PC won't turn on
My computer won't turn on. It was working perfectly the night before. But now, when I push the power button, the pc turns on for a second and then off (the case fans, cpu fans, and cd drive turned on for a second and others). I'm not sure what the problem is. The LED light on my motherboard is on like usually. I did the paper clip test with the power supply (unplugging the power to the motherboard, and using a paper clip to connect the green wire to a black one), and the case fans were running fine. Any help would be nice. Thanks!
  • DennisC8723 Jun 06, 2008
    I did what you said, but it still did not fix the problem. I just bought another power supply, but it still doesnt work, so I know it isnt the power supply. I know its not the harddrive either because when i unplugged it, it still does the same thing. However, something interesting is that when i unplug the power supply to the CPU, the PC stays on when i turned it on, but however nothing displays. But with the CPU power supply plugged in, it just turns off as soon as I turn it on. Thanks for trying to help me though!
  • Anonymous Jul 01, 2008
    The same problem with HP Pavilion a6230n. Any clue either.
  • 49 Answers
What you need to do is reset the bios. If it wont void a warranty..and don't blame me if you ruin your computer, even though this is completly safe.
Unplug your power supply, push thepower button to get rid of extra saved up juice, then take you side panel off and locate your cmos jumper near the battery. You need to position the jumper on 2 of the pins and keep it there for 8 secs. Then put your jumper to origional position and restart your computer. You will have to reset your time and all of your bios settings. YOu can load optimal defaults if you arn't sure what to select.
Posted on Jun 03, 2008
Simply won't turn on. All the power at the plug has current but nothing when you push the on button.
Gary, Could be power supply failure. Links below for trouble shooting your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Fix Laptop That Won Turn On
Laptop not powering up won turn on Fix Solutions
My laptop won turn on when push the power button
Here What to Do When Your Computer Doesn Turn On
Feb 26, 2016 | Computers & Internet
Power flashes on for a second and then turns off completely
The most likely problem is that the power supply has failed.
Jul 19, 2013 | Shuttle XPC SD32G2 Barebone
The power button on my computer won't turn on the computer
if no any power indicator at the front and also the fan at the power supply as will as in the mother board, it was a power supply failure.
Nov 25, 2012 | eMachines EL133105 Desktop Computer with...
Vostro 1400 won't turn on
I doubt there is battery problem, have you tried switching on laptop without battery and connecting through the laptop charger? most probable your battery is not taking the charge. so suggest you to disconnect the battery and try using laptop with charger then you'll find the problem.
Aug 06, 2012 | Dell Vostro 1400 Laptop Computer (Intel...
My Acer Aspire M1201 won't turn on.
More than likely your power supply got fried from a power surge during that storm anyway. You'd be surprised at how worthless most surge suppressors are these days.
Jul 25, 2012 | Computers & Internet
Power button not turning computer on
this is most likely a short in a computer component, You need to unplug everything from the computer incl CPU, Memory, Add on Cards, Hdds, the lot, just have motherboard plugged in and push power, if it powers up (there won't be a pic but you will know it's working) start replacing parts one by one until it won't start and that is the faulty part. If it does nothing with just motherboard plugged in the motherboard is at fault and needs to be replaced, If you have had the motherboard out make sure no of the metal mounts in the case are shorting out anywhere under the motherboard as this will also cause the same fault.
Mar 06, 2012 | Acer Aspire Z5600 PC Desktop
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
When I push the power button on my HP M9060N , it was coming on ok but then it got to where I had to turn on my power bar and wait thirty minutes to turn on computer, its getting now where it needs to be...
More than likely yes. It isn't good practice to cut power to your PC every night. Although I understand that you are most likely doing this for energy savings, it isn't necessary and isn't good for your PC.
A replacement power supply for your computer, according to its spec sheet, must be at least 350W. Power supplies are variable in quality, you get what you pay for.
I recommend a Corsair CMPSU-430CX because I've personally had good experience with their products, and this power supply is relatively inexpensive and meets your requirements.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139017
How to replace a power supply:
http://www.hardwaresecrets.com/article/362
If you do not feel comfortable with replacing it yourself, there are numerous services that will replace it for you, just make sure they don't replace you power supply with a low quality one.
Mar 17, 2011 | HP Pavilion Elite M9060N PC Desktop
I have a Dell Dimension 5100 Desktop that will not turn on.
hi...try to open side cover then find the memory then pull out and clean the pin connectors using Paper Eraser only..thanks...
May 10, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
My compaq presario c500 doesn't respond to the start button
try to turn on the laptop without the battery and only the power cord plug in.
if your laptop works with this you need new battery or update bios ( there might be fix for battery monitor)
if not, call service support, might be motherboard issue
let me know an update
Apr 03, 2009 | HP Compaq Presario C500t Notebook
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
