Question about Acer Aspire 5630 Notebook
Acer laptop turned laptop on started up screen stayed blank then turned itself off could you give me a reason why and how to fix it
  • 78 Answers
First thing to try would be to remove the battery and unplug from the mains, then hold down the power button to discharge all electricity from device, You will need to hold down power button for 1-1.5 minutes.
Once this is done put the battery back in and try again. Let me know how you go.
Posted on Jun 03, 2008
Fix a blank screen on acer laptop
Please be more specfic about what is the model, whatelse you see other than blank screen( do you see power LED comes on ,if yes does it stays on / comes on and off,......
Feb 14, 2015 | Acer Aspire Computers & Internet
My acer chromebook screen went blank suddenly
ALL YOU HAVE TO DI IS HOLD DOWN THE POWER BUTTON UNTIL A SCREEN COMES UP THAT SAYS:
"SUSTEM IS REPAIRING ITSELF".
That screen will stay on and along the top of the screen you will see a percentage progress line of the repair in progress. (It will take around 4-5 minutes)
Jan 22, 2013 | Acer Cromia Chromebook PC Notebook
Got an acer aspire ax3812 tower is on but screen stays blank got any ideas
Change the internal Ram sticks. This can cause a "Hold" in the BIOS boot process, thereby stopping the machine from going to the Operating System. Hope this helps.
Jan 29, 2012 | Acer Aspire Computers & Internet
My acer aspire5100-5022 blank screen.hooked up to a external monitor no problem. Is there a fix?
The reason the screen of your laptop is not functioning fine could most likely be of two sources.
1. The screen might be faulty,
2. The flip might be faulty.
To fix the problem if the screen is faulty, all you have to do is to replace the screen.
How to fix the screen?
  1. get the appropriate screwdriver,
  2. get an alternative screen or a new screen,
  3. open the laptop from the bottom,
  4. carefully force it open from the sidelines,
  5. try to disconnect the screen from the board,
  6. then you can REPLACE it with the new screen,
  7. couple it back together and it will start working fine.
fixing the flip?
  2. Open the laptop,
  3. check the connection from the link that assists in flipping the laptop,
  4. Check the cables link on the board,
  5. check for any faults and correct it,
  6. couple it back together,
  7. charge it for a while turn it on.
take care
Jun 18, 2010 | Acer Aspire 5100 Notebook
My acer aspire 5520 comes on then turns off how do I fix it
I've already solved my problem, and it maybe help somebody with the same trouble...so there you go:
1st step: Let the laptop turns on and off itself until it's screen turns to a white blank one
2nd step: Power off it
3rd step: Power on tha laptop. It will start normally and give you two options of startup
4th step: Choose to start the "recovery test", then it will repair any error and will start Windowsmag-glass_10x10.gif normally
Well, that's what I've done to recover my Acer...
Jan 19, 2010 | Acer Aspire 5520-5908 Notebook
My acer 4520's screen is blank when i'm turning it on.
There are approx 4 reasons why this might happen:
  1. The backlight has gone (Find a dark place and shine a torch into the screen and see if you can see an image in the background, if you see an image then the backlight has gone) - Needs a new backlight (Engineer to remove and fit) or have a new panel fitted.
  2. The panel has died - Need a new panel
  3. A cable has worked itself loose or is broken
  4. The inverter has gone - Need new inverter
  5. Long shot, the bios has got corrupted - Engineer could re-flash the bios
  6. Long shot, Mainboard onboard graphics has gone - Need new mainboard
My personal opinion is that the backlight or inverter has gone - Either way it needs to be opened up to repair it, consult a service centre and get a quote or repair it yourself if your up for it.
Thanks
Sep 05, 2009 | Acer Aspire 4520-5582 Notebook
I have an acer laptop. When you turn it on you can hear it running but the screen stays blank
Is the screen black(unlit) or blank? If it's not lit, use a bright torch to see if there is a picture, and it means the backlight has gone, which is an easy fix.
Jul 08, 2009 | Acer Computers & Internet
Blank screen...no keys working
Hi
is the acer still covered by the warranty? you can get it repaired for free if it is, its a common fault with these, my friend over here in finland has one of those and it did the same thing, he got it replaced / fixed for free since it was under warranty. get yours fixed also.
May 12, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 3003LMi not posting anymore
Sound like a bad video card or its connection to the video inverter or screen.But mostly a bad video card and maybe high heat related failure.
Dec 10, 2008 | Acer Aspire 3000 Notebook
Laptop Wont Boot
Does it sound like it's starting up at all? Is the problem that only the screen turns blank? You might have just disabled the standard output. Try pressing Fn (bottom left on the keyboard) and the F5 on the top a few times to see if the screen toggles back on. You might also try to run it without the battery, and on the battery only in case it's a faulty battery or power supply that causes the problem. If not, it sounds lsike a serious problem, so if there is any chance of the waranty still being valid I'd call acer support asap.
Jun 17, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 5630 Notebook Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
