Question about HP DesignJet 3500cp InkJet Printer
HP Design Jet 3500 cp Replacement of Carriage belt
Carriage belt is worn out and needs replaced. How does one replace the belt.
    Scholar:
  • 96 Answers
Very carefully, if you can find a belt replacement. i would be surprized if you can find the part. this printer has been out of production for quite some time. remove the left cover, remove the right cover, (you need torx drivers #'s 8,9,10,15,20,25) on the left side, remove the encoder strip, lock the belt tensioner, remove the screws to remove the belt tensioner, remove the carriage assembly, don't forget to remove the trailing cables, make sure you replace the belt exactly the way it came off the carriage assembly and reverse the process to put it all back together. if you can find a certified repair person who can find the parts and has the tools, that might be the way to go. this repair should cost $300-400. if the repair person knows what they are doing. hope this helps.
Posted on Oct 01, 2009
Design jet 750 won't go into test mode
check to see if the belt that you changed was reinstalled correctly
with the proper tension because if the belt is too tight or too loose
these simptoms may be the result of poor adjustment.you need
just a small amount of play in that belt where you can take your index finger and softly poke the belt which should have a small
amount of play.go over what you did so that you can find where you have went astray
Nov 09, 2013 | HP DesignJet 750c InkJet Printer
On my HP 1050C Designjet I am getting the error 'Check printhead path Type 2. Then it says to switch off.
Hello. The "Check Print Head Path" error is usually a worn out carriage belt on printers more than 5 years old. Open the top cover and examine the area under the belt and look for debris that looks like pencil erasure crumbs. Other possible problems could be the tube system catching on something as the carriage moves, the encoder strip being very dirty or extreme friction between the carriage bushings and the rails they move on. If the belt needs to be replaced, a replacement kit can be purchased at: http://www.lpscomputer.com/c-790-hp-designjet-belt-replacement-kits.aspx
Hope this helps.
Bob
Jan 26, 2011 | HP DesignJet 1050c plus InkJet Printer
Our design jet 500 is showing a system error of 86.01
>Check carriage axes usage reached 100%? check carriage warn out position, feel old? replace it.
> Check carriage assm play..feel over play replace carriage bushings & lubricate it.
> Check carriage stuck in service station?, find out the reason shoot the problem.
Jan 14, 2011 | HP DesignJet 500 InkJet Printer
HP 500ps showing error is System error 86:01
System Error: 86:01
Problem Description: Carriage-Axis shutdown.
If this error code appeared but was NOT caused by a paper jam, then try the following:
* Too much friction in the Slider Rod. lubricate the Slider Rod.
* The Carriage is bumping into the Service Station. If the carriage
is stuck at the right hand side of the Printer and cannot be moved
out to the center of the Print Platen it is because the Service
Station cannot uncap the Printheads. In this case replace the
Service Station/Aerosol Fan Assembly
Apr 16, 2010 | HP DesignJet 500ps InkJet Printer
CHECK PRINTHEAD PATH
Check to make sure that the front top of the L bracket that shields the ink tubes on the carriage is not rubbing against the inside top front metal edge that is just behind the clear plastic cover. And make sure your rails are cleaned and then oiled with NYE oil. There is a problem with the design of this machine, where there is a bracket on the top of the carriage assembly that pushes the ink tubes towards the inside front of the machine causing unneccesary rubbing.
Jan 27, 2010 | HP DesignJet 1050c InkJet Printer
Check for free carriage motion by unplugging the printer while the carriage is in the print area of the plotter. Open the top cover and move the carriage to check for free movement. If there are rubber crumbs under the belt, the belt is worn out and needs to be replaced. Manual can be downloaded from: www.lpscomputer.com/ec/manuals.htm
Parts available at: http://www.lpscomputer.com/c-736-designjet-1050c-belt.aspx
Oct 01, 2009 | HP DesignJet 1055cm InkJet Printer
Carriage belt replacement
Use the carriage replacement procedure in the service manual. Download here: www.lpscomputer.com/ec/manuals.htm
Aug 10, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
HP 170 Color Copier Carriage Belt Replacement
My carriage belt has broke is there anyone who can repair it, or how can I fix it. H P Copier Model 170
Feb 04, 2009 | HP 180 Color Copier
Carriage belt replacement for HP 430
http://www.fixyourownprinter.com/forums/inkjet/36780
Fifth post down.
I changed the carriage belt using these instructions.
Hope that helps
Jan 08, 2009 | HP DesignJet 430 InkJet Printer
Replacement carriage belt for HP DesignJet 800
The part number is; C7769-60182 runs at around $70.00.
This component needs to be installed by a service technician. You can seriously damage this plotter if you remove the carriage ribbon connectors and do not install them properly. You will fry the pca board (a $1,100 mistake).
Nov 19, 2008 | HP DesignJet 500ps (42 in.) InkJet Printer
HP DesignJet 3500cp InkJet Printer Logo
468 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
