Question about iiyama E431S-B 17" LCD Monitor
ProLite E431S - comes on dim for a few seconds - then off!
Well the title explains it all really!
If I were to switch the monitor on, it will start up but show a dimmer picture than it's twin next to it! then after about 2-3 seconds it goes back into stand-by.
any ideas anyone?
  • 42 Answers
Probably the power supply is defective.
Most probably the electrolytic capacitors in the secundary circuit heve become bigger then they used to be.
Replace them all...
greetings Drikus
Posted on Oct 12, 2008
I can't get any sound from the monitor the menu doesn't seem to switch the sound on
Did you connect an audio-cable from the "line-out" socket on your computer's sound-card to the "line-in" socket on the back of the monitor?
Nov 05, 2010 | iiyama ProLite E431S 17" LCD Monitor
My iiyama e431s monitor pwers on and off every 2 secs. the picure is fine when the power light is on but the light and picure switch off regularly every 2 secs.
1) Go to Control Panel (Located on the start menu).
2) Then double click on Power Options.
3) The Power Options Properties window shall now open.
4) You will see a section called Settings for x power scheme, the x depends on which power scheme is enabled.
5) Click on the down arrow to the right of Turn off monitor: And set this to Never.
This should stop you monitor from powering off every 2 secs. If you need any further help just add a comment.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
Nov 02, 2010 | iiyama E431S-B 17" LCD Monitor
Iiyama Prolite 434S monitor is too dark
Dim or dark display can be caused by a faulty inverter board or faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp, the CCFL lamp is a miniture fluro tube and these dim with age.
Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site. :-
www.lcdparts.net
Sep 28, 2009 | iiyama ProLite E434S 17" LCD Monitor
Iiyama Prolite E431S turns itself on and off
i think your monitor lose a power connection
Aug 31, 2009 | iiyama E431S-B 17" LCD Monitor
Blank screen, but has power
It is most likely a backlight that has burnt out or something else of the sort. You will want to call HP Support and explain to them of your troubles.
Aug 17, 2008 | HP L1706 17" LCD Monitor
Iiyama E431S-B 17" LCD... Problem:
Power supply is defective, replace all secundary capacitors.
greetings Drikus
May 22, 2008 | iiyama E431S-B 17" LCD Monitor
PC monitor wont come on.
Check that the power cord is fully plugged in first.
It is probably the inverter board inside the monitor.
(if the screen does properly display ever then it is not the screen)
It CAN be fixed but I do not suggest anyone open up a monitor (LCD or CRT) who is not "technically inclined."
If you really want to fix this particular one then take it to a local tech and get an estimate first. If it's almost as much as a new monitor then buy a new one.
Mar 14, 2008 | iiyama ProLite E434S 17" LCD Monitor
Monitor dims
Your monitor in hardware problem front panel keys short in side.change menu switch on boar.or command section problem.check ic or componets relate it.
Mar 03, 2008 | HP mx705 17" CRT Monitor
Colour changing
I found this on another site:
[QUOTE=numbnutjas]I had the same problem along with lots of others who bought this great prolite monitor.
Whenever you turn the power off for more than five seconds the monitor looses an important bit of info of a hidden menu. Iilyama are not keen on publicizing the fact their monitor has a bug!
Follow these steps very carefully, it might not work the first time but it does work I promise.
Make sure that the moniter power button is off.
Unplug monitor from mains ( the auto exit button should flash red after about five seconds and you hear a popping sound.)
plug monitor back in mains.
hold down + and - on the monitor
now hold down power button on monitor
let go of power when power button when the green led lights up
let go of + and - buttons
wait a few seconds and press menu, a hidden menu will appear in the top right
use the + and - buttons to move the hilighted option over the auto colour option in the menu
push the menu button.
It does work, but if you have any problems: email at : miamoo2038 at hotmail dot co dot uk
Feb 23, 2008 | iiyama ProLite E434S 17" LCD Monitor
iiyama E431S-B 17" LCD Monitor Logo
361 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
