Question about Compaq 39-pin IDE Hard Drive Cable (108950010) Drive Case
Hard Drives not read
I have a PC with a 300GB sata, and a 200GB sata. When starting the computer the memory shows up but not the hard dirves. Other times the hard drives work either one or both, and then at times during the use of the computer it will freeze up. I then restart the computer and it wont read the hard drives yet again. I have guted out the PC and rewired all the hard drives etc. Still no hard drives. I know the hard drives are good. I am not sure what the problem is. I want to say maybe the power suplly isnt putting out enough, but not entirely sure. If anyone could help it would be greatly appreciated.
    Scholar:
  • 180 Answers
The problem which i feel is
1 not enough wattage of power supply required wattage is 500w
2 PUT ONE DRIVE ON SATA 1 AND run the comp
3 then remove this hd and put another one and run comp
see if it detects as drive both times
then
choose sata 3 and sata 1 for both the drives, one sata 1 and other sata 3
since both would be master this time your problem may be rectified
if both the drives have same firm ware , the drives will report this error permenantly .
last try can be done to remove pcb of the drive and clean the contact surfaces of firm ware and motor supply area. this will solve your problem too. you may notice some dry burned surface on the firmware contact areas.
anaesarora
Posted on Feb 08, 2009
Ide driver
It appears to be SATA 2.5
Spec
NB link for spec only - I know nothing about the seller
Oct 29, 2013 | Fujitsu 200GB MHY2200BH, PN...
I have unplugged my maxtor 300gb external hard drive from one pc and have plugged into my laptop to transfer data. Light goes on but doesnt seem to be showing up on laptop 'My Comp'
you might want to try to unplug to HD's power and plug it back in then plu the USB into you computer....make sure that you remove the usb safely and not just unplug it.
Nov 24, 2010 | Maxtor OneTouch II external hard drive...
200gb drive registers as 2000gb when I try to format
why not either rename this drive at the correct size or format and partion etc,
If the drive shows 2000GB then why not put some stuff on it say 300GB and if its a 200GB it will give you a FULL message once it reaches 200GB
May 27, 2010 | Western Digital (WD2000BB) 200 GB Hard...
LaCie d2 200GB on my Pc (windows xp) via USB 2.0 doesn't show
the situation here is ahppening to all external sata or Esata drives what happens is the external closure has a usb controller when this dies the drive doesn ot spin up or does not reconise simple solution buy a external drive encloser and transfer the drive to it and that will work. thanks and please rate.
Nov 24, 2009 | LaCie d2 (300769) 200 GB Hard Drive
Where can I locate a Maxtor: 7245A 245MB 3.5"/SL IDE / AT
That is a *VERY* old disk-drive, not a printer.
Modern disk-drives from MAXTOR are, for example, 200GB or 300GB,
namely about 1000 times as much capacity as the 245MB disk-drive.
Try any local computer-store that sells "used" hardware.
Probably, any hard-drive *SMALLER* than 8.4GB can be substituted, and still be compatible with your computer's motherboard.
Nov 18, 2009 | Office Equipment & Supplies
Reagarding some Hard disk
You system probably supports IDE hard disks up to 200GB in size. It all depends on what chipset was used on your motherboard. Since it is a PIII system, the 200GB limit is most likely quite solid. Although, you can get past this by installing a PCI card that can handle larger capacity drives. You could also opt for using a SATA controller, but you will be limited to SATA-150 instead of the more current SATA-300 with a PCI interface.
Jun 07, 2009 | Intel P4 System Configurator (P4SDRAM1) PC...
USB 2.0 Portable External 200 GB Hard Drive doesn't want show up
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Go Start> Control Panel> Administrative Tools> Computer Management
Select Disk Management under Storage
Look to see if your Drive is listed and what the Status, Layout, Type, and File System it has.
Right mouse click on the dive and click on Explore to see if your files come up. If yes, then perform a Change Drive Letter and Path.
Let me know what the status is.
Feb 10, 2009 | Western Digital Caviar SE16 (WD5000AAKS)...
Hard drive connects and then disconnects quickly
Sounds like a bad solder joint or break on the circuit board. If the data on it is important, you may need to use a data retrieval service.
Jan 18, 2009 | Maxtor DiamondMax 10 6L300R0 (6L300R020PK)...
Seagate 300GB USB 2.0, read write error
Hook it to another computer do see if the drive is the issue.
Oct 04, 2008 | Seagate 300GB USB 2.0/FireWire Hard Drive...
Hard disk problem
hmmm try to make SATA disabled from your BIOS setup. Because windows XP SP2 don't have any SATA driver, its came up with only IDE.
Try to disable your SATA it will fix your problem.
Thanks
Iqbal
Mar 23, 2008 | Toshiba Satellite A135-S2276 Notebook
Computers & Internet Logo
123 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
