Question about Dell Inspiron 2200 Notebook
Dell inspiron 2200 would not start
I have tried it with and without the battery and it will not start. The adaptor works fine. i cheched the plug on the computer and that is fine too without any break inthe posts. I would appreciate your input in this probplem.
Thanks
  • Anonymous Jun 13, 2008
    Yes i have the same problem after 29 minutes or so the machine start to say conect the adapter cos the battery no charge and you will lose date and click goes off and try to restar and no ultil disconet the ac and reconet and restar the laptop Thanks for any hint
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    hmmm...so..it's not doing anything..methinks you have a truly unhappy motherboard..under warranty, by chance?
  • 191 Answers
If your ac adapter is working fine with similar other system. the only thing to be replaced will be the systemboard. if you are in United States you can call 1-800-624-9896(United States).and if its not or you r not sure either logon to http://tinyurl.com/3ykjjr
its a dell website . you can punchin your system's service tag and can get info regarding every Dell system.
and if your system is out of warranty you can call 1-800-288-4410 EXT-7260623. its for Dell out of warranty repair. they will pick up your laptop and will throughly check it. what ever part needs to be replaced they will let you know.
if you can provide me your service tag i can arrange a call back from Dell technical support.
Posted on Jun 04, 2008
I bought a non dell battery for my inspiron 6400 note book but it wont charge,looking for a solutions,dell batteries too expensive john dublin ireland
the laptop will work with just adaptor plugged in and the battery removed.Try only adaptor plugged in.
Hoping this will work
thanks
Jan 05, 2011 | Dell Inspiron 6400 Notebook
My dell mini inspiron doesn't work when i turn it on; it starts but then nothing, it is obvious that it is on but it is only a black display on the monitor. What could be the problem?
You can switch it OFF and remove the battery.
Wait for 5mins, Connect the battery again, Also connect the Power Cable to the Laptop.
Try to switch it ON, It should work.
With regards
FIXYA team
**Please post your feedback and Vote if the problem resolved as per your satisfaction**
Oct 08, 2010 | Dell Inspiron Mini 10 Notebook
I was working on my laptop - it mysteriously shut down.
remove the battery on the system then unhook the adaptor press and hold the power botton down for 10 seconds this is to power drain *********** board...... then conenct the adaptor without the battery power the system on if it powers on leave it on for a minute or 2 then shut it down again inset the battery turn system back on if it does not turn on with battery something is wrong with the system motherboard conflicting with the battery in it call dell for options if in warranty
Jun 05, 2010 | Dell Inspiron 2200 Notebook
Inspiron 1300 PC Notebook: I can not start my Dell Inspiron 1300 , when i plu...
adapter should be fine..if light comes on adapter should be good...leave battery out of the system...just use adapter and when starting system up tap f12...see if u can see this menu..if not try a external monitor to see if u can get a image..if so run the diagnostic..if still no image or no external monitor it may be a mb
May 06, 2010 | Dell Inspiron 1300 Notebook
Ac adapter will not charge my computer
If the laptop will run from the adaptor, then the adaptor is probably fine. That being the case, if the charge light flashes when the adaptor is plugged in, the battery is faulty. No charge light on an otherwise working system is probably the battery charging circuit in the laptop.
May 17, 2009 | Dell Inspiron 1525 Laptop
Inspiron laptop Battery won't charge
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Apr 06, 2009 | Dell Inspiron 9400 Notebook
Computer doesn't accept power
check the metal post inside the power jack connection. very carifully try to wiggle the metal post and see if it moves or if its there at all. if the post wiggles, it is probably broken and needs to be re-soldered...only someone who knows how to do that should as you could damage the board trying yourself.
also try plugging it in without the battery.
do any lights come on at all when its plugged in or power buttons are pressed?
Mar 28, 2009 | Dell Inspiron 2200 PC Notebook
Wont power up
the vr\ery first thing what u have to do is that disconnect the ac adaptor and take the battery out of the computer and then press and hold down the power button without the battery and the adaptor for one minute and then connect the ac adaptor and put the battery back in and then try and turn it on and what u can do is that try and turn on the computer only with the battery and then take the battery out and try and turn it on only with the adaptor,and then what u can try is that try with the different adaptor having same configuration,and try and connect the ac adaptor into the different wall outlet....good luck
Jan 28, 2009 | Dell Inspiron 6000 Notebook
Can i run the laptop without a battery in it.plugged in with ac adaptor only
Yes, you can.
Laptops can run without battery with the AC, and it's fine, does not harm.
But however, I do not recommend you removing the battery and using the notebook with AC adapter only. The notebook is designed to be portable and with battery plugged in. In addition, using AC adapter only may cause the system to overheat since it is getting and using direct power from the power outlet.
Sometimes when you take out the battery your laptop doesn't work.
But that issue usually is related with some problem with the connectors of your motherboard.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 17, 2008 | Dell Inspiron 2200 Notebook
Laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Dell Inspiron 2200 Notebook Logo
Alun Cox
