Question about Danby DAR483BLS Compact Refrigerator
Danby DAR483BL Bar fridge
My bar fridge has started to freeze everything. I have unplugged and re-connected to get a LE code come up on the LCD panel and can't use the up or down arrows to change temp or the C & F button to change view.
Any thoughts? Is it as simple as the thermostat inside has gone?
Phil
  • Anonymous Jun 18, 2008
    Same fridge same problem! We've had to throw out 2 fridge full of beer and wine, and it's getting old fast. Sears in of no help at all, they took t fridge 3 months ago and we've not seen it since.
huuum
  • 750 Answers
SOURCE: danby compact 482 fridge is
Hello tbrown7777
Welcome.
You said, Your Danby compact 482 fridge is freezing everything. thermostat switch seems to check out.
Just 482 is incomplete!!!!!!!!!
Can you send me the complete model number off the sticker in the fridge or on the rear of the fridge?
and the year of it! waiting your response!
Huuum
Posted on Oct 21, 2008
  • 1462 Answers
SOURCE: this is a Danby refrigerator
fault is the thermostat. auto defrost on a fridge (but not a freezer) is a function of the thermostat
Posted on Nov 16, 2008
  • 306 Answers
SOURCE: bar fridge
There is a PTC relay on the compressor you need to replace it. Small black square looking device take the wire retainer clip off and pry off the relay. Get the wires going to relay noted and then get the model number and make of your unit. Go to a parts house for appliances and get a new one. About 25 bucks for that little dude but it is a needed for your compressor. Could get a 3 in 1 relay they are a lot cheaper and easy to install. let me know how it goes ken
Posted on Jan 12, 2009
  • 4 Answers
SOURCE: Temp wont go below 60
Very simple. Call Danby at 1-800-26-DANBY and tell them the issues you are having. The reps there are very knowledgable and more than willing to help. I just had to replace a computer pad and they are awesome to deal with. FYI, the owner's manual does not have a parts listing. Good luck
Posted on Jun 15, 2009
reddyanantha
  • 205 Answers
SOURCE: I have a Danby Kegerator and the thermostat
hello sir/mam
please check and change the temp sensor then see its working
Posted on Sep 15, 2009
Danby Silhouette frig freezing everything regardless of thermostat setting.
It's the thermostat that's failed.
You'll need to buy a replacement unit, then fit it into the fridge.
If you can do this yourself, by all means get on with it.
If you can't do this yourself, you'll need to pay an engineer to do this for you,
or let everything freeze.?
best of luck
Mar 14, 2018 | Danby Refrigerators
Control panel on front stops working, only freezer lights are lit, freezer and fridge stop cooling.
when half of the display goes out, it is giving you an error code telling you what is wrong with the fridge.Unplugging it simply resets the computer until the error comes back typically within a few hours.
without knowing what is lit up, it is difficult to help you so I would recommend putting the error code "which bars are lit up" in a comment so we can diagnose further
Feb 03, 2018 | LG LFX25960ST Stainless Steel French Door...
The compressor of unit not turn on again after unpluged
You can just unplug the relay and shake it. If it rattles, it's bad.
What is your model number?
Nov 01, 2012 | Refrigerators
My tv will freeze on menu
Looks like there is/are jammed button/s in the remote. Try removing the batteries from the remote and using control panel of the TV.
Jul 28, 2012 | Vizio M470NV 47 in. LCD HDTV
47 in vizio tv keeps freezing when i go to menu
Look for jammed buttons on the remote or on TV.
I mean it freezes EVERYTHING. Pop, water, juice, top or bottom. I have unplugged it overnight, no change. It is the thermostat. I just don't know where to get one.
Please repost this in the appliance area dealing with this type of equipment as for some reason it is posted in the TV area.
Jun 14, 2012 | Sylvania Televison & Video
Freezer not freezing, refrigerator not cold, frost on back wall of freezer, what do ii do?
You have an ice block if the fridge is not cooling and freezer somewhat is. There are a few options you have. First off the bi-metal defrost thermostat has to be replaced. This may be your only problem. The other two things you can check one it your heater. Once you remove the ice to can test the heater for continuity. The other is your defrost timer. Unfortunately you have a computer board that is your timer. You cant test this but you can see if it is working. If the box shuts everything down the fans in freezer and the compressor for 8-30 minutes than kicks everything back on chances are your board is fine. Now to fix your problem.
Option 1 only use if you have a backup fridge to put everything in. Transfer all your food to backup fridge. Unplug fridge for 48-72 hrs with doors cracked open and have towels surrounding the fridge for all the water. Remove back panel in freezer to check for ice block. **Remove back access panel and at the top of coils is your bi-metal. It has two wires going to it. Replace. Now to test the heater you will see the wires to the heater if you have a glass heats there is a pink and blue wire that run down your coils to the heater. Remove the heater and test for continuity. If you have a bar heater you will see two wires running up along the side of coils. You have a bar heater on this icebox. Chances are the heater will still be good. Now once everything is back together than give it a couple hours for temp to get back down before moving your food back.** If you have not heard the box shutdown. Dont put you food back yet give it three days and than check for ice buildup. If I block is forming again replace defrost board if not than it was just your bi-metal.
Option 2: If you dont have a backup fridge. Follow most of steps above once Ice is melted. Get a couple bath towels and a hair dryer. Now remove freezer access panel and with box unplugged start melting all the ice and letting a mojority of the water fall onto the towels. Now once all the ice is melted Take flashlight and look between all the coils. Ice can be hideing and your will have problems again. Now do everything between aristcrats above. Now if you have not hear the box shutdwon your board maybe out. Hopefully its just your bi-metal.
If you have a more question or need further assistance please reply.
Aug 02, 2011 | Maytag MZD2766GES Side by Side...
Washer has a LE (or EE) code or something like that. First character looks like an E missing the top bar, or an L with an extra bar in the middle. i was doing a load of towels when this happened. i assumed...
Washing machine has an LE error code
Is this a new installation? In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Jun 09, 2011 | LG Washing Machines
Hello tbrown7777
Welcome.
Huuum
Oct 20, 2008 | Danby Refrigerators
Danby DAR483BLS Compact Refrigerator Logo
166 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
