Question about Samsung SH-S182 DVD±RW Dual Layer Burner
Burning to cd
Each time i try to burn a disc i get the error message 4280 and the disc is rejected
  • lidya haile Apr 18, 2009
    i donot know how to burning cd
    please tell me the procedure how to burn cd
    President:
  • 1,257 Answers
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Posted on Jun 03, 2008
Ok - same itunes error 4280 - but not using a Sony CD and the drive will burn an MP4 dvd - just not CD-r or -rw discs Microsoft Windows Vista Home Premium Edition Service Pack 2 (Build...
Search Results Occurring during an attempt to burn a cd in iTunes, the Burn Error 4280 pop up in a message and is most often a result of the wrong speed of burning in the iTunes program, an issue with the cd drive, or incompatibility between your computer and the cd burner.Sep 9, 2011
Solve Burn Error 4280 with Simple Steps - ErrorAnswers.com
erroranswers.com/pc-performance/solve-burn-error-4280-with-simple-steps/
itunes error 4280 Google Search
Mar 14, 2017 | Samsung SH-S182 DVD±RW Dual Layer Burner
I get an error message to use a blank or erasable DVD
I would try simply copying one of the already completed discs using a stable and well known burning program like Nero. Programs like Pinnacle can be very temperamental when exporting their projects to disc.
Jul 19, 2010 | Gear Head 8XDVDEXT DVD External Slim...
Whenever I try to burn a cd it fails and comes up with an error 4280 message how do I fix this problem
Hi! I had the same problem before when writing files to disc. What i did was to lower down the speed ex. from 16x to min or from 4x or 8x to 16. That should also fix your problem.
Jun 14, 2010 | Sony DRU 510A DVD±RW Burner
Cd disc drive on Toshiba laptop pops open when i try to burn disc
Please make sure you have enough space available on your disc.Please switch to a new empty disc and let me know if you get the same error.Before trying with a new disc restart your laptop and then burn with the new disc.
Thank you.
Aug 13, 2009 | Toshiba Satellite Pro S300M-S2403 Laptop
Burning a disc
please 1st you install a burning software and then burn you disc.
Aug 11, 2009 | Apple iTunes
I get an error 4280 when I attempt to burn an audio cd
Apparently a common error; if you google error 4280 you'll get several different versions of what is happening. Some blame the Sony CD's other blame Dell, HP, etc...like I said there is a long list so I didn't want to pick out just one, it depends on your Computer type, combined with the CDs..so go ahead and take a look. Personally from reading some of the fixes I came up with; don't use Sony disc and run at 16x to get rid of the error. Hope this helps..
Please rate this solution.
Mar 18, 2009 | Computers & Internet
I keep getting cancelled CD burns off of iTunes and Windows Media
I had that error befor I was burning with Memorex's 52x CD-R... when I switched to a Maxell's CD-R, the error was gone! And I left the burn speed at 'maximum'. It did it in about 4minutes. Good luck!
Dec 26, 2008 | Computers & Internet
Burning cds
check there must be option on the burning software , where you can disable these warnings, by the way the cd's are burning successfully or not ?
Nov 01, 2008 | Maxdata Pro 650T Notebook
Rejected discs
I had the same problem, with rejections getting more and more frequent. In the end replacing the DVD burners fixed the problem. Apparently, the red lasers that burn the cd surface fade with use. They are still fine reading the disk at low power, but burning at high power becomes progressively more hit-and-miss.
Jan 08, 2007 | Rimage 2000i CDR 2 (52X), CD Duplicator...
Samsung SH-S182 DVD±RW Dual Layer Burner Logo
1,161 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
