Question about Viking DUAR140 Compact Refrigerator
Refridgerator does not cool anymore
I have a Viking DUAR140 or VUAR140 Compact Fridge (it says VUAR but matches the picture on the DUAR) and I left town for quite a while and the fridge was ajar. It no longer cools anything, the motor does not run. The light still works, but nothing else does. I tried changing the level on the cold dial and jiggling it but to no affect. What should I try next?
3 Suggested Answers
  • 32 Answers
SOURCE: Eaton Viking mini fridge not getting cold
yes. you certainly need to get a technitian out there. it seems that you are having a shortage of gas. if you have a gas shortage, then there must deffinitly be a gas leak somewhere.did you recently try to clean the plate that you mentioned with something shap? if so then you might have punctured it and that is where your gas leak might be. you do get special epoxies that you can do a quick fix, but you will still have to send it to a repair shop to regas and evacuate the unit. good luck
Posted on Sep 07, 2009
  • 101 Answers
SOURCE: 2006 Viking VUAR 141 bar fridge not cooling enough
The thermistor is looking for a very cold temperature before shuting off for the cycle defrost to work correctly. Thus if if shuts off early I would suspect the thermistor or the potentiometer. The pot is connected to terminals # 6 and 7 and should have a resistance over 90K-ohms when set to the coldest position. The thermsitor should have a resistance of 5.6K-ohms at 0 C and near 2.2 at 20 C. The control rarley fails but if it has been recently replaced the DIP switches (there are four of them) may be in the wrong position. If they are in question, try talking to technical customer service at Marvel (they made the unit). Their number is 800-223-3900. Your Viking VUAR 141 should be the same as their 60AR. The thermsitor is usually the most troublesome component but usually fails in the opposite way causing the unit to run too cold.
PS does the cooling fan shut off the same time as the compressor? if not, then the compressor overload is the issue...the the temperature control. If both shut off and on at the same time then you are on the right track.
Good Luck - Subdriver
Posted on Mar 25, 2010
The light is blinking on my refridgerator
How long was it left open? Evaporator coils may just need defrosting to restore normal operation.
Sep 15, 2017 | Refrigerators
Ge Refeigerator not cooling anymore
You should compromise with repair guy,may he is anice person
Jan 21, 2015 | GE Refrigerators
Kenmore elite refridgerator
check to make sure door is not stuck shut... or food may be blocking door outlet (usually located upper left hand corner of fridge side
Aug 29, 2014 | Kenmore Refrigerators
Refridgerator and Freezer Not Cooling (2 year old fridge)
Some of these had problems with the door light switches between the doors. They also control the fans. The top and bottom both have fans in back. Try opening top door and holding door light switch in. Wait for a couple minutes to see if fan comes on. Try with freezer too. If not coming on may need switch.
Jun 02, 2010 | Samsung RB215LASH
Mar 22, 2010 | Refrigerators
Ed27dsxdw01 side by side fridge
I had this "problem" for a little while. Thought I was gonna trash the fridge and start over anew. Turned out I had a bag of greens sitting up along the top left side of the fridge that was blocking the vent where the air from the freezer side blows in to cool the fridge side. Clear off the top left side of your shelf to start with (would be good if they included this "tip" in the owner's manual).
Aug 15, 2008 | Whirlpool ED2FHEXN Side by Side...
Haier hrt02wnc compact refridgerator 1.7 cubic
I have a Haier mini fridge model hrt02wncbb it will not cool, The fan runs all the time. I keep it in my class at school but there is five other mini fridge they work find what should i do?
Apr 13, 2008 | Haier HRT02WNC Compact Refrigerator
Viking DUAR140 Compact Refrigerator Logo
64 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
