Question about SanDisk Sansa c240 MP3 Player
Usb plug is not recognized
When i plug my usb cord to my computer it says it is not recognized
  • 3,037 Answers
The encryption needs to be changed. A three letter encryption should show up on the player screen even if not recognized by the computer. It will be usually MSC or Mxx, ect. You need to change it, this can be done somewhere within the menu but I am unsure with this exact model right now where this option is but with a little searching you should be able to find it. If you still can't find it, let me know and I will grab a similar version and figure out what it should be listed under.
good luck
Posted on Jun 03, 2008
My computer can't recognize my USB cord
Try another computer, see if it sees it on that one. If it does then you need to delete all the USB ****** bus controllers on your PC. Attacht the usb deviice then reboot the computer and ithe system should fin it.
Aug 12, 2014 | Mach Speed Trio MACH SPEED Eclipse 180G2...
Printer not being recognized by computer
Sir/Madam
1. Is the printer turned on?
Make sure the printer is turned on.
Make sure the power cord is securely plugged into the electrical outlet.
Test the power by plugging in the power cord of another electrical appliance to an electrical outlet and turn it on. If the power to the other electrical appliance comes on, the printer may be considered to be faulty.
If this product is recognized:
Close this page to return to the installation window.
If this product is not recognized:
Proceed to the next step.
2. Are your computer and the printer correctly connected?
Make sure the USB cable is securely connected to the printer and to your computer and check that the USB cable is not damaged nor badly crimped.
The printer will not be recognized during the driver installation if connected to a printer switch or the printer buffer. If this is the case, try to directly connect the printer to your computer using the USB cable.
If you are connecting the printer to your computer via a USB hub, connect the printer to the first-tier hub from your computer. If the printer driver is still not recognized on your computer, try to directly connect the printer to your computer without the USB hub.
If you are connecting the printer to your computer via a USB hub, make sure the USB hub device is recognized by your computer.
3. Does your computer provide USB or IEEE 1394 support?
If Still Your Problem Is not solved Then Click On Below URL
http://files.support.epson.com/htmldocs/r1800_/r1800_rf/dset_1.htm
Or
Still You have problem Then please Follow Us On HP Printer Support
Jan 08, 2014 | HP P4515n LaserJet Printer
Plug USB cord into computer to transfer photos..on camera screen it says mass storage and the USB is not recognized
Plug camera in any other USB port of computer as some time one particular USB port stop to recognize it.
Oct 20, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
MY COMPUTER SAID IT DOES NOT RECOGNIZE MY USB CORD
It will never say it doesn't recognize a USB cord.
A USB cord is just that--a piece of wire. It might tell you that it can't find the printer.
Has the printer worked before?
If you are installing it for the first time, did you install the software before plugging in the printer?
If you have done all these things, then either the USB port is bad or the printer is.
But--try uninstalling the printer first--and any software that came with it. Then reinstall the software and plug in the printer.
While I did mention that the cord is just a piece of wire, it is possible that the cord has become damaged in some way. Try using a different cord. Also, try using a different USB port.
Apr 18, 2009 | HP LaserJet P2015dn Printer
Windows XP will not recognize my WD 250GB Harddrive
Just plug your USB HDD directly into your MBoard's USB port...
Feb 09, 2009 | Western Digital 250GB MyBook External USB...
Having Problem with both LaCie hard drives being recognized on both macs
Try to connect to another computer, and see if it recognizes the drive. If Not, you can dismantle LaCie and take the disk out.
Connecto your disk to another external box (USB or Firewire) so you can have access to you data.
Jul 04, 2008 | LaCie (300740) 160 GB Hard Drive
My USB cord quit working
If the pictures are stuck in your internal camera memory, you will need a cord to get them off unelss you can transfer them to your memory card first. You should be able to copy the pics there.
Jun 22, 2008 | Nikon COOLPIX L4 Digital Camera
Computer stopped recognizing USB cord from Zen sleek photo
The first problem is probably a software incompatibility between Creative's software and Windows Media Player version 11. The second problem is possibly a need to replace the battery. 3rd party batteries are about 20 dollars now.
May 28, 2008 | Creative Labs Zen Sleek Photo MP3 Player
SanDisk Sansa c240 MP3 Player Logo
32 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
