Question about Brother CS-80
Buttonholes The thread keeps getting tangled underneath when I try to use my buttonholer. I have checked and rechecked everything and I am sure i am following the directions. Help!
  • bumblebabymo Jul 31, 2008
    I'm having the same trouble. I've checked for tangled thread & scratched bobbins - that's not the problem.
    It will sew one side and get 'stuck' on the bar at the bottom of the button hole and not sew any farther.
  • 66 Answers
Please try this take out the bobbin and filp it around the other way and see if this helps
Posted on Jan 30, 2009
What is wrong with machine I have tried all the instructions and it makes a horible button hole
most sewing shops/fabric shops that sell or service machines have people who are willing to show you how to do it regardless of the make of your machine
there is a knack to the job that is difficult to print in instructions
Sep 02, 2015 | Sewing Machines
Buttonhole stitch problem
Try setting it to for a longer/shorter stitch length, as the case may be.
Mar 21, 2015 | Sewing Machines
Singer Advance: Buttonhole getting stuck and not advancing fabric
make sure the buttonhole lever is pulled down
make sure to use the right needle for the fabric being sewed
make sure the to thead has not come off the thread take up lever
also could be a problem with the feed dogs, look in the manual
and see where the feed dog lever is and check to see if it's in the
up position, if the feeddogs are in the up position then the feeddogs need to be checked to see if they need to be adjusted.
Dec 17, 2012 | Sewing Machines
E1 flashes on the message window of my brother sewing machine
Brother Computer Codes
  • E1: Make sure the presser foot is lowered before sewing.
    E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
    E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
    E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
    E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
    E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Oct 03, 2012 | Brother CS-6000
I get a E4 code whan I turn on machine and I can't figure out what is wrong.
Brother Computer Codes E1: Make sure the presser foot is lowered before sewing.
Sep 21, 2012 | Sewing Machines
I have been trying to make a buttonhole but the top thread keeps breaking and the threads are all snarled up underneath the material. what am i doing wrong? i have a brother ls2125 machine maria
Firstly have you interfaced the material that you are buttonholing on? You will never get a good buttonhole otherwise. Also start each new project with a new needle matching the size to the weight of fabric. Good guide available here http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/
Top thread breaking is usually because the tension is too tight or the thread is catching somewhere in the thread path from the spool to the needle. Also check that the needle doesn't have a burr on it somewhere, or is blunt.
Thread snarls underneath the fabric is usually caused by top thread tension issues. You will need to rethread top and bottom and CHECK that the thread is in tension correctly. So lower the pressure foot and pull the top thread just before the needle - does it feel hard to pull? If not, then the thread is not in tension. Rethread top again, checking the tension dial is set to 5 and the thread is correctly pulled between the tension discs. And always hold the two thread tails at the back of the sewing area as you start each new seam to avoid these being pulled down into the bobbin area and getting jammed up.
So, rethread, test sew and get the top tension sorted, a nice straight stitch happening, then try the buttonholing sequence again.
Apr 26, 2011 | Brother LS-2125 Mechanical Sewing Machine
Tangled thread
Ask at the shop where you bought it, take a sample and arrange a time to meet & discuss if it is under warantee.
Jul 30, 2009 | Brother CS6000i Computerized Sewing...
Buttonholer on Singer 2639 sewing straight ahead
set you machine for "zigzag" then: try your buttonholer again.
Also; the thread tension can be adjusted by a small screw in the side of the bobbin for the bottom loop of the stich or, the tensioner on the side of the machine head for the top loop
May 28, 2009 | Singer 2639
Brother Super Galaxie 2100 Buttonhole lever not working
I have a problem with my CS 8150 which sometimes tells me to lower the pressure foot even though I had already did it. What clears the problem for me is that I eject the thread cassette and re-install and I can go ahead and sew. Try that to see if it will quit telling you to pull down the lever.
Sep 03, 2008 | Brother CS-8150 Computerized Sewing...
Buttonhole instructions needed for Singer 7422 Advance
These are the exact instructions from the Manual. 1. Select one of buttonhole patterns.
2. Replace the presser foot with the buttonhole foot. (Install presser foot with little red mark towards the front)
3. Insert the button into the buttonhole foot. (the part located in the back crescent shaped)
4. Lower the buttonhole lever (to the left of the needle) so that it drops down vertically between the stoppers A and B.
5. Carefully mark the position of buttonhole on your garment.
6. Place the fabric under the foot. Pull out the bobbin thread underneath the fabric to a length of about 4 inches to the rear.
7. Align the buttonhole mark on the fabric with the mark on the buttonhole foot, and then lower the buttonhole foot.
8. While holding the top thread, start the machine.
*Sewing will be completed automatically.
9. When sewing is finished, use a buttonhole opener to open up the frabric in the center of the buttonhole. Be careful not to cut anyt of the seam thread.
I hope this helps.
Mar 28, 2008 | Singer 7422
Brother CS-80 Logo
87 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
