Question about HP Color LaserJet 2600n Printer
HP 2600N Power up problem
I purchased an HP laserjet 2600N in April. I have always experienced the following problem. When I turn on the power switch the printer appears to start up. I can hear the motors and paper rollers going through their start up cycle, but no front panel lights are visible and the display is blank. If I switch the power off and on again using the printer power switch the front panel lights and display come on and the printer works fine. I contacted HP on line support who suggested I upgrade the printer firmware to the latest version. I did this -but no change - still the same start up problem every time I switch on. Makes no difference if I power up the printer after the computer is powered up or vice versa.
The printer is connected to a single computer [no network] using a USB port. Operating system is windows XP SP2. Apart from this start up problem the printer seem to function correctly and the print quality is fine. Any ideas on what could be causing this
  • 1 more comment
  • stewart moulton Jun 06, 2008
    Thaks for the suggestion, but I had already tried powering the printer from a separate wall socket and it made no difference.
    Contacted HP support again and they have agreed to take the printer back and fix it under warranty.
  • Anonymous Feb 25, 2009
    Same problem. No lights, hear motor. Sometimes we get lights then it is fine. No rhyme or reason.
  • Anonymous Mar 15, 2009
    I have the same problem. I have to keep turning it off and on until it comes back to life. Unfortunately I have had the printer for quite a while, so no warranty fix. HP are you listening?
    Tom Davidson (SE Wisconsin)
    Thomas.Davidson@yahoo.com
    Master:
  • 638 Answers
Try to plug in ur printer in some other grounded wall outlet directly.this may solve ur problem.
Posted on Jun 04, 2008
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
HP color laser jet 2600n. Shows 51.22 error
after you replaced the cartrige,did you run a initialization?
Sep 07, 2008 | HP Color LaserJet 2600n Printer
GOOD AFTERNOON, AFTER THE EXCHANGE'S BLACK AND MAGENTA TONER PRINTER HP COLOR LASERJET 2600N 55.1 HAS THE ERROR AND EVEN BACK TO THE ORIGINAL CARTRIDGES and update the firmware the error persists.
55.1 Error DC controller error.
The device has experienced an internal hardware error.
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
If a surge protector is being used, remove it.
Plug the device directly into the wall socket. Use the power switch to turn the device on.
Check the engine (DCC) firmware version.
Update if needed. Replace the DCC if a firmware upgrade does not resolve the issue.
Jul 13, 2011 | HP Color LaserJet 2600n Printer
I get an HP error message on 2600n printer saying "57 Fan Error". Is it fixable?
57 Fan Error
Turn off then on
The device has experienced a problem with its internal fan.
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.The fan is not replaceable. Replace the engine.
Jul 11, 2011 | HP Color LaserJet 2600n Printer
Hp color laser 2600n error 51.23
51.23 Error-yellow scanner error
Try this:
initialize.
it. Plug the device directly into the wall
device on.
Laser scanners are not replaceable.
Replace the engine.
Jun 28, 2011 | HP Color LaserJet 2600n Printer
Hp laserjet 2600n printer has a 51.22 error even after removing the toners
hardware error.
51.22 Error-magenta scanner error
try this:
initialize.
device on.
Replace the engine.
Oct 30, 2010 | HP Color LaserJet 2600n Printer
Error no is 51.22
go to this link, and read page 12 .. your error is listed as
http://www.partshere.com/Models/Q6455A/CLJ_2600nTroubleshooting.pdf
51.20 Error
51.21 Error
51.22 Error
51.23 Error
hardware error.
51.20 Error-black scanner error
51.21 Error-cyan scanner error
initialize.
device on.
Replace the engine
please post positive feedback for me
Oct 17, 2010 | HP Color LaserJet 2600n Printer
I have a Hp color laser jet printer it is giving me an error message 55.1 turn off what does this mean I have tried turning off
Here is what HP says... Error message55.1 Error DescriptionDC controller error. The device has experienced an internal hardware error. Action
  1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn on the device.You could have a bad power outlet. try another one.
Apr 15, 2010 | HP Color LaserJet 2600n Printer
Ihave hp 2600n printer error 55.1 & i turn it off and open with out soved pls help me thank
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information. 55.xx PRINTER ERROR alternates with CYCLE POWER TO CONTINUE An internal communications error occurred. The page containing the error will automatically be reprinted. 1. Check the power at the customer’s location. 2. Replace the formatter and/or firmware DIMM. 4. Replace the engine controller board. 5. Replace the formatter board. On the 5si, 8000, 8100 this could be a fuser problem. Try replacing the fuser.
Apr 11, 2010 | HP Color LaserJet 2600n Printer
HP 2600n
50.2 Fuser Error Turn off then on Description 50.2 Slow fuser error. The device has experienced an internal hardware error. Action
  1. Turn off the device, wait at least 25 minutes, and then turn on the device.
if no result,
Fix this with a new FUSER Assembly for HP Colour Laserjet 2600/n (200/240v) Part Number: RM1-1821-240CN or Fusing Assembly – RM1-1820(110/120v )
Oct 05, 2009 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
99 people viewed this question
Seeker5211
Seeker5211
