Monitor saying no signal
Put a new processor in my motherboard power is going to the motherboard and processor but the monitor keeps saying no signal
  • 3 more comments
  • Anonymous Jul 11, 2008
    the motherboard light ls on ,the cpu fan is on but no sinal to the monitor.I try the video card on a different computer and its working.
  • larry82 Aug 02, 2008
  • rescomres Oct 03, 2008
    I have no signal to monitor i have power monitor remains blank cannot tell if the board is bad or if the cpu is bad there are no beeps to go on my board is a P4MBMS with a celeron D 2.8 please help
  • Anonymous Nov 25, 2008
    I have the same problem. my pc just stopped working one day.
  • thom_asm May 08, 2009
    every time i go to my computer it keeps saying no signal i thought it was the video card but my video card is only new help!!
  • 458 Answers
Check the Pins in the monitors serial port and make sure all are straight 15 of em
Posted on Jun 03, 2008
Mine was doing the same i took it to computer oasis and they said my modem was bad and was affecting other things,,removed it and since i am on dsl that was all i needed to do,,works like a charm!
Posted on May 04, 2009
My computer moniter keeps telling me that theres no signal please can you help me solve my problem
Posted on Nov 10, 2008
When I turn on my gateway computer my monitor will turn on but will says "no signal RGB". is it my motherboard thats going bad?
If the monitor comes on with the Gateway logo and follows with no signal, the monitor is probably okay. If the computer seems to run with no display then I would suspect the video graphics card, but there are a lot of variables that I do not know. I suggest a computer repair store to check your system with an estimate.
Dec 31, 2010 | Gateway FPD1976W LCD Monitor
Hi, my Dell Vostro 200 monitor isn't working; when I boot up the light is blue and everything else seems to work but the monitor says 'Entering power save mode' or something and it shuts off. I can't get...
Your monitor is most likely fine. That message is the monitor telling you it's not getting any video signal from the computer.
If you're hearing all the sounds that go with a normal startup (usually a beep from the motherboard, then hard drive activity, finally the normal Windows startup sound through the speakers), and seeing that message, then you may have a monitor problem. You can try another monitor as a test.
The trouble is probably that the computer is turning on, but not actually starting up. This may be due to power supply, memory, processor or motherboard problems. Or one of the drives or expansion cards connected to the motherboard may be keeping the system from starting.
Make sure the memory modules are firmly seated in their sockets, and disconnect everything else but the power supply. If the motherboard, processor and memory are working, the system will start and you'll see something on the monitor. Then you can start reconnecting parts and see when the problem returns.
Mar 30, 2010 | Dell Vostro 200 Mini Tower With 20" Flat...
No signal on monitor
You might try switching the VGA cable if you haven't. If that doesn't work then I'd agree with you in saying the motherboard is likely fried.
May 26, 2009 | AMD ASUS A7V8X-X MOTHERBOARD ATHLON XP...
New Motherboard & Processor not working
Usually this symptom has to do or with memory modules with problems or the VGA adapter (integrated) could be damaged. First try to reset the BIOS of *********** taking out the battery and using the reset jumpers informed in the Mother Board manual. Then put the battery and the jumpers back to the factory default position and try again.
If this doesn't work, try to plug the power cord to another 220V as the ground could cause this type of problems.
You can also try to install another VGA adapter to check if you receive the VGA signal in your monitor.
Hope it helps...
Please tell us about your progress.
Best regards
Eduardo
Oct 04, 2008 | Computers & Internet
Mpga478b
have u check ur memory?... ur videocard and powersupply...thats the main problem of pc if it has no display....just try it one by one...hope it can help u
Sep 10, 2008 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Installed new Power supply, Monitor stays in standby...? So I noticed my fan was starting to go out, then it actually went out, my power supply would start to over heat and the cpu would shut itself...
Your problem is either the processor or the motherboard. that is why your monitor is not getting any signal. first try to replace the processor because I suspect that this might be the problem as it has gotten overheated before. if there was a power problem with you power supply you monitor would not power up at all.
Jul 10, 2008 | Computers & Internet
Computer won't boot up
Make sure that your power switch is connected to the correct pins on the motherboard. The LED you see lit may be the stand-by power indicator saying it has power and is waiting for the signal from the power switch.
May 06, 2008 | ASUS CROSSHAIR Motherboard
No signal to monitor when booting.
(1) Remove memory from mother board and start the system if you happen to listen long beep then RAM is not working properly.
(2) Clean RAM conducting area on mother board with clean cotton cloth, put one peice of RAM and test and check the othe peice also, if working you could any sign display . Before doing all these check mother board any LED is glowing if so your SMPS is working after you turn on UPS.
(3) Check for all proper connection for all cables. Have you connected video cable of monitor to mother board VGA (it will not work because it is disabled as soon as you installed XFX GeForce 8800 GT), your viedo output only will come through XFX GeForce 8800 GT VGA port.
(4) If propelm persits Deassmble complete the system and reassmble & do n't connect HDD, DVD, floppy. Cehck with bare mother baord, processor, RAM (put one picese at a time) by connecting viedo cable of monitor
Apr 19, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
New power supply, but turning on no signal to monitor
well this is one of the nightmare problems I keep got into ..there can be alot of posibilities..but the most common are the video card is damdaged or the mainboard.try to change the video card and check than.if the problem persists,than is a motheboard fault..look to all the condensors,chech the intefrity of your connections..
good luck.
it is  a very booring work.
Feb 03, 2008 | E-Machines (308714) Motherboard
Computers & Internet Logo
1,364 people viewed this question
David Payne
David Payne
