
D800 will not even boot
Okay, I had that problem with my HP less than a minute ago.
Maybe it is the same problem. See if the battery light comes on. Press the power button again and again if it doesn't start, for some time. It may show the boot screen and hang. Now, the battery must be charged. Shut it down directly and switch the AC off.
Now, switch it on and see if the battery light comes on. If it does, it is the same problem as mine. Now, turn the PC over and remove the battery carefully. There may be switches for that.
Now, plug in the AC and start it without the battery in. If it does, you're done. Now, plug in the battery again.
Nov 28, 2008 | Dell Latitude D600 Notebook
Dell D800 Problems!!
Could be a short in the battery, Dell batteries are notorious for this. Try running it without the battery for a while. If the problem goes away, then it'e tome for a new battery.
Jul 05, 2008 | Dell Latitude D800 Notebook
Latitude D800 wont boot
ok now it sounds to me the power pack on the back has shat its self so ufourtanetly u need a new one if u still have a valid warrenty ring dell or go to their web site at www.dell.com and they will happiley help u there number is also their but if u dont have warrenty go to their website and see how much it costs for a new battery but see a friend who has a dell laptop and plug in the power cord it might be your power cord not your com or battery so give it a wirl and if u have any problems email me at mid.nightclub@hotmail.com
Dec 31, 2007 | Dell Latitude D800 Notebook
Dell Latitude D800
This may be SpeedStep slowing the processor to save battery life. It speeds up when it is needed.
Dec 13, 2007 | Dell Latitude D800 Notebook
Dell Latitude D800 Notebook Logo
111 people viewed this question
Alun Cox
