Question about Frigidaire ATF6000ES Front Load Washer
Front Load Washer holding water in bleach compartment
The water doen't drain out of the little tray you put detergent and bleach in.
  • tmorga6918 Jul 05, 2008
    The bleach and liq softener fills with water and I cannot add bleach. Tried to soak up excess water but not working. The detergent part works fine. Brand new washer.
  • Anonymous Aug 20, 2008
    Same problem, bleach dispenser fills with water after each wash and it is a big inconvenience to take it out and dump the water in the sink. I called customer service and was just redirected to the book which says it is "normal." Well, I really don't think that improper siphoning of water is normal or a good design in a machine. I have not contacted them by email and am awaiting a response.
I take out the drawer and dump in sink. My manual says this is normal.
Posted on Jul 11, 2008
  • 868 Answers
Re place the valve that operates the dispenser.
Posted on Jun 03, 2008
Inserting detergent/fabric softner/bleach
First check in which tray the water is flooding then put in that tray and then start the main program
May 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer is leaking detergent from the tray on the front of the washer. I cannot find anything online to help.
YOU MEAN THE TRAY WHERE YOU PUT DETERGENT, BLEACH, AND FABRIC SOFTENER IN? IF SO, REMOVE THE TRAY OUT COMPLETELY. REACH INSIDE MAKE SURE THERE IS NOTHING IN THERE THAT COULD BLOCK THE WATER GOING INTO THE MACHINE VIA A HOSE. AND ALSO CHECK AND CLEAN YOUR TRAY. THE TRAY CAN BE DIS-ASSEMBLED TO CLEAN. RUN IN WARM WATER AND MAKE SURE YOU CLEAN THE WHOLE THING OF SOAP AND SOFTENER RESIDUE. DON'T FORGET THOSE TINY LITTLE HOLES ON THE TRAY AND THE REMOVABLE CAPS
BOYNISMO@YAHOO.COM OR 714-334-1998
Dec 09, 2009 | LG WM1812C Front Load Washer
The inside of my Speed Queen washer smells badly . It makes my clothes smell also , but not near as much as inside of the washer . What happened to cause this ?? Also , the detergent holder never...
Front load washers seal up tight with door closed. This causes the smell. Leave the door open in between loads.
The detergent holder always holds a little water.
Nov 04, 2009 | Speed Queen CTSA0AWN Front Load Washer
Cleaning agent placement
From left to right as you see.
1 This is for your frontloader soap powder or other detergent.
2 Fabric conditioner or softener. If this is too thick, mix with water to prevent clogging.
3 Detergent for soaking agent. I dont see 'bleach' anywhere
There is an panel, front bottom right which holds your pump filter, unscrew to clean out. But wait. Plug off the mains.
You will see a hose on the left, this is if your water in the tub cannot drain, you can drain it here. Your tub can hold upto 20 litres/4.4 gals.so have a suitable container to collect; carefully remove cap to drain out. Reason why it doesn't drain is because there is a block in your pump (right side) which you must clear.
To keep your pump from probs (a tip which you seldom see) empty all pockets of clothes before putting into machine. I have a non electronic Philco which i dont remember cleaning with hotwash or anything, 10years +
For exteriors do not use solvents or steel wool. Only hot soapy water with a mild non-abrasive cleaning agent, dry with soft towel.
Above should be useful. Pl rate.............
Mar 21, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Front load washer wsx208a
clean the detergent draw dont put the detergent liquid or bleach over the limit line...should low than that line.
Oct 05, 2008 | GE WSXH208A Front Load Washer
We buy a use front load wacher we dont have the manuel it is a 24 inch front load we dont know if we use the same detergent ad softner and were we put it please sent me or phone me 72 581 0294 or e mail...
Any detergent that says "Automatic" should be OK.
Pretty much any softener should be OK.
You will usually find a drawer on the front panel of the machine, just under the top edge, typically on the left hand side.
If you open this drawer, you will find it is divided into a number of (typically four) compartments. There will be one or two large compartments for detergent and one or two smaller, usually partially covered, compartments for bleach and conditioner.
You need to identify which is which.
Starting with detergent: If you only have one large compartment, that's the one to use.
If there are two, you need to know which is for main wash and which is for prewash. If one is bigger than the other, use the big one for your main detergent load. If using a cycle that does a prewash, put detergent in the smaller compartment as well.
If they're both the same, you need to experiment: Select a wash cycle that doesn't do prewash. Turn the machine on, and when it starts to fill, cautiously open the drawer a little and look to see which compartment has the fill water running through it. That's the one you need to use for your main wash detergent (use the other as well on cycles that do a prewash).
Now look at the smaller compartments. Hopefully, they'll be marked with a triangle for the bleach and something looking like a flower for the conditioner. If not, put a little bit of conditioner into the bottom of each, set the machine to "final rinse" and see which compartment it takes the conditioner from. That's the one you use for conditioner in future. (Don't worry about the little bit of conditioner you've put in the bleach tray - this will rinse out the first time you run a full cycle).
When putting in bleach or conditioner, it's important not to overfill. If there's a fill level line, don't go above that. If the compartment is covered with a grating then fill no further than the grating. Overfilling will cause the product to go into the machine too early in the cycle.
(Finally, strongly advise against posting your phone number or personal email address on public internet sites - it attracts all sorts of undesirable attention)
Good luck - and enjoy your new machine.
A.
Mar 15, 2008 | Washing Machines
Detergent doesn't drain
The rod which controls the flow of water to the various compartments needs to be adjusted. It is not a difficult fix. You can contact Malber usa (info@malberusa.com) and they can "walk" you through it. In the alternative, you can put the detergent in the pre-wash tray without concern.
Sep 19, 2007 | Malber WD1000 Front Load Washer/Dryer
Detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Feb 28, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
441 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
