Question about EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard
Strating up problem
Strats up goes to detect drives then frezzes but reset sw then boot up and goes to widows. tried two different drives one sata and one ide both have the same problem can you help me
    President:
  • 2,351 Answers
Please update MB with the latest bios version:
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=685&DetailName=Bios&MenuID=1&LanID=9
Flash from a floppy disk. Re check bios after flash. Go to Boot section. Make sure you have the correct drive listed in the boot order. If trouble still continues. Go to the serial ATA SATA hard drive's manufactures site. Download the tools/utilities & set the drive up with their bootable floppy disk software.
(Do this without the IDE connected to the system). Try installing windows. You shouldn't have a problem. (The bootable floppy can also test the drive).
Luck!
If problem returns, please include detailed results.
Mike
Posted on Jun 04, 2008
Upgraded HDD on D800 to 160GB drive. Worked fine for 2 wks. Shutdown and will not boot up. BIOS doesn't detect the drive. I can connect the drive to an external USB device and read all files on...
Could be an incorrect bios hard drive setting. Dell has a good customer service area. Did you use same type of drive SATA TO SATA? IDE to IDE? If you changed over there might be a setting to account for the difference.
Aug 25, 2017 | Dell Latitude D800 Notebook
K8V SE Deluxe board. B.I.O.S. Main on Auto, No Hard Drive Detected. Hard Drive is shown in Boot and RAID. Have checked all cables and tried a different HD. Cannot load O.S. from disc. Fails because...
I think u have to download the driver for SATA drive!
Read again ur owners manual and download the driver and procedure so that the bios can detect the SATA HD!
Jun 13, 2011 | ASUS K8V-MX Motherboard
Acer aspire wont start past boot screen
May be the hard drive is not detecting properly on the computer.
Try resetting BIOS.
If that doesnt help, try checking your hard drive on a different computer or using some 3rd party HDD checker.
Nov 05, 2010 | Acer Aspire M1100-U1402A Refurbished AMD...
Did not detect the additional sata hard disk?
Have you tried connecting the SATA hard-drive to a different computer, just to prove that it is not a "dud" ?
Is the SATA hard-drive getting power?
(It should warm-up a bit, and you make feel it vibrate as it spins.)
Have you tried a different SATA cable between the hard-drive and the SATA connector on the motherboard?
Check the BIOS settings, to be sure that detection of SATA drives is "enabled".
Apr 09, 2010 | Computers & Internet
How can i fix my seagate HDD,it wont detect in bios boot up..
Make sure it is connected to power and SATA, try a different SATA connector on your motherboard, there are probably 4 different connectors. Also make sure that the SATA controller is set to "NON RAID" mode in bios.
You need to go into BIOS to change these settings, If you don't know how to do it Give me your motherboard details (model no makers name)and I'll write you out a walkthrough to set the bios up properly for your drive
Jan 25, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
M2N-MX SE PLUS SATA PROBLEM
Do your have windows installed on a ide drive?, cos if this is the case you have to install the sata hdd drivers.
Mar 27, 2009 | ASUS M2N-MX Motherboard
PC won't boot if SATA drive connected, drive works fine if plugged afterward
Try Hirens Boot CD. It has a lot of programs on it to detect format etc.
I think your hard drive has a missing or corrupt MBR and it needs to be replaced.
When I have had a hard dive not recognized I hve used Super Fdisk to format and reset hard drive.
On the boot disk
Nov 03, 2008 | ASUS K8N-E Deluxe nVidia nForce3 250...
Dell Precision 380
So the 80GB drive is an IDE drive, right?
Different manufacturer's have different BIOS' so I can't say with certainty what you'll see in yours, but on my ASUS motherboards I have a one of three settings:
PATA
SATA
PATA+SATA
When I run both IDE and SATA drives I need to use the third setting. I sounds like you're shutting off the PATA when you enable the SATA so there's no drive from which to boot.
If I misunderstand your problem please let me know.
Dec 22, 2007 | Dell Precision 380 P4 Dual Core 3 GHz...
Boot Failure
i am assuming you have allowed the bios to detect that there is a different hard drive fitted as it will be looking to boot from an non existent drive. If you have fitted a new HDD with an operating system already on it then you will have to repair windows as its a change in hardware. If you cant get the bios to see the drive then the motherboard has an IDE or Sata connector problem.
Sep 13, 2007 | Computers & Internet
EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard Logo
109 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
