Symbol ls4000i scanner driver
Hi i am looking for the driver for the above product, or a fix as it is working but wont send/recieve the data.
  • allthewayRay Jul 31, 2008
    I have the same problem and I'm on Vista
  • Anonymous Mar 23, 2009
    me too and im on xp
5 Suggested Answers
Sudrajat
  • 20 Answers
SOURCE: Symbol scanner LS3200
Check out the cable of your scanner, it must be placed with new one if it's broken
Posted on Aug 24, 2007
  • 25 Answers
SOURCE: Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Posted on Jan 05, 2008
Exidous
  • 63 Answers
SOURCE: scanner symbol ls3070-i100US
These are the only drivers i could find that fit your description. Hope it helps.
Simple COM Port Emulation USB driver version 1.8.5
1.8.5 DRIVER Simple COM Port Emulation is one of the USB (Universal Serial Bus) interface modes supported by Symbol scanner devices. In this mode, a Symbol scanner...
123Scan Scanner Configuration Utility v2.7
2.7 UTILITY SOFTWARE 123Scan is an easy-to-use PC based application that will help you program your Symbol Technologies bar code scanning products. Allows easy scanner...
OPOS Driver for Symbol Scanners v3.24
3.24 DRIVER The OPOS Driver for Symbol Scanners v3.24 provides the tools necessary for scanning bar codes. OPOS (OLE for Retail Point-Of-Sale) is a standard programming...
JavaPOS Driver for Symbol Scanners v1.9.1
1.9.1 DRIVER  This driver provides the Java objects necessary to connect a Symbol barcode scanner to a host system based on the Java POS specification (a part of the NRF...
Posted on Oct 06, 2008
  • 74 Answers
SOURCE: scan a barcode and the help menu of the program. LS4000i
Disconnect the scanner from the mouse port or disconnect the mouse from the scanner. The scanner must be connected to the keyboard port and have a keyboard attached to the scanner.
Posted on Sep 17, 2009
  • 65 Answers
SOURCE: Need Adapter
LS4000i does not work with USB or RS232. It is an undecoded (dumb) scanner you need a LS4004 to work with RS232 and special STI adaptor for anything other then 4006, 4007 and 4008. You can always contact me by phone or email 630-622-2024 akowalski@legacyglobal.com Please visit our website www.legacyglobal.com
Posted on Oct 20, 2009
SPACE problem. Hello i have Symbol LS 2208. I need remove space/gap from this code 09/ 5864 I tried to create rule for this (remove all spaces) but it wasn´t work - the scanner scaned no data. I use...
Hello, if all your barcodes have the same structure, it will an easy task. You would need to scan following barcodes from ADF chapter in the Product Reference Guide located at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf
Create New Rule Send Characters Up To Space Character in Alfanumeric Section Skip Ahead 1 Send All That Remains Save Rule
This will by all scanned barcodes send all characters up to the space character, skip the space and send the rest of data.
Oct 22, 2010 | Symbol LS 2208 Barcode Scanner - P/N...
I have misplaced my CanoScan LiDE200 installation CD. Is there a way to download the software required online so that I can scan? Thank you, Patrick
CLICK HERE
hi if you click on the link above then look on the right hand side of the page it takes you to you will see a heading that says buy this product if you look just under this you will see the drivers and software option. click on this and you will be able to download the latest drivers and software for your device.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 10, 2010 | Computers & Internet
Where can I find a current driver?
It doesnt look like the website has the driver - have a look here http://www.scanning.datalogic.com/sitefiles/result.aspx?m=Data%20Sheet;Photography,%20Accessories;Press%20Release&p=QS200&l=english&d=1&t=search&s=NonCurrent
I would contact data logic http://www.scanning.datalogic.com/sitefiles/contact.aspx
The support site - you need to select archive products http://www.scanning.datalogic.com/sitefiles/downloads.aspx then click on For non-current products: Please search the Archivesfor available materials.
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 25, 2010 | PSC QuickScan 200 CCD Handheld
I have a Symbol LS3070 that has stopped sending a return after UPC-A scans. I added a suffix of 7013, and got no change. Any Ideas?
Scanning Scan Options, Data Suffix, Enter from Adobe pages 141 and 142 of 214 the LS3070 Product Reference Guide resolves this issue. The suffix is already set to 7013 so scanning the barcodes above should be all you should have to do to send the return or enter key after every barcode scanned..
Nov 16, 2009 | Symbol (LS3070-I100US) Handheld
LS2208 Can get it to work no driver
If your scanner shipped with a keyboard wedge cable and you are using a PS/2 to USB adapter all you should have to do is scan the IBM AT Notebook barcode on Adobe page 56 of 342 of the LS2208 Product Reference Guide. I suggest saving a copy of the document to your host then printing just that page. Scan the barcode then try scanning your barcode. If the computer still does not see your barcode try rebooting. If this still does not resolve your issue you may want to purchase a USB cable. The part number is CBA-U01-S07ZAR.
If you have the CBA-U01-S07ZAR and the scanner is not sending data then you should scan the HID Keyboard Emulation barcode from the QRG that came with the device or Adobe page 109 of 342 of the guide referenced above. I hope this helps.
Oct 20, 2009 | Symbol LS2208 Handheld
Symbol LS2208: Suffix with 2 x ENTER
You may need to enter two "rules", each adding an "enter" to the data. This is programmed by scanning special barcodes in the manual, which you can download here:
http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
Aug 27, 2009 | Symbol LS2208
I would like to transmit EAN-13 bar code without check digit, but closed by ENTER.
If you would like the LS2208 to transmit only the first twelve digits of an EAN-13 barcode followed by an enter you will have to write an Advanced Data Formatting rule using barcodes from the LS2208 Product Reference Guide found here: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=114420371&stateId=1%200%20114410810
The barcodes you will print and scan in the order they are listed are:
Begin New Rule
EAN-13 (from the Critera pages of the ADF section)
Send Next 12 Characters
Send Enter key
Save Rule
If all other barcodes require an enter key make sure you scan Scan Options, Data Suffix, Enter (from the same manual or from the Quick Start Guide) before scanning the ADF rule above.
Jul 13, 2009 | Symbol LS2208 Handheld
Jan 03, 2008 | Symbol LS 4000i Handheld
Symbol PDT3100 TFT300 & File Transfer
I would like to suggest since you are approaching to GUI enviroment you need to develop system build by visual basic using MSCOMM control by sending and receiving data between PDT3100 and PC.
Please try to visit www.planetsourcecode.com for best VB tutorials about how to use MSCOM1 or hire/chat me if you need my further assistance.
Good luck,
Philip
Nov 04, 2007 | Symbol PDT 3100
Computers & Internet Logo
2,513 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
