Question about RIM BlackBerry Pearl 8100
My blackberry only vibrates and does not ring.
Just lile all the others that posted their problem, my blackberry only vibrates and does not ring.
  • 78 Answers
Sounds like it just need to change the profile settings. Click the menu button then Profiles and select either the loud or normal profile.
Posted on Jun 03, 2008
Hi, i can't get the ring tones to even play now...I've been doing some stuff on my blackberry and I wonder if I've turned something off that should be on now. When I set the volume, I did set it to tone...
This has happened to be before. Sometimes, the speaker just stops working. So dont get stressed out. To me it seems like you went through all the steps to fix it. You didnt do anything wrong. What I would do is call your phone carrier and ask if you could get your phone checked out. They will go inside the phone and check all the insides to make sure it works. That is what I had to do and it turns out that my speaker broke and I needed to get a new phone. So dont worry.
Mar 01, 2011 | RIM BlackBerry Curve 8310 Smartphone
Ringer Not Working Properly
i would check your profiles. usually the default setting for the load profile is for it to vibrate twice and then ring, so that usually only gave you two rings to answer the phone after it vibrated twice. make sure that within your profile setting that you have it to ring with a tone, and make sure you have a volume selected. i would also use blackberry desktop manager and perform a back up or sync of your blackberry, and then perform a wipe handheld. the wipe hand held feature is in your options---security---general settings---and then press your options button (right of the trackball) and select wipe hand held. you will type the word blackberry and then it will wipe the handset. after it resets try the volume before you restore it, if you still don't have volume your speaker is bad.
Nov 05, 2009 | RIM BlackBerry Pearl 8100
Well i have a blackberry pearl 8100 and i set it so that it rings and it does ring but it vibrates twice before that and i dont want it to do that. How do i make it just ring and not vibrate ?
Go to profile, select advance, you will get all the profiles highlight any one of the profile,then press Menu key, select Edit, then select Phone, you will get an option called Out of holster, press Menu key, select Change option under this select Tone, Now you're will only ring.
Nov 01, 2009 | RIM BlackBerry Pearl 8100
How to get my blackberry to ring and vibrate
  • You need to check the profile.
  • Go to main screen
  • you will find options
  • under options icon you find profiles. Here you can set vibrate and ring tone
Oct 24, 2009 | RIM BlackBerry Curve 8310 Smartphone
My blackberry suddenly stopped making noise. The ring, alarm or music will not work. It still vibrates but no noise comes out of it.
You have to pop the battery out to reboot it...happens ALL the time!!! I have to do it almost every other day
Oct 05, 2009 | RIM BlackBerry Pearl 8100
My alarm won't ring or vibrate, but both work when someone calls me. I have it set for vibrate/ring but the screen just lights up when the alarm goes off, doesnt vibrate or ring
Reboot the HH,restart the HH and follow the follwing steps Press Menu,Select Clock-press menu-select alert type as tone-select the tone from the given list and save it.Check whether if you are able to listen to the tone.
Aug 04, 2009 | RIM BlackBerry Pearl 8100
Can't set my blackberry curve to ring and vibrate at same time
To silence your device
In the profile list, perform one of the following actions:
• To receive LED notification only, click Quiet.
• To receive vibrate notification only, click Vibrate.
• To turn off all notification, including notification profile exceptions and LED notification, click Off.
Hope this helps!
- CBR2009
Aug 03, 2009 | RIM BlackBerry Curve 8310 Smartphone
Does not ring - only vibrates
A couple of solutions to avoid doing a full software re-install.
Check your profile settings - From home screen, Profile, Advanced, Active, Edit, Phone - Check both in and out of holster to make sure the tone is active in both. If not change the settings.
Let me know how that works - there are a couple of things to look at and suggest before a re-install.
Apr 08, 2009 | RIM Blackberry Curve 8300
Blackberry 8300 curve
Turn your vibrate off. The curve vibrates before it rings, it won't vibrate and ring at the same time. So with the vibrate off, you will gain about 10-15 seconds of ring time.
Apr 24, 2008 | AT&T Blackberry Curve 8300 Smartphone
Bb pearl won't ring
Have you checked the "profiles" (click the icon on the desktop). Make sure it is not in silent or vibrate mode.
Hope that helps... :)
Feb 07, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
914 people viewed this question
Top RIM Computers & Internet Experts
Trisha
Trisha
Nataly Roberts
Nataly Roberts
SANTHOSH
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
