Question about Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-E60A20 error code 4 blinks
Hi, I have been fighting this TV for a week now. It shut down showinging 4 blinks. I have replaced the thermal fuse, the lamp and cleaned three of the four fans. I can't figure out how to get to fan 178708111. Also on this TV, the H4 board is not located where the service manual shows?
The fans were dusty and the fan178706511 was really dusty.
The screne still shows fan problem?
Ken
  • kayliiscute5 Apr 18, 2009
    HI, my kdfe60a20 was blinking 6 red, so I replaced the thermal fuse and cleaned all the fans but now, it turns on for 3 seconds then goes off, now it blinks 4 red. How can I fix this problem?
SOURCE: kdfe60a20
VERY Easy to change!!! We took the back off and on the right side by the fan is where it connects, just like KimSm said.. My husband called the shop and they wanted to charge 100 to come and look at it, 100 to take it with him if needed, 50 a night storage fee, 600-700 to fix it... He went as far to tell my husband there was no way we could fix it ourselves, there was soldering involved,circuit boards involved.. All lies!!! I just happened to stumble across this website and I am glad I did.. Saved a bunch of money. Thanks Everyone!!! Harley_Diva
Posted on Jun 03, 2008
kevin000
  • 1847 Answers
SOURCE: KDF-E60A20
For free sony support go the link choose the produce and chat for free
http://esupport.sony.com/US/perl/support-contacts.pl
Thanks for using fixya. Hope this solution may have helped you.
Posted on Jun 17, 2008
SOURCE: sony kdf-e60a20 problems
Replace the main lamp( sony XL-220). Step by step instructions in owners manual, takes about 10 minutes and is very simple.
Posted on Dec 24, 2008
romsky79
  • 822 Answers
SOURCE: Looked and the thermal fuse is not broken
check again thermal fuse that you replace maybe wattage is not enough. there a lot of protection in that circuit.
Posted on May 30, 2009
ripleymojica
  • 643 Answers
SOURCE: Picture and sound goes out?
does it do it on dvd. if not ists the signal from your cable provider
Posted on Jun 02, 2009
I'm having the same problem with my tv (wega sony kdf e60a20) just like a few other people here, with the sensor cutoff fuse, how do you replace this item?
If you mean the thermal fuse, the set should have a red blink code of 5 blinks. The thermal fuse is way inside on the frame of the lamp housing but can be tested with rear cover removed.
If you have one bad the red blinking light will have to display some code.
Dec 22, 2012 | Televison & Video
H ave a sony kdfe60a20, just replased bulb and fan for bulb, watched for about 2 hours then tv went dark. Now I have a blinking red light. blinks 4 times pause 4 times continuously until I unplug the tv....
4 times red standby light indicates problem with exhaust fan that is not running for some reason.
Recheck fan that you replaced and make sure its connector is plugged properly and it running freely.
4 times red light blinking is fan error in this tv.
Thanks.
Nov 03, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
KDF-E60A20 Red Light Flashing 6x
a 6x blinking error code is usually the thermal fuse located above the lamp housing on the light engine. probable cause of failure is clogged fan located in same area or poor ventilation because set is to close to wall [unit requires minimum of 4 inches of clearance]. part # is 1-910-023-93. another possibility but less likely is the gm board which drives the lamp voltage. part # is a1109407a.
Jun 02, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
May 30, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Tv blinks 6 red blinks
Thermal Fuse kit needs replacement = part # 1-910-023-93
Qualified tech only.....T.
Jun 22, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
KDF-E60A20
Jun 01, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Kdf-e60a20
do a google, Sony 4 red blinking lights, there is lots to read. Read it all. We had 6 blinking lights and it was at $20 thermal fuse that we reinstalled ourselves and saved lots. It was past warranty. You can also put a message out on the blogs. But do your homework, it's worth it. Good Luck, Kim
May 20, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Sony kdf-e60a20 60inch
Yes, it's your thermal switch, had this problem and changed the bulb, no help. Got it checked by tv repair and they changed the switch.
Jan 08, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
My TV KDF-E60A20 is now Fixed. My tv was overheated and Thermal Fuse Located bottom of the lamp burned. I replaced a different Thermal fuse part from 191000644 to 191002393
at www.partstore.com
search for part number. thank you for the review it's help me a lot
thank again
May 07, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-E60A20 60 in. LCD HDTV Logo
140 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
