Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
I now have a shadow
Hello, First I had the problem of the tv would turn off and give 3 blinking lights.
I had that repaired for $300 bucks.
Now I have whats seems to be shadows on lettering and faces.
The repair man said give it a couple of days. Is this true.
  • NeedsBigHelp Jun 03, 2008
    Thanks for the fast response "IFixAll"...
    How do I pull up the convergence adjust with the remote?
  • 868 Answers
Can you adjust the convergence through the remote.It will pull the lines closer together.
Posted on Jun 03, 2008
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
48" Toshiba Projection TV
If you keep whacking it, you'll NEED a repairman!!!
Really, the question you should ask yourself is, "Am I wanting to spend money to fix this set or invest in a new one?" Since I don't know your financial situation, I won't go there, but I would suggest that you maybe contact a TV repair person, have them come out, look at the set and give you an estimate on the repair costs. The trip out and the estimate may cost you a couple hundred bucks, but you then have the information necessary to decide which way you want to go.
Personally, if the cost of the repairs approach about 1/3 the cost of a new set, I would opt for the new set -- so if it would cost me about $700 or more to fix the old one, I could see a new set in my future. If it would only run $300, I may get the old one fixed and get another year or two out of it. By then, the prices on the larger sets would have come down, the options and selections would have gone up.....
Jan 24, 2010 | Toshiba Televison & Video
I have a hitachi 43uwx10b projection tv with red shadow on one side of screen
sounds like one of your bulbs inside the tv is off alignment. you need to have a tv repairman come and look at it and retune the prism. but beware it's not a cheap repair, probably looking at 200 to 300 bucks for the repair.
Oct 17, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
JVC TV AV-32870 will not turn on. blinking timer light
Worth taking it in since it is hard to find a new TV for less than $300. I have a 32 inch JVC iart that for about 2 years would turn itself off and the timer light would blink. Only thing that worked would be to disconnect and turn back on. Eventually, the tv "popped" I could smell something that burned out and within 3 weeks tv went "dead" Took it to a tv repair place and replaced power unit for $150. I had similar problem with a 19 inch Philips and that tv has been going strong for 4 years since repair.
Good Luck
Oct 17, 2008 | JVC AV-32820 32" TV
Panasonic projection tv
Standby light blinking 3 times means a convergence error. The two convergence IC's need to be changed Panasonic part# C5AA00000203 (do not substitute with a generic STK#) This is about a $300-$400 repair.
Sep 23, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Sony kdf-60wf655
There is a lamp driver error in your TV set. Most likely the ballast circuit for the bulb. Depending on who you take the set to, you will pay anywhere from 300 to 500 bucks to have this set repaired. This is why i recommend an extended warranty on all of these types of TV sets. This repair will involve replacing a board, and it could be one out of three of the differant boards that control the lamp. good Luck.
Jul 21, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Mitsubishi diamond series tv
I have a 2003 mitsubishi WS-55711. While watching TV the other day it just shut off. When I pressed the power button, the green light turned on for approximately 3 secs, then shuts off. I've attempted to simply unplug it for a period of time in hopes that it would possibly reset. However, the same thing happens. Is this a problem I can fix on my own or does a professional need to fix it? If I do have a pro fix it, what is the likelyhood that it will happen again? Should I just invest in a new TV? Thanks
Jun 26, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Powers Out and Power light blinks 3 times
If the picture turned yellow then that usually indicates a loss of blue. The blue CRT might have shorted out or the driver to it. The driver will be the lesser of cost in repairs.
Apr 17, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Need Help big screen turns on thens goes off
The unit is going in to shutdown. Sounds like you have a short in the high voltage section.
Feb 18, 2007 | Panasonic PT-53WX52 53" Rear Projection...
Mitsubishi WS-55807
You have a convergence problem, and the sooner you get the set into the shop the less it will cost you. It seems that you may only have bad or cold solder connections on the stk convergence ics. If you keep hitting it to fix it, its goingg to surge the parts then youll be looking at 300 bucks or more to repair. GET THAT SET IN ASAP. Good Luck
Jul 13, 2006 | Mitsubishi WS-55807 TV
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
