Question about Maytag Washing Machines
No matter which wash cycle is used nor how big or small the load is, the machine will not do the last spin out.
  • 868 Answers
Is this a front load?check the circuit board on top console look for a burnt R-11 on board ;replace control board & wax motor
Top load I need a model number.
Posted on Jun 03, 2008
My washer makes a horrible noise in the final spin cycle on all washes
does ur washer shake & move also? if so, it may be that the loads r too small. especially with top loaders, when the machines not full, the clothes r not evenly distributed and that could do it. if u stop the cycle and evenly distribute the clothes, it should stop. hope that helps.
Jan 10, 2012 | Whirlpool Washing Machines
It seems like our washing cycle goes all the way through to drain/spin without fulling draining or spinning - we have fabric softener left in the dispenser and the clothes are - particularly at the bottom...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 27, 2011 | General Electric WJRR4170GWW Top Load...
Kenmore washing machine didn't spin @ end of cycle
If you tried a different cycle and it worked this means that the timer is probably bad on the main cycle that you use. If the machine does not spin on all cycles, then please check out the LID SWITCH.
Nov 12, 2009 | Washing Machines
Spin issues
Your clutch is no good You will need to replace it.
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Bosch Nexxt 800 washer won't drain clothes fully
There is not a Spin Only Cycle BUT there is a REFRESH cycle that will take about 10 minutes.
Sometimes when the load is unbalanced and the machine can not balance the load by itself, the clothes will remain soaked. To avoid this, make sure you always have a balance of small and large things and when loading your machine, do not shove the items in so they ball up.
Dec 27, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Final Spin
could be a clogged water pump. check the filter/pump for dirt and small items, socks, pins, coins,
tnx 4 using fixya,
drcool
Oct 11, 2008 | GE WBSE3120B Top Load Washer
Whirlpool washer front loader model LHW0050PQ
This is not a Malber machine but the following fix has worked for the Malber washer. Try unplugging the machine for at least 2 minutes. Do not just turn it off as there is still current going to the machine .This should clear the computer. If this does not work, the imbalance may have overloaded the circuit board requiring replacement.
Nov 15, 2007 | Malber WD1000 Front Load Washer/Dryer
My Maytag front loading washer does not fully rinse cloths MAH8700A. I purchased this washer about 6 months ago. I usually wash small loads but have noticed it doesnt matter what size load. When first...
Is the drain path free-flowing? That is, does the water eject freely during spin/rinse? Maybe there's a restriction in the line, or it's too high above the washer.
Feb 25, 2007 | Maytag MAH8700A Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
