FixYa.com
Tags:
Toshiba 50H72 50 in. Rear Projection Television
Toshiba 50H72 has color bow problem, how to fix?
posted by dalewilcox on Jun 03, 2008
I have a 50H72, seems to need the convergence board fixed. I called PTSCorp (board replacement company) and got quote for $51, I can send them my board and they will fix it. However after reading some posts on this type problem I'm not sure if I should have the board fixed or try to fix the IC's myself. I read about some problem if you replace the board because it has some setting loaded into it and if you get a new board you will loose those settings and its hard to reconfigure. Is this true? Could someone explain? I rather just send the board off for repair but not sure if that's a good idea? Also does anyone have a picture or instructions on getting to the board and removing it on a 50H72?
Thanks for your help, Dale
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Projection Televisions problems?
Toshiba 50H72 50 in. Rear Projection...
50H72 Toshiba picture wiggle at...
Hi, I read some of your post on... Answer This...
TV Remote Control Problem
TV remote control is very slow... Answer This...
PICTURE HAS HORIZONTAL TEARING....
the piture has a jittery... Answer This...
shuts off
shuts off on its own and red... Answer This...
Last night the TV and picture... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
