Question about Lexmark X2350 All-In-One InkJet Printer
Fixing the lexmark 2300 printer
I wish it was that simple,but its not, after inserting the dics to install, it seems to stop loading,when you press start and then all programs,there is no sign of lexmark in there, i dont know why it wont instll or show up anywhere.
  • 103 Answers
It is a printer, not a program, so it will not show up in programs.
If the disc does not autorun when you insert it, simply click start/my computer then select the drive you inserted the CD into. From there you can start the installation manually (double-click the file the ends ".exe".
Posted on Jun 15, 2008
When i try to print on my Lexmark 2300 it keeps saying scanner unit is open, but it isn't. I've turned it off and on opened and closed the unit but this hasn't helped
It could be the cartridges in the carrier. Please follow the steps below to identify and fix the problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Unplug and re-plug the printer into the power outlet to reset it.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge. You may also try to insert a different known working cartridge to determine if the cartridge you are currently using is faulty.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 15, 2011 | Lexmark Z2300 InkJet Printer
I cant dound load my printer to my lap top lost the dic,6924,239544855_652569478_0_en,00.html
here is the site my company uses to fix and download lexmark drivers click on printer click on your model and away you go
best of luck
merry christmas.
Dec 22, 2010 | Lexmark Z1420 InkJet Photo Printer
Can't remember how to scan document from Lexmark printer
There are several ways to scan. Place your document face down on the glass. If you have the Lexmark software loaded and running its monitor program, either press the scan button (the second button) on the printer or launch the Lexmark Imaging Studio (Start > All Programs > Lexmark 2300 Series > Lexmark Imaging Studio or double click on the shortcut on the desktop) and click one of the Scan options (pictures or text).
The All-in-one Center will open and you can adjust the scan settings and the destination for the scan. Click Scan Now to scan.
If you have Vista, you can also scan to Paint. In Windows 7, both Paint and Windows Fax and Scan will also acquire scans.
If you have problems, try a new USB cable or connecting to a different port. Scanners require bi-directional communication with the computer and can fail even when the printer works.
(We had a scanner that would preview but not scan due to a bad cable. So it can give an intermittent issue.)
May 17, 2010 | Lexmark X2350 All-In-One InkJet Printer
I need to get a copy download of the dics for printer .
Here you go !
What I'll do is I'll provide you with the website.
In this you'll have an option "Search by Model" In this type X2600 without space between X and 2600 and press enter. Now you'll have an option to choose your Operating System. Choose your Operating system (Eg: Windows XP / Windows Vista / Unix / Linux OS/ Mac OS) and you'll have an option saying "Download Now" . Click on that and Save File in any location in your Hard drive. Once this is done you can either Run and install the software or Write the same in any writable CD or DVD using a burning software.
Good Luck !
May 29, 2009 | Lexmark X2600 InkJet Printer
You can download both the User's Guide & the Setup Sheet for this printer from Lexmark's website at the following link:
May 15, 2009 | Lexmark X2350 All-In-One InkJet Printer
Lexmark 2300 series scanner
i went to control panel and typed in scan. clicked on "scanners and cameras". hit "scan profiles". chose lexmark. hit "add profile". it wouldn't save so i hit "preview first" and that made it physically scan and it showed up on the screen. after that I could hit name it and "save profile" and i got my papers onto the comp. i can't figure out how to get the papers out of the control panel format tho. also my sis's comp is high tech so i don't know how much use this will be. but if you get this far and the files copied out of the control panel format plz let me know.
May 19, 2008 | Lexmark X2350 All-In-One InkJet Printer
Lexmark X2350 printer problem
Usually the light blinks if you have started a print job and run out of's trying to get your attention to insert more paper before it can continue. Check and see whether there are any print jobs that weren't able to conclude and delete them. Go to 1) Start, 2) Control Panel, 3) Printers and Other Hardware, 4) View Installed Printers, 5) Lexmark 2300 Series. When you double click on the Lexmark Printer Symbol, it will open up a smaller window which will show you whether there are any print jobs that are waiting to print. If there are any, delete them. Hopefully this will solve your problem.
May 08, 2008 | Lexmark X2350 All-In-One InkJet Printer
Lexmark 2300 driver
I cant load my lexmark 2300 onto my new computer with vista windows
Apr 03, 2008 | Lexmark X2350 All-In-One InkJet Printer
Lexmark 2300 all in one not scanning
I had this same problem.
For some reason when the printer installs, the scanner is disabled.
You will need to be on a user with administrative rights to complete this fix.
Also be sure you have downloaded and istalled the latest drivers from Lexmarks site.
  • Right click my computer.
  • Select manage from the dropdown menu.
  • Press continue if a UAC popup comes up.
  • In the left pane click Device Manager.
  • From the list of devices, expand "Imaging devices".
  • Right click on the lexmark xxxx-xxxx series.
  • Select enable.
Windows should automatically find the driver you installed and the scanner should would without a hitch now.
Hope this helps ya!
Sep 25, 2006 | Lexmark X2350 All-In-One InkJet Printer
Lexmark X2350 All-In-One InkJet Printer Logo
49 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
