Question about Refrigerators
Amana Mod # ABB2223DEB Refrigerator
Purchased Amana model ABB2223DEB Nov. 2004
1st problem; Feb 2006, loud grinding & popping noise
when refrigerator starts up and lasts 15-20 seconds.
Replaced Air Damper Pt# 67003903.
2nd problem; Mar 2006, Refer not cooling, freezer
frosted up. Replaced Control Board Pt #12002567.
3rd problem; Nov 2006, loud grinding & popping noise
Replaced Air Damper Pt # 67003903.
4th problem; Feb 2007, loud grinding & popping noise
5th problem; Mar 2008, loud grinding & popping noise
6th problem; May 2008, loud grinding & popping noise
Does anyone have any ideas reguarding this, other than
replacing one bad "made in china" damper with another
"made in china" soon to go bad damper?
Thank you in advance.
  • Anonymous Oct 02, 2008
    I have the same model and the same problem. Purchased unit June 2006 and I am on my third damper motor and I need a fourth now. Symptoms are the exact same as you described. Costs me over $100 each time the guy comes out cause he says it's out of warranty.
I found this problem addressed on applianceblog.com and per they recomended part # 67006166. My repairman ordered this part and it had been superseeded by an even newer version, # 10127429. He installed that newest version in late June 2008 and it has been great ever since. So for me # 10127429 was the answer. Hope this helps
Posted on Dec 03, 2008
Try damper part number W10167268 from Whirlpool. They re-engineered the part, it's works different. Whirlpool issued a bulletin to servicers, but won't cover it under warranty (I have tried for many customers) "A bulletin is NOT a recall"
Refrigerator not as cold as it should be, freezer too cold and has some frost
check the fan should be run in freezer & its air flow clear to refrigerator side,no blockage items or ice in its way oy of air flow
Jul 07, 2014 | Amana Refrigerators
I have a amana abb2223deb fridge and the freezer stopped cooling then 2 days later the fridge stopped as well.Any one know what that can be I bought this in 2005 my second fridge in 7 years. any help would...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 29, 2010 | Amana Refrigerators
Noise after the motor starts
Is this a clicking or a knock/pop sound? The knock knock sound can sometimes be helped a little bit by tilting the refrigerant filter drier (located in the compressor compartment) to a horizontal position. Ask your technician to do this for you.
May 29, 2010 | Amana DRS2462B Side by Side Refrigerator
Knocking noise in refrigerator section
This will be a loose mount on the electric motor (tighten)
May 05, 2010 | Amana ABB1927DE Bottom Freezer...
Amana ARB9059cs: compressor makes loud noise (come and go). Refrigerator not working but bottom freezer is working. All lights on. Please advise.
they had problems with some compressors siezing up due to lubrication issues.refrig not cooling probably air flow problem.either fan in freezer section not working,coils iced up,or return air vent blocked
Jan 25, 2010 | Amana ARB9059CS Bottom Freezer...
Makes a loud pop noise, and the refrigerator compartment now freezes.
sounnds like your air damper poped off the spring and is now stuck open pouring freezer air into you refer compartment'
Oct 09, 2009 | Amana ABB1927DE Bottom Freezer...
AMANA REFRIGERATOR MAKES A LOUD POP!
Dear Customer
Please perform the following
If it's cooling ok, they're probably normal sounds. Modern refrigerators can make many noises, most people aren't home long enough to hear them. A popping sound could be defrost water hitting a hot defrost element, or refrigerant making noise in the cooling lines. If it's working ok, ignore it. Please rate this,Thank u
Dec 17, 2008 | Amana ACD2232HR Side by Side Refrigerator
Noisy Amana ABB2227DEB
The motor is an "auto damper" that opens/closes to let cold air from the freezer comp. into the refer comp. depending on the temp. There is nothing you can do for maintenance, the little motor runs the damper when needed automatically. Some motors are quiet, some are noisy (grind grind grind) as the open and close. Sort of the nature of the beast, if you're lucky you get one that stays quiet.
Feb 26, 2007 | Amana ABB2227DE Bottom Freezer...
Refrigerators Logo
783 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
