Question about KitchenAid KTRS22EL Top Freezer Refrigerator
Kitchenaid superba model no. KTRS22MAAL10
(top freezer bottom refrigerator) We have noticed the bottom is not blowing cool air. The freezer is working, lights all work. There is a box with small grid like cuts in it. Is this suppose to blow cool air? I know the temp control on the front inside panel is working because you can here something shut down in the back of refrigerator. please help ! We would like to try and save cost and repair ourselves if possible. Janet H.
  • 958 Answers
SOURCE: Kitchenaid refrigerator w/bottom freezer french doors
please check the air flow to the refrigerator side. it could be a stuck damper motor or damper thermostat. if the fan inside the freezer is running, you should be able to feel cold air coming out off the vents in the refrigerator side. you might have to press the button light switch on the panels to run the fan.
Posted on Feb 19, 2008
  • 1314 Answers
SOURCE: Water Filter Kitchenaid Superba...Where is it??
look for a round peice on the kickpanel at the bottom of the unit it twists and slides out
Posted on May 13, 2008
  • 10 Answers
SOURCE: Kitchenaid KSRA25IL Freezer working Fine - Refrigerator not
I had a similar problem where the refrigerator side was not cooling well but I could feel very little air coming through the vent in the top left corner.I blew hot air from a blow driver into the vent for about 1 minute which melted ice that was hanging from the bottom of the vent cover.Cold air started blowing harder thru the vent and cured the problem.
Posted on Feb 16, 2009
  • 333 Answers
SOURCE: location of refrigerator water filter
The filter should be a canister somewhere in the line from your sink to the refrigerator. If there is no canister visib;le there then obviously they never installed a filter in the first place. I hope this helps. Don't forget to rate my answer. thanks.
Posted on Feb 21, 2009
whytfang
  • 170 Answers
SOURCE: KitchenAid Side-by-side (ksrg25fkwh05) - Freezer not working
The odds are it is a circuit board problem...I had a huge Amana 27 cubic foot side by side and it did the same thing...I diagnosed the problem and replaced the circuit board ....which actually controls everything...one sure sign is to pull the unit out as the other person did and to access the back of the unit where the compressor is...(the comptressor should be on 85% of the tme....if it is not on and warm or hot to the touch then it is a circuit board problem....since compressors will continue to run if there is a defrost problem (most of them anyway), or an Ice build up, etc etc. I don't recommend a layperson trying to replace the circuit board (mine cost $115,) but if you do it is generally in the door mine was a long thin circuit board behind the fridge door handle. .P.S. the heat that the other person felt on the door and around the door seals is normal lots of people don't even know this heat strips exist until something haappens and they start feeling around...these heat strips are to prevent frost of ice build up where the door meets the fridge framd...which can happen due to the extreme temp difference between the two...(inside temp and outside temp).
I hope this has helped...good luck...Knowledge gives you a base from which to yield power over unscrupulous repairmen whop may try to take advantage of people.
Again ...good luck and let me know what happens.....Please rate me .....The Fang.
Posted on Mar 27, 2009
My refrigerator isn't cooling well. The freezer isn't freezing at the top only the bottom.
if it's just cold at the bottom and warm up top it sounds like you have a bad evaporator fan motor in the freezer side,when you open the freezer door do you hear the fan blowing?if not bad fan motor,this happens when the fan motor is bad because heat rises and cold air sinks.part number : 2259385 and it's around 60 to 70 dollars
Nov 19, 2013 | KitchenAid Superba Architect KSCS25INSS...
We have a Kitchenaid superba side by side. The freezer is working fine, but the refrigerator isn't cold. I have vacuumed the coils at the top of the model, but didn't solve the problem. I can...
The cooling normally comes from the freezer side, through cooling tubes. There should be a fan either blowing or sucking the air through these cooling tubes. So the first thing you should do is verify that the evaporator fan is turning and then see if you feel air flow in both compartments. If you have air flow in the freezer but not the refrigerator side, then the cooling tube must be blocked.
Most of the time the blockage is ice or frost, and you will need to open up the inner back panel of the freezer to get to the cooling tube. Look for an opening under the evaporator. Suggest a hair dryer to defrost the tube.
Jul 15, 2011 | KitchenAid Refrigerators
My refrigator will get cold for a couple of days then it does work then it will work> I notice that in the freezer part gets ice up then it starts to melt and also the refrig part will stop blowing in...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,</span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><br />Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling<br /><br />Refrigerator not Cooling or Fridge not Cooling<br /><a href="http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not" target="_blank">http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not</a><br /><br />How to Defrost Refrigerator Defrost Timer Problem <br /><a href="http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer" target="_blank">http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer</a><br /><br /><br />Water Running in efrigerator from Freezer<br /><a href="http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from" target="_blank">http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from</a><br /><br />heatman101</span><br />
Aug 25, 2010 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Refrigerator dripping water
i have a kitchenaid top / bottom refrigerator water drips in top part only not freezer. what is my problem?
Dec 31, 2009 | KitchenAid Superba KSRG25FK Side by Side...
many times when a unit has a defrost problem the coils freeze up and do not allow the fresh food side to cool properly...check for a build up of ice on the inside back wall of the freezer compartment. if there is a build up of ice, you have a defrost problem. Also, check to make sure the evaporator fan in the freezer is blowing the air into the fresh food side.
Dec 26, 2008 | KitchenAid KSRS25IL Side by Side...
Refrigerator stopped cooling
I have the same problem on my GE model :
GTS18FBMERWW
It is a 18 cu ft, top freezer model.
If you get an idea please let me know.
TK
May 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Freezer too cold frosty, and refrigerator section too warm
Sounds like a defrost problem if the evaporator is frozen over. If it's just Ice blocking air transfer on a top freezer model, then it's a blocked defrost drain.
Sep 10, 2017 | KitchenAid Superba Architect KSCS25INSS...
Fridge and Freezer losing cooling
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Nov 23, 2007 | Fisher and Paykel Active Smart E522B...
Fridge freezer double door top fridge bottom freezer
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
YOU CAN TRY turning FREEZER CONTROL
To A WARMER FREEZER SETTING
Allowing.. MORE AIR.. to refrigertor side
Oct 24, 2007 | KitchenAid Superba KSCS23IN Side by Side...
KitchenAid KTRS22EL Top Freezer Refrigerator Logo
442 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
