Question about Maxtor One Touch II (EO1E200) 200 GB Hard Drive
Maxtor one touch 2 200gig
I found this hard drive in a house that i was cleaning out and can not get my computer to pick it up.it connects to a usb port.is there any knid of drivers or softwear that i need to get? found this at a house i was cleaning out and can not get my computer to pick it up.is there some kind of driver or softwear that i need to get ?
  • 65 Answers
If you have Windows 2000 or newer, Windows will auto install generic drivers for the drive and show a drive letter in my computer. Chances are the drive has issues. Try pluggin into a differnet computer and see if the same results occur.
Posted on Jun 04, 2008
How do I connect the hard drive for Maxtor One touch
Just use a standard USB cable to run from the drive to the computer's USB port, and connect the power adapter from the wall to the drive.
Feb 16, 2011 | Maxtor OneTouch 4 500GB External USB 2.0...
My Maxtor one touch has stopped being picked up by my computer when plugged in. When power source is plugged in led light (white) just blinks and never turns solid
You said it has stopped being picked up when plugged in so I hope this is note is relevantbut I don't think it is abnormal for it just to blink.
If the OneTouch does not appear in My Computer or cannot befound by Maxtor Manager, right click on My Computer icon and select Properties,Device Manager, Disc drives, and expand Disc Drives.
There may be ayellow overlay over Maxtor drive, to show it has a problem, so right click onit and select 'Choose drivers for this device' to reinstall them.
Without goingonline they seem to be found and reinstalled from somewhere locally on the PC and I hope this willdo the trick.
Also in case this helps, I don't find the OneTouch (Maxtor Manager) software appears when the driveis plugged in, so I think this is normal too.
You should look for an icon (a capital M within a blue disc) for Maxtor Managerin the taskbar, at the bottom right of the PC's screen.
Right clicking on this icon, (capital M), should bring up awindow with Maxtor Manager at the top.
Then click on the text 'Maxtor Manager' to open the program's window.
Hope this is what you wanted.
Dec 28, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
My Maxtor 200GB external HD is not showing up on my Mac G4. I've tried USB & Firewire connections. Restarted the Maxtor then computer. Restarted computer, then Maxtor No good. Thanks for your...
If it still has a valid warranty, exercise the warranty to get a free replacement.
Otherwise, open the enclosure, and separate the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a 'slave' disk-drive in a desktop computer, to see if the adapter was the problem.
Oct 26, 2010 | Maxtor One Touch II (EO1E200) 200 GB Hard...
BROKEN PLUG?
You can buy another external housing and then just swap the hard drive itself over to the new housing. The housing only cost in the 30 buck range if not cheaper. If you need to get the data off, you can also buy an EIDE/SATA to USB adapter that will allow the connection between an unhoused hard drive and a computer. CompUSA sells them for around 20-25 bucks.
Jul 05, 2010 | Maxtor OneTouch III Mini Edition 120GB...
My Maxtor One Touch III no longer turns on. The
well after some research or a lot of research. I found a few articles that suggest that there is a problem with the board inside the case. It suggest that you take apart the case and remove the hard drive and put it into your computer and it will work just fine.
Nov 04, 2009 | Maxtor OneTouch II external hard drive...
Maxtor one touch 4 mini 250GB hard drive beeping
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
Oct 15, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
My computer no longer recognizes my Maxtor One Touch III Firewire 400/USB 2.0
go to my computer proeprty then uninstall usb driver and then right clik any driver then clik on scan for hardware then it searches usb and install automatically.
May 22, 2009 | Maxtor One Touch III 500GB FireWire/USB2.0...
Transfering data from Maxtor to a new computer
It's a USB Hard drive, so you should plug the USB port into one computer, put your information on it, then plug the USB port into the other computer. Browse the Hard Drive for your data. It's like a larger flash drive.
Feb 10, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Maxtor external hard drive is not accessable
- Do you hear any beep sound when you plug in the USB drive into the laptop? - You can also try a different USB cable - Try connecting the hard drive to a different computer and see if it works All those steps will help you determine where the issue is. Please revert back with any other observations. Good Luck
Mar 30, 2007 | Maxtor (H01R300) 300 GB Hard Drive
Open Questions:
Maxtor One Touch II (EO1E200) 200 GB Hard Drive Logo
159 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
