Question about Gateway FPD2275W LCD Monitor
Acer LCD Monitor - Stuck Displaying green
Hi, when I returned home from work the other day I found that my Acer LCD Monitorwill now only display the word "acer" in green when powered on.Normally it would display this logo for a few seconds, then move to "NoSignal" until I powered on my computer (I was told to always power on the monitor first then the computer). Next, it would display the image from the computer as it should and function perfectly.
However, it will now only display this green acer logo and never go beyond this point, whether it is or is not connected to a computer (using either vga or dvi connection)and whether the computer is turned on or turned off. It simply displaysthe logo then does not attempt to receive a signal from it's connectedcomputer.
Could this be a result of a power outage at my house while I was at work? What can I do to make my monitor function again?
    President:
  • 2,712 Answers
Cant say for sure. The display seems to be working, and the computer signal seems to be the problem. It could be a faulty cable. Check the pins on the cable monitor and see if they are bent, etc.
If the connectors are Ok, it could be the converter or the main board that has the fault. This could be caused by a power surge, or just a mechanical failure.
There is no easy diagnosis for this\ one, without actually checking the parts. I would recommend taking it to a repair place.
Posted on Jun 04, 2008
Acer monitor has green lines on the scren
Liquid Crystal Display (LCD) screens use less energy and display a clearer picture than the Cathode Ray Tube (CRT) displays that preceded them. These new LCD screens now dominate the computer monitor market. From time to time, however, pixels can become stuck and a green line can display on the screen. Removing this line is sometimes possible without sending the screen to the manufacturer for expensive repair.
Locate the pixels that are stuck on the screen. Download a free screen repair software program, such as UD Pixel or JScreenFix. Run the software and allow it to find and attempt to repair the stuck pixels. Turn off the LCD monitor. Apply the damp cloth directly over the stuck pixels and use a gentle pressure to spread the liquid within the screen.
Things You'll Need Pixel repair software Damp cloth LCD screen 5 Ways To Fix A Stuck Pixel On Your Screen
http://www.makeuseof.com/tag/best-software-solutions-to-fix-a-stuck-pixel-on-your-lcd-monitor/
Feb 22, 2013 | Acer Computers & Internet
MY ACER LAPTOP 5535 WHEN SWTICHED ON, I CAN HERE THE FAN STARTED AND GREEN LIGHT SHOWS, BUT THE SCREEN IS BLANK, NOTHING DISPLAYING PLEASE HELP!
is sounds like the lcd display may be bad. try plugging a rgb cable into your laptop and another monitor to see if you get pic.
Aug 30, 2010 | Acer Computers & Internet
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Monitor colors are not displaying correctly
Hi, At the worst it is a blown monitor, but have hope. 1st try a new or known good lead, between monitor and PC. 2nd put monitor with own lead on good PC. if 1st works = result. if 2nd and monitor is same, suspect monitor, however, if 2nd works ok on other PC, then look at ur vid card. Either way, this test sequence should save you some $. Be lucky.
Aug 15, 2009 | Acer AL1916W 19" LCD Monitor
PS3 to Acer AL2423W
this link will help you:-)
http://forums.entechtaiwan.com/index.php?action=printpage;topic=4280.0
Jun 23, 2009 | Acer AL2423W LCD Monitor
I have 3 acer al1603w widescreen monitor.. it was working ok before, then i let my brothers used them. afterwhich it is displaying "input not supported". WHOAAA!?!!? what do i do? its bugging me for 3 days...
Sounds like somebody messed with the monitor setup on the monitor controls. Check the manual to set it up correctly. If they changed the monitor's Frequency settings, the problems you are having will occur. Gotta set them back to 70Hz and check the other settings. If you need a manual, get back to me with the exact model number of the monitor.
Jun 11, 2009 | Acer AL1916W 19" LCD Monitor
Acer LCD Monitor only displays "acer" logo
You are correct, it could be a power surge that has caused it.
Try this..
Unplug the monitor from the wall.
Remove all the video connections at the monitor end.
Wait 10 minutes then plug the monitor back into the wall (do not connect the video leads)
Turn it on and see if it goes past the ACER logo now. If so, replace the video cables and try the computer.
If not, then one of these will apply and a tech will be required..
  1. The internal bios has been corrupted.
  2. The power supply inside the monitor may have issues preventing the video board from starting correctly. This could be as simple as a few failing capacitors.
Number 2 is the most likely cause with an Acer monitor though. Any local tech will be able to correct it fairly cheaply, but phone around for quotes..they can vary a lot.
Jun 03, 2008 | Acer X193W LCD Monitor
Monitor
hi,
Unplug the monitor from the back of your computer tower. If the LCD is not displaying any Video the monitor has gone bad. If it displays self test feature check window. It could be a graphic card driver problem.
Mar 22, 2008 | Dell E176FP 17" LCD Monitor
Monitor Acer Problem
I agree it isn?t the monitor but I would suspect the video card you are connecting it to or the PC itself. Generally if a monitor doesn?t detect a video signal it will go into hibernation mode, typically displaying a no signal warning and changing the LED color from green to amber. When you start the computer is anything displaying at all? Are you sure the PC is powering up and booting?
Jul 22, 2007 | Acer AL1916W 19" LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Gateway FPD2275W LCD Monitor Logo
95 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
