Don't know the model from the information you give, so can only give general advice, but you can try looking for OSD or On Screen Display or On Screen settings on the TV's menu.
Hi there are a few things that could be bad on this TV. the first thing I would check is the T-con board if that's not the problem then the signal board and last the screen itself. If you are planing on doing it yourself you can get parts from www.interliquidparts.com
If you can fix it by yourself, there is a problem in horizontal circuit panel, you need to check that in series because the part appear visbly good but when tested by the exact tester you register busted. that should be replaced immediately. Check also the vertical panel parts of the circuit. but if hard you do the job you may consult the service center of your TV or the vendor of the TV.
ps. please don't rate me if you are not convince of my suggestion.
On the top left hand corner of your remote is a button with the letter i on it and a green query mark beside it. Press it once and the AV1 icon should disappear. Took me ages to find this out, so you're not alone...
You may find it in your "Menu" button on your remote, search for anything similar to "HD Logo" and turn it off. Failing that, make sure it isn't stuck on with transparent plastic, haha.
yOU ARE HAVING A PROBLEM IN HORIZONTAL CIRCUIT OR IN YOUR POWER SUPPLY kindlyu take your T.V tO A QUALIFIED TECH to repair it.ypur problem could be a faulty capacitor ,flyback or horizontal output transistor.
