Question about Sharp AR-5316 Advanced Digital Imager Copier
Error Code U2-40 on Sharp FO-DC550 fax machine.
  • Anonymous Jun 10, 2008
    SHARP FO DC 550
    U2-40 WHAT IS IT?
U2-40
Posted on Sep 10, 2008
  • 146 Answers
That is a CRUM communication error. The CRUM is a chip that resides on the toner cartridge that keeps track of the toner usage and resets when a new toner is installed. If you replaced the toner recently it may be corrupt. If you got a refurbidhed toner they may have reprogrammed the CRUM incorrectly. Power supply problems often cause this error so check your outlet to make sure it is withinn the proper voltage range and also that it is not on the same circuit as other devices. Get a "real" surge protector designed for office equipment such as a smartpower. Try changing toners and using genuine supplies.
Posted on Jun 04, 2008
Fo-dc550 how to reset
depends on the code, what are you trying to reset?
Jul 23, 2014 | Sharp FO-DC550 Laser Fax
Need manuel
hi just
try try this link then download
http://esupport.sharp-cee.com/html/om/index.php?StartRec=0&ListLimit=10&Lang=%&TemplateLang=en&ProdLine=36&SortOrder=DESC&OrderBy=Title&SearchString=fo%20dc%20550
Apr 21, 2011 | Sharp FO-DC550 Laser Fax
Sharp fo 4700 display error ( polygon )
You have a bad printhead unit(laser unit) . The polygon mirror is not rotating within a specific amount of time. I recommend you to replace your fax unless your willing to spend between 200 to 500 dollars.
May 03, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Sharp FO-4650 fax machine
You have a bad printhead unit(laser unit) only if the problem persist. The polygon mirror is not rotating within a specific amount of time.
Feb 10, 2009 | Sharp FO 4450 Laser Fax
Error H3 00 appears not found in guide book
H3-00 Heat roller high temperature detection
The fusing temperature exceeds 240C°.
Thermistor abnormality.
The easiest and cheapest solution is to replace the fuser.
This is very typical of a laser machine as some point the fuser will go out.
These little machines have a disposal fuser unit. It is possible to replace the parts. After the time and parts, in the long run it is cheaper to replace the whole unit.
Jan 28, 2009 | Sharp FO-DC550 Laser Fax
Sharp FO5700
I have never seen this error code on a sharp FO 5700 are you sure that is the right model # or error code. I even did a search in the FO5700 service manual(no luck). I believe I have seen this code before on a sharp copier.
Sep 05, 2008 | Sharp FO 5700 Plain Paper Laser Fax
International faxing
Dial it as you would dial from a regular phone.
Ask the operator for the Country Code.
Sep 02, 2008 | Sharp FO-DC535 Fax
Sharp AR-5316 Advanced Digital Imager Copier Logo
545 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
