The power in my house shut off. when it came back on, i turned on my pc and monitor and the color on my monitor was much darker. how do I fix it?
  • 53 Answers
Check your display for the auto setting and engage it that should activate the readjust.
If your monitor is a CTR (TUBE)
It should have the same settings. look at the manual that came with the display.
no manual you can find it on the web.
What ever the display is... google it and chances are you'll hook up.
goodluck
44hink
Posted on Jun 03, 2008
  • 44 Answers
There should be a menu button on your monitor. press it and select brightness.
The color on my new flat screen monitor is now yellow. It was fine. I restarted my computer and the color is now darker and yellow. Fixing the color doesn't seem to fix it either.
That means it is not getting the Blue color signal, you should try this monitor with another PC first to make sure it is not the PC video card problem, also check all the pins of the video cable and make sure the plugs are properly seated.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 27, 2011 | HP Pavilion F1903 19" Flat Panel LCD...
LG Flatron W2234S 22 purple tint problem
your LCD monitor has bad ccfl lamps or inverter circut..
May 08, 2010 | LG 22" FLATRON LCD Monitor
Hi, my SyncMaster 920nw turned off today, when I turned it on the colours were changed, all desktop went in transparent green and I can't make colours back to normal, I pressed the auto button and desktop...
Well a few things could be wrong. In my shop I could tell you pretty quick which it was. But lets look at the possibilities.
1. Monitor has gone bad.
2. Somehow the monitor has become partially disconnected from the PC on one end or the other.
3. The video card has gone bad.
First check that the cable is plugged in to the PC and the monitor securely.
If that doesn't fix the problem check it with another monitor. Borrow one if you have to. If that fixes the problem then you know your monitor gave up.
If it doesn't fix the problem then your video card is bad.
Apr 23, 2010 | Samsung SyncMaster 920NW Monitor
After reseting Asus vw192s I can´t have the normal color, It tries to autoadjust, for a second it is all fine and then turns into a darker colour, more blue. Don´t know what to do.
I have the same problem and you can fix it by entering in factory service mode:
1. Turn the monitor ON
2. Turn it Off
3. Press and hold MENU button and turn the monitor ON, led should glow orange
4. Press MENU again and service pop up will show up
5. Choice AUTO
Blue color on my screen vanished.
I have found this solution on polish forum.
http://www.elektroda.pl/rtvforum/topic1949561.html
Dec 30, 2009 | ASUS VW192S Monitor
Hello, i have an issue where my viewsonic A90F 19" crt moniter's picture dims darker at random...then returns back at random as well. Any idea what it might be? I recommend: | Change Remove Formatting Bold...
If you still have the monitor, check the signal cable -- wiggle it a bit at the PC end and at the monitor end, while watching the image on the monitor. Any change? If you have issues when moving the cable at the PC end, you may want to try shutting down the PC and disconnecting the monitor. Then clean the pins on the monitor's connector with 91%+ isopropyl alcohol and a cotton swab (make sure no cotton is left behind). let dry and try again.
If none of this make any difference, wait for the monitor to go dim. Then, gently smack it on all sides. If the image clears up or changes, there is likely an internal bad connection. Do not open the monitor unless you are familiar with all safety precautions involved.
I have the same monitor and I was having a similar problem. Turned out, there was a cracked solder joint on the signal board at the back of the CRT plus several more questionable ones.
Nov 08, 2009 | ViewSonic A90f (Metallic Black) 19 in.CRT...
I have a shap lcd computer monitor and when i plug it into my computer and turn the power on, the little green power light comes on, screens back. and after 5-10 seconds the light turns orange and blinks...
It could be your monitor is fine. It simply goes to a cycle when its turned on and does not detect any signal coming from your CPU, it simply goes on standby mode (hence the darker image and orange/blinking light.) have you checked the computer (CPU) part?
Dec 04, 2008 | Computers & Internet
Monitor not powering down
Do you mean the computer is sutting down but on the monitor showes different colors if so you might have a problem in the system you might have to reinstall you OS if the computer does shut down but the monitor stays on and flashes different colors you have to shut the monitor down manually with the power button on the monitor.
Feb 14, 2008 | Dell Dimension 3000 PC Desktop
Green color snowing on darker background... Help!
this type of discoloration problem occurs due to magnetic field near by ur monitor may be due to speakers or some other appliances... just keep some distance between them wit the monitor then on the monitor press menu and give degauss once... i am damn sure your problem will be fixed...
Feb 04, 2008 | Sony SDM-HS73P 17" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
